Include dependency graph for cs_renumber.h:Go to the source code of this file.
Enumerations | |
| enum | cs_renumber_cells_type_t { CS_RENUMBER_CELLS_SCOTCH_PART, CS_RENUMBER_CELLS_SCOTCH_ORDER, CS_RENUMBER_CELLS_METIS_PART, CS_RENUMBER_CELLS_METIS_ORDER, CS_RENUMBER_CELLS_MORTON, CS_RENUMBER_CELLS_HILBERT, CS_RENUMBER_CELLS_RCM, CS_RENUMBER_CELLS_NONE } |
| Cell renumbering algorithm types. More... | |
| enum | cs_renumber_i_faces_type_t { CS_RENUMBER_I_FACES_BLOCK, CS_RENUMBER_I_FACES_MULTIPASS, CS_RENUMBER_I_FACES_SIMD, CS_RENUMBER_I_FACES_NONE } |
| Interior faces renumbering algorithm types. More... | |
| enum | cs_renumber_b_faces_type_t { CS_RENUMBER_B_FACES_THREAD, CS_RENUMBER_B_FACES_SIMD, CS_RENUMBER_B_FACES_NONE } |
| Boundary faces renumbering algorithm types. More... | |
| enum | cs_renumber_vertices_type_t { CS_RENUMBER_VERTICES_BY_CELL_ADJ, CS_RENUMBER_VERTICES_BY_FACE_ADJ, CS_RENUMBER_VERTICES_NONE } |
| Vertices renumbering algorithm types. More... | |
| enum | cs_renumber_ordering_t { CS_RENUMBER_ADJACENT_LOW, CS_RENUMBER_ADJACENT_HIGH } |
| Ordering options for adjacency arrays. More... | |
| void | cs_renumber_set_n_threads (int n_threads) |
| Set the target number of threads for mesh renumbering. More... | |
| int | cs_renumber_get_n_threads (void) |
| Return the target number of threads for mesh renumbering. More... | |
| void | cs_renumber_set_min_subset_size (cs_lnum_t min_i_subset_size, cs_lnum_t min_b_subset_size) |
| Set the minimum sunset sizes when renumbering for threads. More... | |
| void | cs_renumber_get_min_subset_size (cs_lnum_t *min_i_subset_size, cs_lnum_t *min_b_subset_size) |
| Get the minimum sunset sizes when renumbering for threads. More... | |
| void | cs_renumber_set_algorithm (bool halo_adjacent_cells_last, bool halo_adjacent_faces_last, cs_renumber_ordering_t i_faces_base_ordering, cs_renumber_cells_type_t cells_pre_numbering, cs_renumber_cells_type_t cells_numbering, cs_renumber_i_faces_type_t i_faces_numbering, cs_renumber_b_faces_type_t b_faces_numbering, cs_renumber_vertices_type_t vertices_numbering) |
| Select the algorithm for mesh renumbering. More... | |
| void | cs_renumber_get_algorithm (bool *halo_adjacent_cells_last, bool *halo_adjacent_faces_last, cs_renumber_ordering_t *i_faces_base_ordering, cs_renumber_cells_type_t *cells_pre_numbering, cs_renumber_cells_type_t *cells_numbering, cs_renumber_i_faces_type_t *i_faces_numbering, cs_renumber_b_faces_type_t *b_faces_numbering, cs_renumber_vertices_type_t *vertices_numbering) |
| Return the algorithms for mesh renumbering. More... | |
| void | cs_renumber_mesh (cs_mesh_t *mesh) |
| Renumber mesh elements for vectorization or threading depending on code options and target machine. More... | |
| void | cs_renumber_cells (cs_mesh_t *mesh) |
| Renumber cells depending on code options and target machine. More... | |
| void | cs_renumber_i_faces (cs_mesh_t *mesh) |
| Renumber interior faces for vectorization or threading depending on code options and target machine. More... | |
| void | cs_renumber_i_faces_by_gnum (cs_mesh_t *mesh) |
| void | cs_renumber_b_faces (cs_mesh_t *mesh) |
| Renumber boundary faces for vectorization or threading depending on code options and target machine. More... | |
| void | cs_renumber_b_faces_by_gnum (cs_mesh_t *mesh) |
| void | cs_renumber_b_faces_select_ignore (cs_mesh_t *mesh, cs_lnum_t n_faces, const cs_lnum_t face_ids[]) |
| Renumber boundary faces such that selected faces appear last and will be ignored. More... | |
| void | cs_renumber_vertices (cs_mesh_t *mesh) |
| Renumber vertices depending on code options and target machine. More... | |
| void cs_renumber_b_faces | ( | cs_mesh_t * | mesh | ) |
parameters: mesh <-> pointer to global mesh structure
| [in,out] | mesh | pointer to global mesh structure |
| void cs_renumber_b_faces_by_gnum | ( | cs_mesh_t * | mesh | ) |
| void cs_renumber_b_faces_select_ignore | ( | cs_mesh_t * | mesh, |
| cs_lnum_t | n_faces, | ||
| const cs_lnum_t | face_ids[] | ||
Those faces will appear last, and the local number of boundary faces set to the number of remaining faces; The mesh's n_b_faces_all and n_g_b_faces_all allows accessing the full boundary faces list.
