1 #ifndef __CS_PRESSURE_CORRECTION_H__ 2 #define __CS_PRESSURE_CORRECTION_H__ #define restrict
Definition: cs_defs.h:142
bool cs_pressure_correction_cdo_is_activated(void)
Test if pressure solving with CDO is activated.
Definition: cs_pressure_correction.c:3048
cs_real_t * inner_potential_flux
Definition: cs_pressure_correction.h:71
void cs_pressure_correction_cdo_finalize_setup(const cs_domain_t *domain)
Finalize setting-up the pressure increment equation At this stage, numerical settings should be compl...
Definition: cs_pressure_correction.c:3134
cs_field_t * pressure_incr_gradient
Definition: cs_pressure_correction.h:55
Definition: cs_field.h:125
void cs_pressure_correction_cdo_init_setup(void)
Start setting-up the pressure increment equation At this stage, numerical settings should be complete...
Definition: cs_pressure_correction.c:3065
integer, save ncmast
number of the ncmast cells in which a condensation source terms is imposed. See lstmast list and the ...
Definition: pointe.f90:210
cs_equation_t * pressure_incr
Definition: cs_pressure_correction.h:49
void cs_pressure_correction(int iterns, cs_lnum_t nfbpcd, cs_lnum_t ncmast, cs_lnum_t ifbpcd[nfbpcd], cs_lnum_t ltmast[], int isostd[], cs_real_t vel[restrict][3], cs_real_t da_uu[restrict][6], cs_real_t coefav[restrict][3], cs_real_t coefbv[restrict][3][3], cs_real_t coefa_dp[restrict], cs_real_t coefb_dp[restrict], cs_real_t spcond[restrict], cs_real_t svcond[restrict], cs_real_t frcxt[restrict][3], cs_real_t dfrcxt[restrict][3], cs_real_t i_visc[restrict], cs_real_t b_visc[restrict])
Perform the pressure correction step of the Navier-Stokes equations for incompressible or slightly co...
Definition: cs_pressure_correction.c:3283
integer, dimension(:), pointer, save ifbpcd
list on the nfbpcd faces in which a condensation source terms is imposed. See ifbpcd and the user sub...
Definition: cs_nz_condensation.f90:95
void cs_pressure_correction_cdo_activate(void)
Activate the pressure increment solving with CDO.
Definition: cs_pressure_correction.c:2973
integer, dimension(:), allocatable ltmast
list on the ncmast cells in which a condensation source terms is imposed. See the user subroutine cs_...
Definition: pointe.f90:214
Definition: cs_pressure_correction.h:44
void cs_pressure_correction_cdo_destroy_all(void)
Free the main structure related to the pressure correction.
Definition: cs_pressure_correction.c:3209
Definition: cs_defs.h:322
cs_field_t * pressure_gradient
Definition: cs_pressure_correction.h:60
double precision, dimension(:,:), allocatable svcond
value of the condensation source terms for pressure associated to the metal structures modelling...
Definition: pointe.f90:230
void cs_pressure_correction_model_activate(void)
Activate the pressure increment, either FV or CDO.
Definition: cs_pressure_correction.c:3028
Definition: cs_domain.h:140
integer(c_int), pointer, save nfbpcd
Definition: cs_nz_condensation.f90:55
cs_real_t * bdy_potential_flux
Definition: cs_pressure_correction.h:76
cs_real_t * bdy_pressure_incr
Definition: cs_pressure_correction.h:82
Definition: cs_defs.h:316
unsigned short int cs_flag_t
Definition: cs_defs.h:324
double precision, dimension(:,:), pointer, save spcond
Definition: cs_nz_condensation.f90:83
cs_flag_t post_flag
Definition: cs_pressure_correction.h:84
void cs_pressure_correction_fv_activate(void)
Activate the pressure increment solving with Legacy FV.
Definition: cs_pressure_correction.c:2947
cs_real_t * div_st
Definition: cs_pressure_correction.h:66
