| cs_saddle_block_precond_t * | cs_saddle_block_precond_create (cs_param_precond_block_t block_type, cs_param_schur_approx_t schur_type, cs_param_sles_t *m11_slesp, cs_sles_t *m11_sles) |
| | Create and initialize a cs_saddle_block_precond_t structure. More...
| void | cs_saddle_block_precond_free (cs_saddle_block_precond_t **p_sbp) |
| | Free a cs_saddle_block_precond_t structure. More...
| void | cs_saddle_minres (cs_saddle_system_t *ssys, cs_saddle_block_precond_t *sbp, cs_real_t *x1, cs_real_t *x2, cs_iter_algo_t *ia) |
| | Apply the MINRES algorithm to a saddle point problem (the system is stored in a hybrid way). Please refer to cs_saddle_system_t structure definition. The stride is equal to 1 for the matrix (db_size[3] = 1) and the vector. More...
| void | cs_saddle_gcr (int restart, cs_saddle_system_t *ssys, cs_saddle_block_precond_t *sbp, cs_real_t *x1, cs_real_t *x2, cs_iter_algo_t *ia) |
| | Apply the GCR algorithm to a saddle point problem (the system is stored in a hybrid way). Please refer to cs_saddle_system_t structure definition. The stride is equal to 1 for the matrix (db_size[3] = 1) and the vector. This algorithm is taken from 2010 Notay's paper: "An aggregation-based algebraic multigrid method" ETNA (vol. 37) More...
| void | cs_matrix_vector_multiply_gs_allocated (const cs_range_set_t *rset, const cs_matrix_t *mat, cs_real_t *vec, cs_real_t *matvec) |
| | Perform a matrix-vector multiplication in case of scatter-view array as input parameter. Thus, one performs a scatter –> gather (before the multiplication) and a gather –> scatter operation after the multiplication. One assumes that matvec is allocated to the right size. No check is done. More...
| void | cs_matrix_vector_multiply_gs (const cs_range_set_t *rset, const cs_matrix_t *mat, cs_lnum_t vec_len, cs_real_t *vec, cs_real_t **p_matvec) |
| | Perform a matrix-vector multiplication in case of scatter-view array as input parameter. Thus, one performs a scatter –> gather (before the multiplication) and a gather –> scatter operation after the multiplication. The output parameter matvec is not allocated. A check on the size is done for the input array. More...
◆ cs_matrix_vector_multiply_gs()
- Parameters
| [in] | rset | pointer to a cs_range_set_t structure |
| [in] | mat | matrix |
| [in] | vec_len | size of vec |
| [in,out] | vec | vector of real numbers |
| [out] | matvec | resulting vector for the matrix-vector product |
◆ cs_matrix_vector_multiply_gs_allocated()
- Parameters
| [in,out] | vec | vector |
| [in,out] | matvec | resulting vector for the matrix-vector product |
◆ cs_saddle_block_precond_create()
- Parameters
| [in] | block_type | type of block preconditioner |
| [in] | schur_type | type of Schur approximation |
| [in] | m11_slesp | pointer to the settings for the M11 block |
| [in] | m11_sles | pointer to the cs_sles_t struct. for the M11 block |
- Returns
- a pointer to the new allocated strcuture
◆ cs_saddle_block_precond_free()
◆ cs_saddle_gcr()
- Parameters
| [in] | restart | number of iterations before restarting |
| [in] | ssys | pointer to a cs_saddle_system_t structure |
| [in] | sbp | block-preconditioner for the Saddle-point problem |
| [in,out] | x1 | array for the first part |
| [in,out] | x2 | array for the second part |
| [in,out] | ia | pointer to a cs_iter_algo_t structure |
◆ cs_saddle_minres()
- Parameters
| [in] | sbp | Block-preconditioner for the Saddle-point problem |
