Build discrete advection operators for CDO vertex-based schemes. More...
#include "cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <math.h>#include <float.h>#include <limits.h>#include <assert.h>#include <bft_mem.h>#include "cs_cdo_bc.h"#include "cs_flag.h"#include "cs_property.h"#include "cs_math.h"#include "cs_scheme_geometry.h"#include "cs_cdo_advection.h"
Include dependency graph for cs_cdo_advection.c:Functions | |
| static double | _get_upwind_weight (double criterion) |
| Compute the weight of upwinding for an upwind scheme. More... | |
| static double | _get_samarskii_weight (double criterion) |
| Compute the weight of upwinding for an Samarskii scheme. More... | |
| static double | _get_sg_weight (double criterion) |
| Compute the weight of upwinding for an Sharfetter-Gummel scheme. More... | |
| static _upwind_weight_t * | _assign_weight_func (const cs_param_advection_scheme_t scheme) |
| Retrieve the function related to the kind of upwind weighting. More... | |
| static short int | _set_fquant (const cs_cell_mesh_t *cm, short int e, short int f, const double *tef, double *wvf) |
| Retrieve the face edge id from a given cell edge id. Compute the weights related to each vertex of face from pre-computed quantities. More... | |
| static void | _assemble_face (const cs_cell_mesh_t *cm, const cs_face_mesh_t *fm, const cs_sdm_t *af, cs_sdm_t *ac) |
| Assemble a face matrix into a cell matrix. More... | |
| static void | _build_cell_epcd_upw (const cs_cell_mesh_t *cm, _upwind_weight_t *get_weight, const cs_real_t fluxes[], const cs_real_t upwcoef[], cs_sdm_t *adv) |
| Define the local convection operator between primal vertices and dual faces. (Conservative formulation and Upwind flux) More... | |
| static void | _build_cell_epcd_cen (const cs_cell_mesh_t *cm, const cs_real_t fluxes[], cs_sdm_t *adv) |
| Define the local convection operator between primal vertices and dual faces. (Non-conservative formulation and centered flux) More... | |
| static void | _build_cell_vpfd_upw (const cs_cell_mesh_t *cm, _upwind_weight_t *get_weight, const cs_real_t fluxes[], const cs_real_t upwcoef[], cs_sdm_t *adv) |
| static void | _build_cell_vpfd_cen (const cs_cell_mesh_t *cm, const cs_real_t fluxes[], cs_sdm_t *adv) |
| Define the local convection operator between primal vertices and dual faces. (Conservative formulation and centered flux) More... | |
| static void | _build_cell_vpfd_mcu (const cs_cell_mesh_t *cm, const cs_real_t upwp, const cs_real_t fluxes[], cs_sdm_t *adv) |
| Define the local convection operator between primal vertices and dual faces. (Conservative formulation and mixed centered/upwind) More... | |
| static void | _update_vcb_system_with_bc (const cs_real_t beta_nf, const cs_face_mesh_t *fm, const cs_sdm_t *matf, cs_cell_sys_t *csys) |
| Update the cellwise system with the contributions arising from the boundary conditions. More... | |
| static void | _vcb_cellwise_consistent_part (const cs_nvec3_t adv_cell, const cs_cell_mesh_t *cm, const cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the consistent part of the convection operator attached to a cell with a CDO vertex+cell-based scheme when the advection is considered as constant inside a cell. More... | |
| static void | _vcb_consistent_part (const cs_adv_field_t *adv_field, const cs_nvec3_t adv_cell, const cs_cell_mesh_t *cm, const cs_face_mesh_t *fm, cs_real_t t_eval, cs_cell_builder_t *cb) |
| Compute the consistent part of the convection operator attached to a cell with a CDO vertex+cell-based scheme when the advection field is not considered constant inside the current cell. More... | |
| static void | _vcb_stabilization_part1 (const cs_cell_mesh_t *cm, const cs_face_mesh_t *fm, const double stab_coef, cs_cell_builder_t *cb) |
| Compute the stabilization part of the convection operator attached to a cell with a CDO vertex+cell-based scheme (inside pfc) More... | |
| static void | _vcb_stabilization_part2 (const cs_cell_mesh_t *cm, const double stab_coef, cs_cell_builder_t *cb) |
| Compute the stabilization part of the convection operator attached to a cell with a CDO vertex+cell-based scheme (between pfc) More... | |
| void | cs_cdo_advection_set_cip_coef (double new_value) |
| Set the value of the stabilization coefficient used in CIP scheme. More... | |
| double | cs_cdo_advection_get_cip_coef (void) |
| Get the value of the stabilization coefficient used in CIP scheme. More... | |
| void | cs_cdofb_advection_open_default (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, void *input, cs_cell_builder_t *cb) |
| Perform preprocessing such as the computation of the advection flux at the expected location in order to be able to build the advection matrix. Follow the prototype given by cs_cdofb_adv_open_hook_t Default case. More... | |
| void | cs_cdofb_advection_close_default_scal (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv) |
| Operation done after the matrix related to the advection term has been defined. Follow the prototype given by cs_cdofb_adv_close_hook_t Default scalar-valued case. More... | |
| void | cs_cdofb_advection_close_default_vect (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv) |
| Operation done after the matrix related to the advection term has been defined. Follow the prototype given by cs_cdofb_adv_close_hook_t Default vector-valued case. More... | |
| void | cs_cdofb_advection_close_exp_none_scal (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv) |
| Operation done after the matrix related to the advection term has been defined. Follow the prototype given by cs_cdofb_adv_close_hook_t Explicit treatment without extrapolation for scalar-valued DoFs. More... | |
| void | cs_cdofb_advection_close_exp_none_vect (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv) |
