Include dependency graph for cs_mesh_quantities.h:Go to the source code of this file.
| struct | cs_mesh_quantities_t |
Macros | |
| #define | CS_BAD_CELLS_WARPED_CORRECTION (1 << 0) |
| #define | CS_BAD_CELLS_REGULARISATION (1 << 1) |
| #define | CS_CELL_FACE_CENTER_CORRECTION (1 << 2) |
| #define | CS_CELL_CENTER_CORRECTION (1 << 3) |
| #define | CS_FACE_DISTANCE_CLIP (1 << 4) |
| #define | CS_FACE_RECONSTRUCTION_CLIP (1 << 5) |
| #define | CS_CELL_VOLUME_RATIO_CORRECTION (1 << 6) |
| #define | CS_FACE_CENTER_REFINE (1 << 7) |
| int | cs_mesh_quantities_cell_cen_choice (int algo_choice) |
| Query or modification of the option for computing cell centers. More... | |
| int | cs_mesh_quantities_face_cog_choice (int algo_choice) |
| Query or modification of the option for computing face centers. More... | |
| cs_mesh_quantities_t * | cs_mesh_quantities_create (void) |
| Create a mesh quantities structure. More... | |
| cs_mesh_quantities_t * | cs_mesh_quantities_destroy (cs_mesh_quantities_t *mq) |
| Destroy a mesh quantities structure. More... | |
| void | cs_mesh_quantities_free_all (cs_mesh_quantities_t *mq) |
| Reset a mesh quantities structure to its empty initial state. More... | |
| void | cs_mesh_quantities_compute_preprocess (const cs_mesh_t *m, cs_mesh_quantities_t *mq) |
| Compute mesh quantities needed for preprocessing. More... | |
| void | cs_mesh_quantities_compute (const cs_mesh_t *m, cs_mesh_quantities_t *mq) |
| Compute mesh quantities. More... | |
| void | cs_mesh_quantities_fluid_compute (const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities) |
| void | cs_mesh_quantities_fluid_vol_reductions (const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities) |
| void | cs_mesh_init_fluid_sections (const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities) |
| void | cs_mesh_quantities_sup_vectors (const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities) |
| void | cs_mesh_quantities_face_normal (const cs_mesh_t *mesh, cs_real_t *p_i_face_normal[], cs_real_t *p_b_face_normal[]) |
| void | cs_mesh_quantities_i_faces (const cs_mesh_t *mesh, cs_real_t *p_i_face_cog[], cs_real_t *p_i_face_normal[]) |
| void | cs_mesh_quantities_b_faces (const cs_mesh_t *mesh, cs_real_t *p_b_face_cog[], cs_real_t *p_b_face_normal[]) |
| void | cs_mesh_quantities_cell_faces_cog (const cs_mesh_t *mesh, const cs_real_t i_face_norm[], const cs_real_t i_face_cog[], const cs_real_t b_face_norm[], const cs_real_t b_face_cog[], cs_real_t cell_cen[]) |
| Compute approximate cells centers as the mean of the given face centers weighted by the associated surfaces. More... | |
| cs_real_t * | cs_mesh_quantities_cell_volume (const cs_mesh_t *mesh) |
| void | cs_mesh_quantities_check_vol (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int allow_error) |
| cs_real_6_t * | cs_mesh_quantities_cell_extents (const cs_mesh_t *m, cs_real_t tolerance) |
| Compute the bounding box for cells. More... | |
| int | cs_mesh_quantities_compute_count (void) |
| void | cs_mesh_quantities_b_thickness_v (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, int n_passes, cs_real_t b_thickness[]) |
| Determine local boundary thickness around each vertex. More... | |
| void | cs_mesh_quantities_b_thickness_f (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, int n_passes, cs_real_t b_thickness[]) |
| Determine local boundary thickness around each boundary face. More... | |
| void | cs_mesh_quantities_log_setup (void) |
| Log mesh quantities options to setup file. More... | |
| void | cs_mesh_quantities_dump (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities) |
| cs_mesh_quantities_t * | cs_glob_mesh_quantities |
| unsigned | cs_glob_mesh_quantities_flag |
| void cs_mesh_init_fluid_sections | ( | const cs_mesh_t * | mesh, |
| cs_mesh_quantities_t * | mesh_quantities | ||
| void cs_mesh_quantities_b_faces | ( | const cs_mesh_t * | mesh, |
| cs_real_t * | p_b_face_cog[], | ||
| cs_real_t * | p_b_face_normal[] | ||
| void cs_mesh_quantities_b_thickness_f | ( | const cs_mesh_t * | m, |
| const cs_mesh_quantities_t * | mq, | ||
| int | n_passes, | ||
| cs_real_t | b_thickness[] | ||
| [in] | m | pointer to mesh structure |
| [in] | mq | pointer to mesh quantities structures. |
| [in] | n_passes | number of optional smoothing passes |
| [out] | b_thickness | thickness for each mesh boundary face |
| void cs_mesh_quantities_b_thickness_v | ( | const cs_mesh_t * | m, |
| [in] | n_passes | number of smoothing passes |
| [out] | b_thickness | thickness for each mesh vertex (0 at non-boundary vertices) |
| int cs_mesh_quantities_cell_cen_choice | ( | int | algo_choice | ) |
| [in] | algo_choice | < 0 : query 0 : computation based on face centers (default) 1 : computation by cell sub-volumes |
| cs_real_6_t* cs_mesh_quantities_cell_extents | ( | const cs_mesh_t * | m, |
| cs_real_t | tolerance | ||
The corresponding array is allocated by this function, and it is the caller's responsability to free it when they are no longer needed.