| [in] | n_faces | number of selected faces |
| [in] | face_ids | number of selected faces |
| void cs_renumber_cells | ( | cs_mesh_t * | mesh | ) |
| void cs_renumber_get_algorithm | ( | bool * | halo_adjacent_cells_last, |
| bool * | halo_adjacent_faces_last, | ||
| cs_renumber_ordering_t * | i_faces_base_ordering, | ||
| cs_renumber_cells_type_t * | cells_pre_numbering, | ||
| cs_renumber_cells_type_t * | cells_numbering, | ||
| cs_renumber_i_faces_type_t * | i_faces_numbering, | ||
| cs_renumber_b_faces_type_t * | b_faces_numbering, | ||
| cs_renumber_vertices_type_t * | vertices_numbering | ||
Any argument may be passed NULL if this option is not queried.
| [out] | halo_adjacent_cells_last | if true, cells adjacent to ghost cells will be placed last (after pre-numbering) |
| [out] | halo_adjacent_faces_last | if true, interior faces adjacent to ghost cells will be placed last (after pre-numbering) |
| [out] | i_faces_base_ordering | pre-ordering of interior faces by lowest or highest adjacent cell id |
| [out] | cells_pre_numbering | algorithm for cells pre-numbering |
| [out] | cells_numbering | algorithm for cells numbering |
| [out] | i_faces_numbering | algorithm for interior faces numbering |
| [out] | b_faces_numbering | algorithm for boundary faces numbering |
| [out] | vertices_numbering | algorithm for vertices numbering |
| void cs_renumber_get_min_subset_size | ( | cs_lnum_t * | min_i_subset_size, |
| cs_lnum_t * | min_b_subset_size | ||
| [out] | min_i_subset_size | minimum number of interior faces per thread per group, or NULL |
| [out] | min_b_subset_size | minimum number of boundary faces per thread per group, or NULL |
| int cs_renumber_get_n_threads | ( | void | ) |
| void cs_renumber_i_faces | ( | cs_mesh_t * | mesh | ) |
| void cs_renumber_i_faces_by_gnum | ( | cs_mesh_t * | mesh | ) |
| void cs_renumber_mesh | ( | cs_mesh_t * | mesh | ) |
Renumbering cells may also allow improving locality (and favor faces renumbering). It is also possible to place cells connected to ghost cells last, which may be useful to enable computation/communication overlap.
| void cs_renumber_set_algorithm | ( | bool | halo_adjacent_cells_last, |
| bool | halo_adjacent_faces_last, | ||
| cs_renumber_ordering_t | i_faces_base_ordering, | ||
| cs_renumber_cells_type_t | cells_pre_numbering, | ||
| cs_renumber_cells_type_t | cells_numbering, | ||
| cs_renumber_i_faces_type_t | i_faces_numbering, | ||
| cs_renumber_b_faces_type_t | b_faces_numbering, | ||
| cs_renumber_vertices_type_t | vertices_numbering | ||
| [in] | halo_adjacent_cells_last | if true, cells adjacent to ghost cells will be placed last (after pre-numbering) |
| [in] | halo_adjacent_faces_last | if true, interior faces adjacent to ghost cells will be placed last (after pre-numbering) |
| [in] | i_faces_base_ordering | pre-ordering of interior faces by lowest or highest adjacent cell id |
| [in] | cells_pre_numbering | algorithm for cells pre-numbering |
| [in] | cells_numbering | algorithm for cells numbering |
| [in] | i_faces_numbering | algorithm for interior faces numbering |
| [in] | b_faces_numbering | algorithm for boundary faces numbering |
| [in] | vertices_numbering | algorithm for vertices numbering |
| [in] | min_i_subset_size | minimum number of interior faces per thread per group |
| [in] | min_b_subset_size | minimum number of boundary faces per thread per group |
| void cs_renumber_set_n_threads | ( | int | n_threads | ) |
By default, the target number of threads is set to cs_glob_n_threads, but the value may be forced using this function. This is mainly useful for testing purposes.
| [in] | n_threads | target number of threads for mesh numbering |
| void cs_renumber_vertices | ( | cs_mesh_t * | mesh | ) |
