Set of functions to handle the management of high-level iterative algorithms such as Uzawa, Golub-Kahan Bi-orthogonalization, block preconditioner or Picard algorithms which incorporates inner iterative solvers. More...
#include "cs_defs.h"#include <float.h>#include <assert.h>#include <string.h>#include <bft_error.h>#include <bft_mem.h>#include <bft_printf.h>#include "cs_parall.h"#include "cs_sdm.h"#include "cs_iter_algo.h"
Include dependency graph for cs_iter_algo.c:Functions | |
| cs_iter_algo_t * | cs_iter_algo_create (cs_iter_algo_param_t param) |
| Create and initialize a new cs_iter_algo_t structure. More... | |
| void | cs_iter_algo_post_check (const char *func_name, const char *eq_name, const char *algo_name, cs_iter_algo_t *ia) |
| Check if something wrong happens during the iterative process after one new iteration. More... | |
| void | cs_iter_algo_update_cvg (cs_iter_algo_t *ia) |
| Update the convergence state and the number of iterations. More... | |
| void | cs_iter_algo_reset_nl (cs_param_nl_algo_t nl_algo_type, cs_iter_algo_t *algo) |
| Reset a cs_iter_algo_t structure in case of a non-linear algorothm. More... | |
| cs_iter_algo_aa_t * | cs_iter_algo_aa_create (cs_iter_algo_param_aa_t aap, cs_lnum_t n_elts) |
| Create a new cs_iter_algo_aa_t structure. More... | |
| cs_iter_algo_param_aa_t | cs_iter_algo_get_anderson_param (cs_iter_algo_t *ia) |
| Retrieve the set of parameters for an Anderson algorithm. More... | |
| void | cs_iter_algo_aa_allocate_arrays (cs_iter_algo_aa_t *aa) |
| Allocate arrays useful for the Anderson acceleration. More... | |
| void | cs_iter_algo_aa_free_arrays (cs_iter_algo_aa_t *aa) |
| Free arrays used during the Anderson acceleration. More... | |
| void | cs_iter_algo_aa_free (cs_iter_algo_t *info) |
| Free a cs_iter_algo_aa_t structure used to manage the Anderson acceleration. More... | |
| void | cs_iter_algo_aa_update (cs_iter_algo_t *ia, cs_real_t *cur_iterate, const cs_real_t *pre_iterate, cs_cdo_blas_dotprod_t *dotprod, cs_cdo_blas_square_norm_t *sqnorm) |
| Apply one more iteration of the Anderson acceleration. More... | |
| void cs_iter_algo_aa_allocate_arrays | ( | cs_iter_algo_aa_t * | aa | ) |
| [in,out] | aa | pointer to the structure managing the Anderson algo. |
| cs_iter_algo_aa_t* cs_iter_algo_aa_create | ( | cs_iter_algo_param_aa_t | aap, |
| cs_lnum_t | n_elts | ||
| [in] | aap | set of parameters for the Anderson acceleration |
| [in] | n_elts | number of elements by direction |
| void cs_iter_algo_aa_free | ( | cs_iter_algo_t * | info | ) |
| [in,out] | info |
| void cs_iter_algo_aa_free_arrays | ( | cs_iter_algo_aa_t * | aa | ) |
| void cs_iter_algo_aa_update | ( | cs_iter_algo_t * | ia, |
| cs_real_t * | cur_iterate, | ||
| const cs_real_t * | pre_iterate, | ||
| cs_cdo_blas_dotprod_t * | dotprod, | ||
| cs_cdo_blas_square_norm_t * | sqnorm | ||
| [in,out] | ia | pointer to a cs_iter_algo_t structure |
| [in,out] | cur_iterate | current iterate |
| [in] | pre_iterate | previous iterate |
| [in] | dotprod | function to compute a dot product |
| [in] | sqnorm | function to compute a square norm |
| cs_iter_algo_t* cs_iter_algo_create | ( | cs_iter_algo_param_t | param | ) |
| [in] | param | main set of parameters driving the iterative algorithm |
| cs_iter_algo_param_aa_t cs_iter_algo_get_anderson_param | ( | cs_iter_algo_t * | ia | ) |
| void cs_iter_algo_post_check | ( | const char * | func_name, |
| const char * | eq_name, | ||
| const char * | algo_name, | ||
| cs_iter_algo_t * | ia | ||
| [in] | func_name | name of the calling function |
| [in] | eq_name | name of the equation being solved |
| [in] | algo_name | name of the iterative algo. used |
| [in] | ia | pointer to the iterative algo. structure |
| void cs_iter_algo_reset_nl | ( | cs_param_nl_algo_t | nl_algo_type, |
| cs_iter_algo_t * | algo | ||
| [in] | type | type of non-linear algorithm |
| [in,out] | algo | pointer to a cs_iter_algo_t |
| void cs_iter_algo_update_cvg | ( | cs_iter_algo_t * | ia | ) |