| [in] | tolerance | addition to local extents of each element: extent = base_extent * (1 + tolerance) |
| void cs_mesh_quantities_cell_faces_cog | ( | const cs_mesh_t * | mesh, |
| const cs_real_t | i_face_norm[], | ||
| const cs_real_t | i_face_cog[], | ||
| const cs_real_t | b_face_norm[], | ||
| const cs_real_t | b_face_cog[], | ||
| cs_real_t | cell_cen[] | ||
n-1 Sum Surf(Fi) G(Fi) i=0 G(C) = --------------------— n-1 Sum Surf(Fi) i=0
| [in] | mesh | pointer to mesh structure |
| [in] | i_face_norm | surface normal of internal faces |
| [in] | i_face_cog | center of gravity of internal faces |
| [in] | b_face_norm | surface normal of border faces |
| [in] | b_face_cog | center of gravity of border faces |
| [out] | cell_cen | cell centers |
| void cs_mesh_quantities_check_vol | ( | const cs_mesh_t * | mesh, |
| const cs_mesh_quantities_t * | mesh_quantities, | ||
| int | allow_error | ||
| void cs_mesh_quantities_compute | ( | const cs_mesh_t * | m, |
| cs_mesh_quantities_t * | mq | ||
| [in,out] | mq | pointer to mesh quantities structures. |
| int cs_mesh_quantities_compute_count | ( | void | ) |
| void cs_mesh_quantities_compute_preprocess | ( | const cs_mesh_t * | m, |
| [in,out] | mq | pointer to mesh quantities structures |
| cs_mesh_quantities_t* cs_mesh_quantities_create | ( | void | ) |
| cs_mesh_quantities_t* cs_mesh_quantities_destroy | ( | cs_mesh_quantities_t * | mq | ) |
| [in] | mq | pointer to mesh quantities structures |
| void cs_mesh_quantities_dump | ( | const cs_mesh_t * | mesh, |
| const cs_mesh_quantities_t * | mesh_quantities | ||
| int cs_mesh_quantities_face_cog_choice | ( | int | algo_choice | ) |
| [in] | algo_choice | < 0 : query 0 : standard computation 1 : use adjustment for volume from versions 1.1 to 5.3 |
| void cs_mesh_quantities_face_normal | ( | const cs_mesh_t * | mesh, |
| cs_real_t * | p_i_face_normal[], | ||
| void cs_mesh_quantities_fluid_compute | ( | const cs_mesh_t * | mesh, |
| void cs_mesh_quantities_fluid_vol_reductions | ( | const cs_mesh_t * | mesh, |
| void cs_mesh_quantities_free_all | ( | cs_mesh_quantities_t * | mq | ) |
| void cs_mesh_quantities_i_faces | ( | const cs_mesh_t * | mesh, |
| cs_real_t * | p_i_face_cog[], | ||
| cs_real_t * | p_i_face_normal[] | ||
| void cs_mesh_quantities_log_setup | ( | void | ) |
| void cs_mesh_quantities_sup_vectors | ( | const cs_mesh_t * | mesh, |
| cs_mesh_quantities_t* cs_glob_mesh_quantities |
| unsigned cs_glob_mesh_quantities_flag |
