void | cs_syr_coupling_define (const char *syrthes_name, const char *boundary_criteria, const char *volume_criteria, char projection_axis, bool allow_nonmatching, float tolerance, int verbosity, int visualization) |
| Define new SYRTHES coupling. More...
void | cs_syr_coupling_add_zone (const char *syrthes_name, const cs_zone_t *z) |
| Associated a zone to a defined SYRTHES coupling. More...
void | cs_syr_coupling_all_init (void) |
void | cs_syr_coupling_all_finalize (void) |
int | cs_syr_coupling_n_couplings (void) |
void | cs_syr_coupling_set_conservativity (int flag) |
void | cs_syr_coupling_set_explicit_treatment (void) |
void | cs_syr_coupling_log_setup (void) |
| Log SYRTHES coupling setup information. More...
void | cs_syr_coupling_init_meshes (void) |
| Create coupled meshes and setup PLE locator for Syrthes couplings. More...
int | cs_syr_coupling_is_surf (int cpl_id) |
| Check if the given SYRTHES coupling number is a surface couplings. More...
void | cs_syr_coupling_recv_boundary (int nvar, int bc_type[], int icodcl[], cs_real_t rcodcl[]) |
| Read boundary field/variable values relative to a SYRTHES coupling. More...
void | cs_syr_coupling_send_boundary (const cs_real_t h_wall[], cs_real_t v_fluid[]) |
| Send field/variable values relative to a SYRTHES coupling. More...
void | cs_syr_coupling_exchange_volume (void) |
| Exchange volume values relative to a SYRTHES coupling. More...
void | cs_syr_coupling_volume_source_terms (int field_id, cs_real_t st_exp[], cs_real_t st_imp[]) |
| Compute the source term (implicit and/or explicit part) for a volume coupling with SYRTHES. More...
cs_lnum_t | cs_syr_coupling_n_elts (int cpl_id, int mode) |
| Get number of coupled elements with SYRTHES. More...
void | cs_syr_coupling_elt_ids (int cpl_id, int mode, cs_lnum_t elt_ids[]) |
| Get local ids of elements coupled with SYRTHES. More...
void | cs_syr_coupling_recv_tsolid (int cpl_id, int mode, cs_real_t t_solid[]) |
| Receive coupling variables from SYRTHES. More...
void | cs_syr_coupling_send_tf_hf (int cpl_id, int mode, const cs_lnum_t elt_ids[], cs_real_t t_fluid[], cs_real_t h_fluid[]) |
| Send coupling variables to SYRTHES. More...
void cs_syr_coupling_define |
const char * |
syrthes_name, |
const char * |
boundary_criteria, |
const char * |
volume_criteria, |
char |
projection_axis, |
bool |
allow_nonmatching, |
float |
tolerance, |
int |
verbosity, |
int |
visualization |
- Parameters
[in] | syrthes_name | matching SYRTHES application name |
[in] | boundary_criteria | surface selection criteria, or NULL |
[in] | volume_criteria | volume selection criteria, or NULL |
[in] | projection_axis | x', 'y', or 'y' for 2D projection axis (case independent), or ' ' for standard 3D coupling |
[in] | allow_nonmatching | allow nearest-neighbor mapping where matching within tolerance is not available (useful when meshes have a different level of detail) |
[in] | tolerance | addition to local extents of each element extent = base_extent * (1 + tolerance) |
[in] | verbosity | verbosity level |
[in] | visualization | visualization output level (0 or 1) |
In the case of a single code_saturne and single SYRTHES instance, the 'syrthes_name' argument is ignored, as there is only one matching possibility.
In case of multiple couplings, a coupling will be matched with available SYRTHES instances based on the 'syrthes_name' argument.
