7.3
cs_cdo_system.h
1 #ifndef __CS_CDO_SYSTEM_H__
2 #define __CS_CDO_SYSTEM_H__
5  * Structure and functions used to manipulate elementary structures related to
6  * the definition/usage of linear systems (objects manipulated with this
7  * structure are matrices, matrix strcutures and assemblers, range set and
8  * interface set for parallel synchronization/operations)
9  *============================================================================*/
11 /*
12  This file is part of code_saturne, a general-purpose CFD tool.
13
14  Copyright (C) 1998-2022 EDF S.A.
15
16  This program is free software; you can redistribute it and/or modify it under
17  the terms of the GNU General Public License as published by the Free Software
18  Foundation; either version 2 of the License, or (at your option) any later
19  version.
20
21  This program is distributed in the hope that it will be useful, but WITHOUT
22  ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
23  FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
24  details.
25
26  You should have received a copy of the GNU General Public License along with
27  this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
28  Street, Fifth Floor, Boston, MA 02110-1301, USA.
29 */
30
31 /*----------------------------------------------------------------------------
32  * Local headers
33  *----------------------------------------------------------------------------*/
34
35 #include "cs_cdo_assembly.h"
36 #include "cs_cdo_connect.h"
37 #include "cs_matrix.h"
38 #include "cs_matrix_assembler.h"
39 #include "cs_range_set.h"
46  * Macro definitions
48
50  * Type definitions
52
53 typedef enum {
54
60
82 typedef enum {
83
88
90
92
110 typedef enum {
111
116
118
120
121
122 typedef struct {
123
124  /* If the block is associated to one or several matrices, one keeps
125  * the information about the class of the matrix
126  */
127
129
130  /* An element is for instance a vertex, edge, face or cell */
131
134  int stride;
136  /* Description how is stored the matrix values for this block.
137  *
138  * When stride > 1, there are several options to store the matrix
139  * (all possibilities are not available up to now)
140  *
141  * unrolled: True means that a vector-valued DoF for instance is treated as
142  * a scalar-valued DoF which is three times larger.
143  *
144  * interlaced: True means that a vector-valued DoF is stored as follows:
145  * U0x U0y U0z U1x U1y U1z ... UNx UNy UNz
146  * false means that its representation is as follows:
147  * U0x U1x ... UNx U0y U1y ... UNy U0z U1z ... UNz
148  */
149
150  bool unrolled;
152
154
155
165 typedef struct {
166
167  /*
168  * \var matrix
169  * matrix of the system to solve
170  *
171  * \var matrix_class
172  * class of the matrix
173  *
174  * \var mav
175  * structure to manage the assembly of matrix values
176  *
177  * \var assembly_func
178  * function pointer to operate the assembly stage
179  *
180  * \var slave_assembly_func
181  * function pointer to operate the assembly stage when the system helper
182  * is declared as slave (this is the same for all matrices). Useful for
183  * coupled systems.
184  */
185
190
191  /* The following structures can be shared if the same block configuration
192  is requested */
193
198
200
201
209 typedef struct {
210
211  /*
212  * \var n_matrices
213  * number of matrices to consider
214  *
215  * \var matrices
216  * matrix of the system to solve (the matrix id in the list of matrices
217  * corresponding to the matrix at row i and column j is i*n_matrices+j)
218  *
219  * \var mav_array
220  * array of structures to manage the assembly of matrix values
221  *
222  * \var assembly_func
223  * function pointer to operate the assembly stage (this is the same for
224  * all matrices)
225  *
226  * \var slave_assembly_func
227  * function pointer to operate the assembly stage when the system helper
228  * is declared as slave (this is the same for all matrices)
229  */
230
236
237  /* The two following structures are always shared. They correspond to the
238  scalar-valued version. */
239
242
246
248
257 typedef struct {
258
277
279
280  /* The following structures can be shared if the same block configuration is
281  requested. In this case, shared_structures is set to true. By default,
282  there is no sharing. */
283
287
289
290
298 typedef struct {
299
300  /*
301  * \var matrix
302  * matrix of the system to solve
303  *
304  * \var mav
305  * structure to manage the assembly of matrix values
306  */
307
310
311  /* Private structures */
312
317
319
320
326 typedef struct {
327
328  /* \var info
329  * Set of metadata to describe the block
330  */
331
333
345
346  bool owner;
347
348  int id;
349
357
359
368 typedef struct {
369
406
410
412  cs_real_t *rhs; /* shared */
413  cs_real_t *_rhs; /* private */
