7.2
pointe.f90 File Reference
Module for pointer variables. More...
Data Types
type  pmapper_double_r1
 container for rank 1 double precision array pointer. More...
type  pmapper_double_r2
 container for rank 2 double precision array pointer. More...
type  pmapper_double_r3
 container for rank 3 double precision array pointer. More...
Modules
module  pointe
Functions/Subroutines
subroutine init_aux_arrays (ncelet, nfabor)
subroutine resize_aux_arrays
subroutine finalize_aux_arrays
subroutine init_kpdc
subroutine finalize_kpdc
subroutine init_tsma (nvar)
subroutine finalize_tsma
subroutine init_vcond (nvar, ncelet)
subroutine finalize_vcond
subroutine boundary_conditions_init
subroutine boundary_conditions_finalize
subroutine init_1d_wall_thermal
 Allocate the cs_glob_1d_wall_thermal structure. More...
subroutine porosity_from_scan_init
 Allocate the cs_glob_porosity_from_scan structure. More...
subroutine cs_1d_wall_thermal_get_faces (ifpt1d)
 Return pointer to the ifpt1d array for the 1D wall thermal module. More...
subroutine cs_1d_wall_thermal_get_temp (tppt1d)
 Return pointer to the tppt1d array for the 1D wall thermal module. More...
subroutine cs_f_volume_mass_injection_get_arrays (var_id, ncesmp, icetsm_p, itypsm_p, smacel_p)
 Return pointers to the mass source term arrays. More...
type(c_ptr) function cs_get_b_head_loss ()
 Return C pointer to b_head_loss array. More...
type(c_ptr) function cs_get_cavitation_dgdp_st ()
 Return C pointer to cavitation "dgdpca" array. More...
type(c_ptr) function cs_get_cavitation_gam ()
 Return C pointer to cavitation "gamcav" array. More...
integer, dimension(1), target ivoid1
integer, dimension(1, 1), target ivoid2
double precision, dimension(1), target rvoid1
double precision, dimension(1, 1), target rvoid2
double precision, dimension(1, 1, 1), target rvoid3
integer, dimension(:), pointer, save itypfb
integer, dimension(:), allocatable itrifb
 indirection array allowing to sort the boundary faces according to their boundary condition type itypfb More...
integer, dimension(:), pointer izfppp
 to identify boundary zones associated with boundary faces (specific physics models) More...
integer, dimension(:), allocatable idfstr
 the index of the structure, (idfstr(ifac) where ifac is the index of the face), 0 if the face is not coupled to any structure. More...
integer(c_int), pointer, save nfpt1d
 number of boundary faces which are coupled with a wall 1D thermal module. See the user subroutine cs_user_1d_wall_thermal More...
integer(c_int), pointer, save nfpt1t
 global number of boundary faces which are coupled with a wall 1D thermal module. (ie sum over all ranks of nfpt1d) More...
logical(c_bool), pointer, save compute_porosity_from_scan
 Activate the computation. More...
integer, save ncepdc
integer, dimension(:), allocatable icepdc
double precision, dimension(:,:), allocatable ckupdc
double precision, dimension(:), allocatable, target b_head_loss
 Head loss factor of the fluid outside the domain, between infinity and the entrance (for ifrent boundary type). The default value is 0, dimensionless factor. The user may give a value in cs_user_boundary_conditions in the array rcodcl(ifac, ipr, 2). More...
integer, save ncetsm
integer, dimension(:), allocatable, target icetsm
integer, dimension(:), allocatable izctsm
 zone where a mass source term is imposed. More...
integer, dimension(:,:), allocatable, target itypsm
double precision, dimension(:,:), allocatable, target smacel
double precision, dimension(:), allocatable, target gamcav
 liquid-vapor mass transfer term for cavitating flows and its derivative with respect to pressure More...
double precision, dimension(:), allocatable, target dgdpca
double precision, dimension(:,:), allocatable xref_cond
 reference point for wall condensation, used in forced and mixed convection regimes More...
integer, save ncmast
 number of the ncmast cells in which a condensation source terms is imposed. See lstmast list and the subroutine cs_user_metal_structures_source_terms More...
integer, dimension(:), allocatable ltmast
 list on the ncmast cells in which a condensation source terms is imposed. See the user subroutine cs_user_metal_structures_source_terms. More...
integer, dimension(:), allocatable izmast
 zone type where a condensation source terms is imposed to model the metal structures condensation on a volumic zone. More...
integer, dimension(:,:), allocatable itypst
 type of condensation source terms for each variable More...
double precision, dimension(:,:), allocatable svcond
 value of the condensation source terms for pressure associated to the metal structures modelling. For the other variables, eventual imposed specific value. See the user subroutine cs_user_metal_structures_source_terms. More...
double precision, dimension(:), allocatable flxmst
 value of the thermal flux for the condensation model associated to the metal structures modelling. See the user subroutine cs_user_metal_structures_source_terms. More...
double precision, dimension(:,:), pointer, save tslagr
