#include "cs_defs.h"#include "cs_advection_field.h"#include "cs_domain.h"#include "cs_equation.h"#include "cs_gwf.h"#include "cs_param_types.h"#include "cs_property.h"
Include dependency graph for cs_domain_setup.h:Go to the source code of this file.
| void | cs_f_domain_setup_init_model_context (void) |
| When the models have been activated, continue to allocate, add and define structures related to those models This function is called after the user function cs_user_model and before the user function cs_user_parameters. More... | |
| void | cs_f_domain_initialize_cdo_systems (void) |
| Initialize CDO systems. More... | |
| void | cs_domain_set_output_param (cs_domain_t *domain, int nt_interval, int nt_list, int verbosity) |
| Set to true the automatic update of all advection fields. More... | |
| void | cs_domain_set_time_param (cs_domain_t *domain, int nt_max, double t_max) |
| Set parameters for unsteady computations: the max number of time steps or the final physical time of the simulation. More... | |
| void | cs_domain_automatic_time_step_settings (cs_domain_t *domain) |
| Set time step parameters for unsteady computations when this is not already done. This situation should occur when the GUI is used to set a constant time step. More... | |
| cs_xdef_t * | cs_domain_def_time_step_by_function (cs_domain_t *domain, cs_time_func_t *func, void *func_input) |
| Define the value of the time step thanks to a predefined function. More... | |
| void | cs_domain_def_time_step_by_value (cs_domain_t *domain, double dt) |
| Define the value of the time step. More... | |
| void | cs_domain_initialize_setup (cs_domain_t *domain) |
| First setup stage of the cs_domain_t structure Define extra domain boundaries Setup predefined equations Create fields (already done in the FV part) Define cs_sles_t structures for variable fields. More... | |
| void | cs_domain_init_cdo_structures (cs_domain_t *domain) |
| After having read the mesh and the first setup stage build the connectivities and mesh quantities related to CDO/HHO schemes. More... | |
| void | cs_domain_finalize_user_setup (cs_domain_t *domain) |
| Last user setup stage of the cs_domain_t structure. More... | |
| void | cs_domain_finalize_module_setup (cs_domain_t *domain) |
| Last setup stage of the cs_domain_t structure. More... | |
| void | cs_domain_initialize_systems (cs_domain_t *domain) |
| Initialize systems of equations and their related field values according to the user settings. More... | |
| void | cs_domain_setup_log (const cs_domain_t *domain) |
| Summary of the main domain settings. More... | |
| void cs_domain_automatic_time_step_settings | ( | cs_domain_t * | domain | ) |
| cs_xdef_t* cs_domain_def_time_step_by_function | ( | cs_domain_t * | domain, |
| cs_time_func_t * | func, | ||
| void * | func_input | ||
| [in] | func | pointer to a cs_time_func_t function |
| [in] | func_input | pointer to a structure cast on-the-fly |
| void cs_domain_def_time_step_by_value | ( | cs_domain_t * | domain, |
| double | dt | ||
| [in] | dt | value of the constant time step |
| void cs_domain_finalize_module_setup | ( | cs_domain_t * | domain | ) |
| [in,out] | domain | pointer to a cs_domain_t struct. |
| void cs_domain_finalize_user_setup | ( | cs_domain_t * | domain | ) |
| void cs_domain_init_cdo_structures | ( | cs_domain_t * | domain | ) |
| void cs_domain_initialize_setup | ( | cs_domain_t * | domain | ) |
| void cs_domain_initialize_systems | ( | cs_domain_t * | domain | ) |
| void cs_domain_set_output_param | ( | cs_domain_t * | domain, |
| int | nt_interval, | ||
| int | nt_list, | ||
| int | verbosity | ||
Set auxiliary parameters related to the way output is done
| [in] | nt_interval | frequency for the restart process |
| [in] | nt_list | output frequency into the log |
| [in] | verbosity | level of information displayed |
| void cs_domain_set_time_param | ( | cs_domain_t * | domain, |
| int | nt_max, | ||
| double | t_max | ||
| [in] | nt_max | max. number of time step iterations |
| [in] | t_max | final physical time of the simulation |
| void cs_domain_setup_log | ( | const cs_domain_t * | domain | ) |
| [in] | domain | pointer to the cs_domain_t structure to summarize |
| void cs_f_domain_initialize_cdo_systems | ( | void | ) |
| void cs_f_domain_setup_init_model_context | ( | void | ) |