415
416  int n_blocks;
418
420
421 /*============================================================================
422  * Public function prototypes
423  *============================================================================*/
424
425 /*----------------------------------------------------------------------------*/
433 /*----------------------------------------------------------------------------*/
434
435 void
437  cs_cdo_connect_t *connect);
438
439 /*----------------------------------------------------------------------------*/
452 /*----------------------------------------------------------------------------*/
453
456  int n_col_blocks,
457  const cs_lnum_t *col_block_sizes,
458  int n_blocks);
459
460 /*----------------------------------------------------------------------------*/
476 /*----------------------------------------------------------------------------*/
477
480  int block_id,
482  cs_flag_t location,
483  cs_lnum_t n_elements,
484  int stride,
485  bool interlaced,
486  bool unrolled);
487
488 /*----------------------------------------------------------------------------*/
502 /*----------------------------------------------------------------------------*/
503
506  int block_id,
508  cs_flag_t location,
509  cs_lnum_t n_elements,
510  int stride);
511
512 /*----------------------------------------------------------------------------*/
527 /*----------------------------------------------------------------------------*/
528
531  int block_id,
532  const cs_adjacency_t *adjacency,
533  cs_flag_t location,
534  cs_lnum_t n_elements,
535  int stride,
536  bool interlaced);
537
538 /*----------------------------------------------------------------------------*/
549 /*----------------------------------------------------------------------------*/
550
553  int block_id,
554  cs_lnum_t n_dofs);
555
556 /*----------------------------------------------------------------------------*/
565 /*----------------------------------------------------------------------------*/
566
569  int block_id);
570
571 /*----------------------------------------------------------------------------*/
585 /*----------------------------------------------------------------------------*/
586
587 cs_matrix_t *
589  int block_id);
590
591 /*----------------------------------------------------------------------------*/
605 /*----------------------------------------------------------------------------*/
606
607 cs_matrix_t *
609  int block_id,
610  int sub_id);
611
612 /*----------------------------------------------------------------------------*/
620 /*----------------------------------------------------------------------------*/
621
622 void
624  int block_id);
625
626 /*----------------------------------------------------------------------------*/
634 /*----------------------------------------------------------------------------*/
635
636 void
638  cs_real_t **p_rhs);
639
640 /*----------------------------------------------------------------------------*/
646 /*----------------------------------------------------------------------------*/
647
648 void
650
651 /*----------------------------------------------------------------------------*/
657 /*----------------------------------------------------------------------------*/
658
659 void
661
662 /*----------------------------------------------------------------------------*/
668 /*----------------------------------------------------------------------------*/
669
670 void
672
673 /*----------------------------------------------------------------------------*/
678 /*----------------------------------------------------------------------------*/
679
680 void
682
683 /*----------------------------------------------------------------------------*/
687 /*----------------------------------------------------------------------------*/
688
689 void
691
692 /*----------------------------------------------------------------------------*/
693
695
696 #endif /* __CS_CDO_SYSTEM_H__ */
void * block_pointer
Definition: cs_cdo_system.h:356
cs_matrix_assembler_t * matrix_assembler
Definition: cs_cdo_system.h:196
void cs_cdo_system_destroy_all(void)
Free all members associated to system helpers.
Definition: cs_cdo_system.c:2165
cs_cdo_system_type_t
Definition: cs_cdo_system.h:53
cs_matrix_t ** matrices
Definition: cs_cdo_system.h:232
cs_interface_set_t * interface_set
Definition: cs_cdo_system.h:195
int n_col_blocks
Definition: cs_cdo_system.h:407
cs_matrix_assembler_values_t * mav
Definition: cs_cdo_system.h:187
cs_real_t ** rhs_array
Definition: cs_cdo_system.h:414
bool unrolled
Definition: cs_cdo_system.h:150
cs_cdo_system_block_t * cs_cdo_system_add_xblock(cs_cdo_system_helper_t *sh, int block_id, cs_lnum_t n_dofs)
Add an external block definition at position "block_id" in the helper structure. Only metadata are se...
