Functions to handle the resolution of the turbulence modelling within the CDO framework. More...
#include "cs_defs.h"#include <assert.h>#include <stdlib.h>#include <string.h>#include <bft_mem.h>#include "cs_post.h"#include "cs_turbulence_model.h"#include "cs_reco.h"#include "cs_cdo_turbulence.h"
Include dependency graph for cs_cdo_turbulence.c:Macros | |
| #define | CS_CDO_TURBULENCE_DBG 0 |
| cs_turbulence_param_t * | cs_turbulence_param_create (void) |
| Allocate the structure storing the set of parameters for the turbulence modelling. More... | |
| cs_turbulence_t * | cs_turbulence_create (cs_turbulence_param_t *tbp) |
| Allocate the structure managing the turbulence modelling. More... | |
| void | cs_turbulence_free (cs_turbulence_t **p_turb_struct) |
| Free the structure managing the turbulence modelling. More... | |
| void | cs_turbulence_init_setup (cs_turbulence_t *tbs, cs_equation_t *mom_eq) |
| Initialize the structure managing the turbulence modelling. More... | |
| void | cs_turbulence_finalize_setup (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs) |
| Finalize the setup of the turbulence modelling and especially the equations/properties and other related quantities. More... | |
| void | cs_turbulence_init_values (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs) |
| Initialize the values of quantities related to a turbulence model. More... | |
| void * | cs_turb_init_k_eps_context (const cs_turb_model_t *tbm) |
| Allocate and initialize the context structure related to the k-epsilon turbulence model. More... | |
| void * | cs_turb_free_k_eps_context (void *tbc) |
| Free the context structure related to the k-epsilon turbulence model. More... | |
| void | cs_turb_update_k_eps (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, const cs_turbulence_t *tbs) |
| Update for the current time step the new state for the turbulence model. This is used to update the turbulent viscosity. More... | |
| void | cs_turb_compute_k_eps (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs) |
| Compute for the current time step the new state for the turbulence model. This means that all related equations are built and then solved. More... | |
| #define CS_CDO_TURBULENCE_DBG 0 |
| void cs_turb_compute_k_eps | ( | const cs_mesh_t * | mesh, |
| cs_turbulence_t * | tbs | ||
| [in] | time_step | structure managing the time stepping |
| [in,out] | tbs | pointer to turbulence structure |
| void* cs_turb_free_k_eps_context | ( | void * | tbc | ) |
| [in,out] | tbc | pointer to a structure context cast on-the-fly |
| void* cs_turb_init_k_eps_context | ( | const cs_turb_model_t * | tbm | ) |
| [in] | tbm | structure which defines the turbulence model |
| void cs_turb_update_k_eps | ( | const cs_mesh_t * | mesh, |
| const cs_turbulence_t * | tbs | ||
| [in] | tbs | pointer to a cs_turbulence_t structure |
| cs_turbulence_t* cs_turbulence_create | ( | cs_turbulence_param_t * | tbp | ) |
| [in] | tbp | pointer to a cs_turbulence_param_t structure |
| void cs_turbulence_finalize_setup | ( | const cs_mesh_t * | mesh, |
| [in,out] | tbs | pointer to the turbulence main structure |
| void cs_turbulence_free | ( | cs_turbulence_t ** | p_turb_struct | ) |
| [in,out] | p_turb_struct | pointer to the structure to free |
| void cs_turbulence_init_setup | ( | cs_turbulence_t * | tbs, |
| cs_equation_t * | mom_eq | ||
| [in,out] | tbs | pointer to the structure to initialize |
| [in] | mom_eq | pointer to the structure mom_eq |
| void cs_turbulence_init_values | ( | const cs_mesh_t * | mesh, |
| cs_turbulence_param_t* cs_turbulence_param_create | ( | void | ) |
