7.3
cs_cdoeb_vecteq.h File Reference
#include "cs_cdo_connect.h"
#include "cs_cdo_local.h"
#include "cs_cdoeb_priv.h"
#include "cs_equation_builder.h"
#include "cs_matrix.h"
#include "cs_restart.h"
#include "cs_source_term.h"
#include "cs_time_step.h"
+ Include dependency graph for cs_cdoeb_vecteq.h:
bool cs_cdoeb_vecteq_is_initialized (void)
 Check if the generic structures for building a CDO-Eb scheme are allocated. More...
void cs_cdoeb_vecteq_init_sharing (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
 Allocate work buffers and general structures related to CDO edge-based schemes. Set shared pointers. More...
void cs_cdoeb_vecteq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb)
 Retrieve work buffers used for building a CDO system cellwise in case of scalar-valued edge-based scheme. More...
void cs_cdoeb_vecteq_finalize_sharing (void)
 Free work buffer and general structure related to CDO edge-based schemes. More...
void * cs_cdoeb_vecteq_init_context (const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
 Initialize a cs_cdoeb_vecteq_t structure storing data useful for building and managing such a scheme. More...
void * cs_cdoeb_vecteq_free_context (void *builder)
 Destroy a cs_cdoeb_vecteq_t structure. More...
void cs_cdoeb_vecteq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Set the initial values of the variable field taking into account the boundary conditions. Case of scalar-valued CDO-Eb schemes. More...
void cs_cdoeb_vecteq_solve_steady_state (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build and solve the linear system arising from a scalar steady-state convection/diffusion/reaction equation with a CDO-Eb scheme. One works cellwise and then process to the assembly. More...
void cs_cdoeb_vecteq_current_to_previous (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
void cs_cdoeb_vecteq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
cs_real_tcs_cdoeb_vecteq_get_edge_values (void *context, bool previous)
 Get the values at mesh edges (the DoFs) The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
cs_real_tcs_cdoeb_vecteq_get_cell_values (void *context, bool previous)
 Get the values at mesh cells from a reconstruction of edge values. The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
void cs_cdoeb_vecteq_read_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
void cs_cdoeb_vecteq_write_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
◆ cs_cdoeb_vecteq_current_to_previous()
void cs_cdoeb_vecteq_current_to_previous ( const cs_equation_param_t eqp,
cs_equation_builder_t eqb,
void *  context
[in,out]contextpointer to cs_cdoeb_vecteq_t structure
◆ cs_cdoeb_vecteq_extra_post()
void cs_cdoeb_vecteq_extra_post ( const cs_equation_param_t eqp,
void *  context
◆ cs_cdoeb_vecteq_finalize_sharing()
void cs_cdoeb_vecteq_finalize_sharing ( void  )
◆ cs_cdoeb_vecteq_free_context()
void* cs_cdoeb_vecteq_free_context ( void *  builder)
[in,out]builderpointer to a cs_cdoeb_vecteq_t structure
a NULL pointer
◆ cs_cdoeb_vecteq_get()
void cs_cdoeb_vecteq_get ( cs_cell_sys_t **  csys,
cs_cell_builder_t **  cb
◆ cs_cdoeb_vecteq_get_cell_values()
cs_real_t* cs_cdoeb_vecteq_get_cell_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t (size: n_cells)
◆ cs_cdoeb_vecteq_get_edge_values()
cs_real_t* cs_cdoeb_vecteq_get_edge_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t (size: n_edges)
◆ cs_cdoeb_vecteq_init_context()
void* cs_cdoeb_vecteq_init_context ( const cs_equation_param_t eqp,
int  var_id,
int  bflux_id,
a pointer to a new allocated cs_cdoeb_vecteq_t structure
◆ cs_cdoeb_vecteq_init_sharing()
void cs_cdoeb_vecteq_init_sharing ( const cs_cdo_quantities_t quant,
const cs_time_step_t time_step
◆ cs_cdoeb_vecteq_init_values()
void cs_cdoeb_vecteq_init_values ( cs_real_t  t_eval,
const int  field_id,
const cs_mesh_t mesh,
void *  context
◆ cs_cdoeb_vecteq_is_initialized()
bool cs_cdoeb_vecteq_is_initialized ( void  )
true or false
DOXYGEN_SHOULD_SKIP_THIS
true or false
◆ cs_cdoeb_vecteq_read_restart()
void cs_cdoeb_vecteq_read_restart ( cs_restart_t restart,
const char *  eqname,
void *  scheme_context
◆ cs_cdoeb_vecteq_solve_steady_state()
void cs_cdoeb_vecteq_solve_steady_state ( bool  cur2prev,
const int  field_id,
void *  context
◆ cs_cdoeb_vecteq_write_restart()
void cs_cdoeb_vecteq_write_restart ( cs_restart_t restart,