Definition: cs_cdo_system.c:1496
void() cs_cdo_assembly_func_t(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise matrix into the global matrix Block or no block versions are handled.
Definition: cs_cdo_assembly.h:72
Definition: cs_cdo_system.h:84
cs_matrix_t * cs_cdo_system_get_matrix(const cs_cdo_system_helper_t *sh, int block_id)
Retrieve the matrix associated to the given block_id. If the type of block is either CS_CDO_SYSTEM_BL...
Definition: cs_cdo_system.c:1632
cs_cdo_system_type_t type
Definition: cs_cdo_system.h:405
cs_range_set_t * range_set
Definition: cs_cdo_system.h:285
cs_cdo_system_block_t ** blocks
Definition: cs_cdo_system.h:417
cs_real_t * _rhs
Definition: cs_cdo_system.h:413
int n_blocks
Definition: cs_cdo_system.h:416
Definition: cs_cdo_system.h:133
Definition: cs_defs.h:512
Definition: cs_cdo_system.h:55
bool shared_structures
Definition: cs_cdo_system.h:284
cs_cdo_assembly_func_t * assembly_func
Definition: cs_cdo_system.h:188
cs_matrix_t * matrix
Definition: cs_cdo_system.h:186
Definition: cs_cdo_system.h:368
Definition: cs_cdo_system.h:85
int stride
Definition: cs_cdo_system.h:134
cs_real_t * _values
Definition: cs_cdo_system.h:276
cs_real_t * values
Definition: cs_cdo_system.h:275
Definition: cs_cdo_system.h:286
void cs_cdo_system_helper_free(cs_cdo_system_helper_t **p_helper)
Free a cs_cdo_system_helper_t structure.
Definition: cs_cdo_system.c:1133
cs_cdo_assembly_func_t * slave_assembly_func
Definition: cs_cdo_system.h:235
Definition: cs_defs.h:322
Definition: cs_matrix.h:110
void cs_cdo_system_allocate_assembly(void)
Initialize shared assembly structures from the existing helper structures.
Definition: cs_cdo_system.c:2108
Definition: cs_mesh.h:85
Definition: cs_cdo_system.h:241
Structure associated to the extended type of block.
Definition: cs_cdo_system.h:298
bool matrix_struct_ownership
Definition: cs_cdo_system.h:243
Structure associated to the unassembled type of block.
Definition: cs_cdo_system.h:257
Definition: cs_cdo_system.h:57
Structure associated to the split type of block.
Definition: cs_cdo_system.h:209
void cs_cdo_system_build_block(cs_cdo_system_helper_t *sh, int block_id)
Build the associated structures for the given system_helper structure If a member is already allocate...
Definition: cs_cdo_system.c:1725
Definition: cs_cdo_system.h:189
Structure associated to the default type of block.
Definition: cs_cdo_system.h:165
Definition: cs_cdo_system.h:115
Definition: cs_cdo_system.h:308
Definition: cs_cdo_system.h:240
cs_cdo_system_block_t * cs_cdo_system_add_sblock(cs_cdo_system_helper_t *sh, int block_id, cs_cdo_system_matrix_class_t matclass, cs_flag_t location, cs_lnum_t n_elements, int stride)
Add a split block definition at position "block_id" in the helper structure. Only metadata are set at...
Definition: cs_cdo_system.c:1277
cs_matrix_structure_t * matrix_structure
Definition: cs_cdo_system.h:316
cs_matrix_t * cs_cdo_system_get_sub_matrix(cs_cdo_system_helper_t *sh, int block_id, int sub_id)
Retrieve the (sub-)matrix associated to a split block with id equal to block_id. sub_id is the id in ...
