#include "cs_defs.h"#include "fvm_periodicity.h"#include "cs_base.h"#include "cs_block_dist.h"#include "cs_interface.h"
Include dependency graph for cs_mesh_builder.h:Go to the source code of this file.
| struct | cs_mesh_builder_t |
| cs_mesh_builder_t * | cs_mesh_builder_create (void) |
| Create an empty mesh builder structure. More... | |
| void | cs_mesh_builder_destroy (cs_mesh_builder_t **mb) |
| Destroy a cs_mesh_builder_t structure. More... | |
| void | cs_mesh_builder_define_block_dist (cs_mesh_builder_t *mb, int rank_id, int n_ranks, int min_rank_step, int min_block_size, cs_gnum_t n_g_cells, cs_gnum_t n_g_faces, cs_gnum_t n_g_vertices) |
| Define block distribution sizes for mesh builder. More... | |
| cs_mesh_builder_t * | cs_glob_mesh_builder |
| cs_mesh_builder_t* cs_mesh_builder_create | ( | void | ) |
| void cs_mesh_builder_define_block_dist | ( | cs_mesh_builder_t * | mb, |
| int | rank_id, | ||
| int | n_ranks, | ||
| int | min_rank_step, | ||
| int | min_block_size, | ||
| cs_gnum_t | n_g_cells, | ||
| cs_gnum_t | n_g_faces, | ||
| cs_gnum_t | n_g_vertices | ||
| [in,out] | mb | pointer to mesh builder to update |
| [in] | rank_id | id of local rank |
| [in] | n_ranks | number of associated ranks |
| [in] | min_rank_step | minimum rank step between blocks |
| [in] | min_block_size | minimum number of entities per block |
| [in] | n_g_cells | global number of cells |
| [in] | n_g_faces | global number of faces |
| [in] | n_g_vertices | global number of vertices |
| void cs_mesh_builder_destroy | ( | cs_mesh_builder_t ** | mb | ) |
| [in,out] | mb | pointer to pointer of structure to destroy |
| cs_mesh_builder_t* cs_glob_mesh_builder |
