Set of parameters specific for solving the Navier-Stokes system with an incremental projection algorithm. More...
#include <cs_navsto_coupling.h>
Data Fields | |
cs_equation_t * | prediction |
cs_equation_t * | correction |
cs_real_t * | div_st |
cs_real_t * | bdy_pressure_incr |
cs_field_t * | predicted_velocity |
All equations are not always created. It depends on the choice of the model
bdy_pressure_incr |
Pressure increment at the boundary. Used as an array to set the boundary condition arising from a Dirichlet on the pressure.
cs_equation_t* correction |
Pressure correction step related to the mass balance equation (scalar-valued)
div_st |
Source term on the correction step stemming from the divergence of the predicted velocity
Predicted velocity field (value of the velocity at cells after the prediction step). This values may not be divergence-free.
cs_equation_t* prediction |
Velocity prediction step related to the momentum balance equation (vector-valued)
