7.3
cs_domain_setup.c File Reference
Functions to handle the setup of a computational domain High level interface for handling the computation. More...
#include "cs_ale.h"
#include "cs_boundary_zone.h"
#include "cs_cdo_blas.h"
#include "cs_cdo_system.h"
#include "cs_equation.h"
#include "cs_evaluate.h"
#include "cs_gwf.h"
#include "cs_hodge.h"
#include "cs_log_iteration.h"
#include "cs_maxwell.h"
#include "cs_mesh_deform.h"
#include "cs_mesh_location.h"
#include "cs_navsto_system.h"
#include "cs_pressure_correction.h"
#include "cs_prototypes.h"
#include "cs_solidification.h"
#include "cs_source_term.h"
#include "cs_thermal_system.h"
#include "cs_time_step.h"
#include "cs_walldistance.h"
#include "cs_domain_setup.h"
+ Include dependency graph for cs_domain_setup.c:
static void _set_scheme_flags (cs_domain_t *domain)
 Define the scheme flags for the current computational domain Requirement: domain->cdo_context is alloctated. More...
void cs_f_domain_setup_init_model_context (void)
 When the models have been activated, continue to allocate, add and define structures related to those models This function is called after the user function cs_user_model and before the user function cs_user_parameters. More...
void cs_f_domain_initialize_cdo_systems (void)
 Initialize CDO systems. More...
void cs_domain_set_output_param (cs_domain_t *domain, int nt_interval, int nt_list, int verbosity)
 Set auxiliary parameters related to the way output is done. More...
void cs_domain_set_time_param (cs_domain_t *domain, int nt_max, double t_max)
 Set parameters for unsteady computations: the max number of time steps or the final physical time of the simulation. More...
void cs_domain_automatic_time_step_settings (cs_domain_t *domain)
 Set time step parameters for unsteady computations when this is not already done. This situation should occur when the GUI is used to set a constant time step. More...
cs_xdef_tcs_domain_def_time_step_by_function (cs_domain_t *domain, cs_time_func_t *func, void *func_input)
 Define the value of the time step thanks to a predefined function. More...
void cs_domain_def_time_step_by_value (cs_domain_t *domain, double dt)
 Define the value of the time step. More...
void cs_domain_initialize_setup (cs_domain_t *domain)
 First setup stage of the cs_domain_t structure Define extra domain boundaries Setup predefined equations Create fields (already done in the FV part) Define cs_sles_t structures for variable fields. More...
void cs_domain_init_cdo_structures (cs_domain_t *domain)
 After having read the mesh and the first setup stage build the connectivities and mesh quantities related to CDO/HHO schemes. More...
void cs_domain_finalize_user_setup (cs_domain_t *domain)
 Last user setup stage of the cs_domain_t structure. More...
void cs_domain_finalize_module_setup (cs_domain_t *domain)
void cs_domain_initialize_systems (cs_domain_t *domain)
 Initialize systems of equations and their related field values according to the user settings. More...
void cs_domain_setup_log (const cs_domain_t *domain)
 Summary of the main domain settings. More...
◆ _set_scheme_flags()
static void _set_scheme_flags ( cs_domain_t domain)
static
◆ cs_domain_automatic_time_step_settings()
void cs_domain_automatic_time_step_settings ( cs_domain_t domain)
◆ cs_domain_def_time_step_by_function()
cs_xdef_t* cs_domain_def_time_step_by_function ( cs_domain_t domain,
cs_time_func_t func,
void *  func_input
[in]funcpointer to a cs_time_func_t function
[in]func_inputpointer to a structure cast on-the-fly
a pointer to the created definition (cs_xdef_t structure)
◆ cs_domain_def_time_step_by_value()
void cs_domain_def_time_step_by_value ( cs_domain_t domain,
double  dt
[in]dtvalue of the constant time step
◆ cs_domain_finalize_module_setup()
void cs_domain_finalize_module_setup ( cs_domain_t domain)
Last setup stage of the cs_domain_t structure.
[in,out]domainpointer to a cs_domain_t struct.
◆ cs_domain_finalize_user_setup()
void cs_domain_finalize_user_setup ( cs_domain_t domain)
◆ cs_domain_init_cdo_structures()
void cs_domain_init_cdo_structures ( cs_domain_t domain)
◆ cs_domain_initialize_setup()
void cs_domain_initialize_setup ( cs_domain_t domain)
◆ cs_domain_initialize_systems()
void cs_domain_initialize_systems ( cs_domain_t domain)
◆ cs_domain_set_output_param()
void cs_domain_set_output_param ( cs_domain_t domain,
int  nt_interval,
int  nt_list,
int  verbosity
Set to true the automatic update of all advection fields.
[in]nt_intervalfrequency for the restart process
[in]nt_listoutput frequency into the log
[in]verbositylevel of information displayed
◆ cs_domain_set_time_param()
void cs_domain_set_time_param ( cs_domain_t domain,
int  nt_max,
double  t_max
[in]nt_maxmax. number of time step iterations
[in]t_maxfinal physical time of the simulation
◆ cs_domain_setup_log()
void cs_domain_setup_log ( const cs_domain_t domain)
[in]domainpointer to the cs_domain_t structure to summarize
◆ cs_f_domain_initialize_cdo_systems()
void cs_f_domain_initialize_cdo_systems ( void  )
◆ cs_f_domain_setup_init_model_context()
void cs_f_domain_setup_init_model_context ( void  )