Definition: cs_cdo_system.c:1684
cs_cdo_system_block_type_t type
Definition: cs_cdo_system.h:344
Definition: cs_cdo_system.h:89
bool interlaced
Definition: cs_cdo_system.h:151
Definition: cs_cdo_system.h:315
cs_lnum_t * max_col_block_sizes
Definition: cs_cdo_system.h:409
cs_cdo_system_matrix_class_t matrix_class
Definition: cs_cdo_system.h:128
Definition: cs_cdo_system.h:313
void cs_cdo_system_init_sharing(cs_mesh_t *mesh, cs_cdo_connect_t *connect)
Allocate and initialize matrix-related structures according to the type of discretization used for th...
Definition: cs_cdo_system.c:1056
Definition: cs_range_set.h:57
int id
Definition: cs_cdo_system.h:348
Definition: cs_cdo_system.h:309
Definition: cs_cdo_system.h:326
void cs_cdo_system_helper_reset(cs_cdo_system_helper_t *sh)
Free matrix and rhs after the solve step.
Definition: cs_cdo_system.c:2043
Definition: cs_cdo_system.h:112
Definition: cs_interface.h:61
cs_lnum_t * col_block_sizes
Definition: cs_cdo_system.h:408
cs_cdo_system_block_t * cs_cdo_system_add_dblock(cs_cdo_system_helper_t *sh, int block_id, cs_cdo_system_matrix_class_t matclass, cs_flag_t location, cs_lnum_t n_elements, int stride, bool interlaced, bool unrolled)
Add an unassembled block definition at position "block_id" in the helper structure Only metadata are ...
Definition: cs_cdo_system.c:1176
Definition: cs_cdo_system.h:87
int n_matrices
Definition: cs_cdo_system.h:231
Definition: cs_defs.h:316
void cs_cdo_system_helper_init_system(cs_cdo_system_helper_t *sh, cs_real_t **p_rhs)
Allocate and initialize the matrix, rhs and the matrix assembler values.
Definition: cs_cdo_system.c:1804
Definition: cs_cdo_system.h:122
cs_cdo_system_helper_t * cs_cdo_system_helper_create(cs_cdo_system_type_t type, int n_col_blocks, const cs_lnum_t *col_block_sizes, int n_blocks)
Create a system_helper structure from its set of metadata. n_col_blocks and n_blocks may differ accor...
Definition: cs_cdo_system.c:1081
type of block composing a (block) matrix
Definition: cs_cdo_system.h:82
Definition: cs_defs.h:513
unsigned short int cs_flag_t
Definition: cs_defs.h:324
Definition: cs_cdo_system.h:234
Definition: cs_cdo_system.h:117
Definition: cs_cdo_system.h:197
bool owner
Definition: cs_cdo_system.h:346
void cs_cdo_system_helper_finalize_assembly(cs_cdo_system_helper_t *sh)
Finalize the assembly after the cellwise building and assembly.
Definition: cs_cdo_system.c:1982
Definition: cs_cdo_system.h:244
Definition: cs_cdo_system.h:113
Definition: cs_cdo_system.h:194
const cs_adjacency_t * adjacency
Definition: cs_cdo_system.h:278
cs_cdo_system_block_info_t info
Definition: cs_cdo_system.h:332
Definition: cs_cdo_system.h:245
cs_flag_t location
Definition: cs_cdo_system.h:132
Definition: cs_cdo_system.h:56
Definition: cs_cdo_system.h:114
Class of matrices to consider.
Definition: cs_cdo_system.h:110
struct _cs_matrix_structure_t cs_matrix_structure_t
Definition: cs_matrix.h:106
Definition: mesh.f90:26
cs_matrix_assembler_values_t ** mav_array
Definition: cs_cdo_system.h:233
cs_real_t * rhs
Definition: cs_cdo_system.h:412
cs_lnum_t full_rhs_size
Definition: cs_cdo_system.h:411
cs_cdo_system_block_t * cs_cdo_system_add_ublock(cs_cdo_system_helper_t *sh, int block_id, const cs_adjacency_t *adjacency, cs_flag_t location, cs_lnum_t n_elements, int stride, bool interlaced)
Definition: cs_cdo_system.c:1408
cs_range_set_t * cs_cdo_system_get_range_set(const cs_cdo_system_helper_t *sh, int block_id)
Retrieve the range set structure associated to the given block_id.
Definition: cs_cdo_system.c:1566
Definition: cs_cdo_system.h:86
Definition: cs_cdo_system.h:314
