#include "cs_defs.h"#include <assert.h>#include <ctype.h>#include <stdlib.h>#include <bft_mem.h>#include "cs_equation_system_param.h"
Include dependency graph for cs_equation_system_param.c:Macros | |
| #define | CS_EQUATION_SYSTEM_PARAM_DBG 0 |
| cs_equation_system_param_t * | cs_equation_system_param_create (const char *name, int block_var_dim) |
| Create and initialize a new cs_equation_system_param_t structure. More... | |
| cs_equation_system_param_t * | cs_equation_system_param_free (cs_equation_system_param_t *sysp) |
| Free a cs_equation_system_param_t structure. More... | |
| void | cs_equation_system_param_log (const cs_equation_system_param_t *sysp) |
| Log the setup gathered in the structure cs_equation_system_param_t. More... | |
| void | cs_equation_system_param_set (cs_equation_system_param_t *sysp, cs_equation_system_key_t key, const char *keyval) |
| Set a parameter related to a keyname in a cs_equation_system_param_t structure. More... | |
| #define CS_EQUATION_SYSTEM_PARAM_DBG 0 |
| cs_equation_system_param_t* cs_equation_system_param_create | ( | const char * | name, |
| int | block_var_dim | ||
| [in] | name | name of system of equations |
| [in] | block_var_dim | dimension of the variable in each block |
| cs_equation_system_param_t* cs_equation_system_param_free | ( | cs_equation_system_param_t * | sysp | ) |
| [in,out] | sysp | pointer to the structure to free |
| void cs_equation_system_param_log | ( | const cs_equation_system_param_t * | sysp | ) |
| [in] | sysp | pointer to a parameter structure to log |
| void cs_equation_system_param_set | ( | cs_equation_system_param_t * | sysp, |
| cs_equation_system_key_t | key, | ||
| const char * | keyval | ||
| [in,out] | sysp | pointer to a parameter structure to set |
