7.2
cs_navsto_sles.h
1 #ifndef __CS_NAVSTO_SLES_H__
2 #define __CS_NAVSTO_SLES_H__
5  * Functions to handle SLES structures used during the resolution of the
6  * Navier-Stokes system of equations
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2022 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
29 /*----------------------------------------------------------------------------
30  * Local headers
31  *----------------------------------------------------------------------------*/
32
33 #if defined(HAVE_PETSC)
34 #include <petscksp.h>
35 #endif
36
37 #include "cs_iter_algo.h"
38 #include "cs_navsto_param.h"
39 #include "cs_saddle_itsol.h"
46  * Macro definitions
48
50  * Type definitions
52
54  * User function prototypes
56
57 /*----------------------------------------------------------------------------*/
70 /*----------------------------------------------------------------------------*/
71
72 void
74  cs_saddle_system_t *ssys,
76  cs_real_t *x1,
77  cs_real_t *x2,
79
80 /*============================================================================
81  * Public function prototypes
82  *============================================================================*/
83
84 #if defined(HAVE_PETSC)
85 /*----------------------------------------------------------------------------
86  * \brief Function pointer: setup hook for setting PETSc solver and
87  * preconditioner.
88  * Case of multiplicative block preconditioner for a CG
89  *
90  * \param[in, out] context pointer to optional (untyped) value or structure
91  * \param[in, out] ksp_struct pointer to PETSc KSP context
92  *----------------------------------------------------------------------------*/
93
94 void
95 cs_navsto_sles_amg_block_hook(void *context,
96  void *ksp_struct);
97 #endif
98
99 /*----------------------------------------------------------------------------*/
100
102
103 #endif /* __CS_NAVSTO_SLES_H__ */
void cs_user_navsto_sles_solve(const cs_navsto_param_sles_t *nslesp, cs_saddle_system_t *ssys, cs_saddle_block_precond_t *sbp, cs_real_t *x1, cs_real_t *x2, cs_iter_algo_t *ia)
User-defined algorithm to solve a saddle point problem (the system is stored in a hybrid way)...
Definition: cs_navsto_sles.c:225
Structure storing the parameters for solving the Navier-Stokes system.
Definition: cs_navsto_param.h:476
Definition: cs_field_pointer.h:223
Definition: cs_defs.h:322
Set of common parameters to manage an iterative algorithm.
Definition: cs_iter_algo.h:101
Definition: cs_field_pointer.h:222
Definition: cs_saddle_itsol.h:100
Definition: cs_saddle_itsol.h:60
