7.3
cs_gradient_boundary.h File Reference
#include "cs_halo.h"
#include "cs_internal_coupling.h"
+ Include dependency graph for cs_gradient_boundary.h:
void cs_gradient_boundary_iprime_lsq_s (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, const cs_internal_coupling_t *cpl, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_halo_type_t halo_type, double clip_coeff, const cs_real_t *bc_coeff_a, const cs_real_t *bc_coeff_b, const cs_real_t c_weight[], const cs_real_t var[], cs_real_t *restrict var_iprime)
 Compute the values of a scalar at boundary face I' positions using least-squares interpolation. More...
void cs_gradient_boundary_iprime_lsq_v (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, const cs_internal_coupling_t *cpl, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_halo_type_t halo_type, double clip_coeff, const cs_real_t *bc_coeff_a[3], const cs_real_t *bc_coeff_b[3][3], const cs_real_t c_weight[], const cs_real_t var[][6], cs_real_t *restrict var_iprime[3])
 Compute the values of a vector at boundary face I' positions using least-squares interpolation. More...
void cs_gradient_boundary_iprime_lsq_t (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, const cs_internal_coupling_t *cpl, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_halo_type_t halo_type, double clip_coeff, const cs_real_t *bc_coeff_a[6], const cs_real_t *bc_coeff_b[6][6], const cs_real_t c_weight[], const cs_real_t var[][6], cs_real_t *restrict var_iprime[6])
 Compute the values of a symmetric tensor at boundary face I' positions using least-squares interpolation. More...
◆ cs_gradient_boundary_iprime_lsq_s()
void cs_gradient_boundary_iprime_lsq_s ( const cs_mesh_t m,
const cs_mesh_quantities_t fvq,
const cs_internal_coupling_t cpl,
cs_lnum_t  n_faces,
const cs_lnum_t face_ids,
double  clip_coeff,
const cs_real_t bc_coeff_a,
const cs_real_t bc_coeff_b,
This assumes ghost cell values for the variable (var) are up-to-date.
A simple limiter is applied to ensure the maximum principle is preserved (using non-reconstructed values in case of non-homogeneous Neumann conditions).
Remarks
To compute the values at I', we only need the gradient along II', so in most cases, we could simply assume a Neumann BC for a given face.
We still use the provided BC's when possible, for the following cases:
  • Given a non-uniform Dirichlet condition and a non-orthogonal mesh, the Dirichlet values at face centers (shifted by II' relative to I') can convey a portion of the information of the gradient along II'.
  • For cells with multiple boundary faces, information from faces whose normals are not orthogonal to II' can also provide a significant contribution to the normal.
For coupled faces (with internal coupling), we assume a Neumann BC, as the values that could be computed at the intersections of the segments joining coupled cell centers and the matching boundary face do not currently account for the non-linearity associated with wall laws.
A more precise computation for cells with multiple coupled boundary faces would be possible by using multiple passes, first estimating boundary face values without recontruction, then using that information for faces which are not tangential to II' in a second pass. Note though that as the mesh is refined, the portion of the boundary adjacent to cells with multiple coupled faces (i.e. at corners and ridges) diminishes.
[in]mpointer to associated mesh structure
[in]fvqpointer to associated finite volume quantities
[in]cplstructure associated with internal coupling, or NULL
[in]n_facesnumber of faces at which to compute values
[in]face_idsids of boundary faces at which to compute values, or NULL for all
[in]halo_typehalo (cell neighborhood) type
[in]clip_coeffclipping (limiter) coefficient (no limiter if < 0)
[in]bc_coeff_aboundary condition term a, or NULL
[in]bc_coeff_bboundary condition term b, or NULL
[in]c_weightcell variable weight, or NULL
[in]varvariable values et cell centers
[out]var_iprimevariable values et face iprime locations
◆ cs_gradient_boundary_iprime_lsq_t()
void cs_gradient_boundary_iprime_lsq_t ( const cs_mesh_t m,
cs_lnum_t  n_faces,
double  clip_coeff,
const cs_real_t bc_coeff_a[6],
const cs_real_t bc_coeff_b[6][6],
This function uses a local iterative approach to compute the cell gradient, as handling of the boundary condition terms b in higher dimensions would otherwise require solving higher-dimensional systems, often at a higher cost.
Remarks
To compute the values at I', we only need the gradient along II', so in most cases, we could simply assume a Neuman BC.
The same logic is applied as for cs_gradient_boundary_iprime_lsq_s.
◆ cs_gradient_boundary_iprime_lsq_v()
void cs_gradient_boundary_iprime_lsq_v ( const cs_mesh_t m,
cs_lnum_t  n_faces,
double  clip_coeff,
const cs_real_t bc_coeff_a[3],
const cs_real_t bc_coeff_b[3][3],
Remarks