| Operation done after the matrix related to the advection term has been defined. Follow the prototype given by cs_cdofb_adv_close_hook_t Explicit treatment without extrapolation for vector-valued DoFs. More... | |
| void | cs_cdofb_advection_no_diffusion (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cdofb_adv_scheme_t *scheme_func, cs_cell_builder_t *cb) |
| Build the cellwise advection operator for CDO-Fb schemes The local matrix related to this operator is stored in cb->loc. More... | |
| void | cs_cdofb_advection (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cdofb_adv_scheme_t *scheme_func, cs_cell_builder_t *cb) |
| Main function to build the cellwise advection operator for CDO face-based schemes. The local matrix related to this operator is stored in cb->loc. More... | |
| void | cs_cdofb_advection_upwnoc (int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv) |
| Compute the convection operator attached to a cell with a CDO face-based scheme. More... | |
| void | cs_cdofb_advection_upwcsv (int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv) |
| void | cs_cdofb_advection_cennoc (int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv) |
| void | cs_cdofb_advection_cencsv (int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv) |
| void | cs_cdo_advection_vb_upwcsv_wpty (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme with an upwind scheme and a conservative formulation. The portion of upwinding relies on an evaluation of the weigth associated to the given property The local matrix related to this operator is stored in cb->loc Predefined prototype to match the function pointer cs_cdovb_advection_t. More... | |
| void | cs_cdo_advection_vb_upwcsv (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme without diffusion and an upwind scheme and a conservative formulation is used. The local matrix related to this operator is stored in cb->loc Predefined prototype to match the function pointer cs_cdovb_advection_t. More... | |
| void | cs_cdo_advection_vb_cencsv (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme when a centered scheme and a conservative formulation is used. The local matrix related to this operator is stored in cb->loc Predefined prototype to match the function pointer cs_cdovb_advection_t. More... | |
| void | cs_cdo_advection_vb_mcucsv (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme when a mixed centered/upwind scheme with a conservative formulation is used. The local matrix related to this operator is stored in cb->loc Predefined prototype to match the function pointer cs_cdovb_advection_t. More... | |
| void | cs_cdo_advection_vb_upwnoc_wpty (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme with an upwind scheme and a conservative formulation. The portion of upwinding relies on an evaluation of the weigth associated to the given property. The local matrix related to this operator is stored in cb->loc Predefined prototype to match the function pointer cs_cdovb_advection_t. More... | |
| void | cs_cdo_advection_vb_upwnoc (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme without diffusion when an upwind scheme and a conservative formulation is used. The local matrix related to this operator is stored in cb->loc Predefined prototype to match the function pointer cs_cdovb_advection_t. More... | |
| void | cs_cdo_advection_vb_cennoc (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme when a centered scheme and a non-conservative formulation is used. The local matrix related to this operator is stored in cb->loc Predefined prototype to match the function pointer cs_cdovb_advection_t. More... | |
| void | cs_cdo_advection_vcb_cw_cst (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex+cell-based scheme when the advection field is cellwise constant. More... | |
| void | cs_cdo_advection_vcb (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex+cell-based scheme. More... | |
| void | cs_cdo_advection_vb_bc (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Compute the BC contribution for the convection operator. More... | |
| void | cs_cdo_advection_vcb_bc (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Compute the BC contribution for the convection operator with CDO V+C schemes. More... | |
| void | cs_cdo_advection_cell_upwind_coef (const cs_cdo_quantities_t *cdoq, cs_param_advection_scheme_t scheme, cs_real_t coefval[]) |
| Compute the value of the upwinding coefficient in each cell knowing the related Peclet number. More... | |
static |
| [in] | fm | pointer to a cs_face_mesh_t structure |
| [in] | af | pointer to a cs_sdm_t structure related to a face |
| [in,out] | ac | pointer to a cs_sdm_t structure related to a cell |
inlinestatic |
| [in] | scheme | scheme used for discretizing the advection term |
static |
| [in] | fluxes | array of fluxes on dual faces |
| [in,out] | adv | pointer to a cs_sdm_t structure |
static |
| [in] | get_weight | pointer to a function for evaluating upw. weight |
| [in] | upwcoef | array of coefficient to the weight the upwinding |
static |
static |
| [in] | upwp | portion of upwinding to apply |
static |
inlinestatic |
| [in] | criterion | dot product between advection and normal vectors or estimation of a local Peclet number |
inlinestatic |
inlinestatic |
inlinestatic |
| [in] | e | edge id in the cell numbering |
| [in] | f | face id in the cell numbering |
| [in] | tef | value of the area of the triangles tef |
| [in,out] | wvf | weights of vertices for the current face |
static |
| [in] | beta_nf | advection field coefficient |
| [in] | matf | pointer to a local dense matrix related to a face |
static |
| [in] | adv_cell | constant vector field inside the current cell |
static |
| [in] | adv_field | pointer to a cs_adv_field_t structure |
| [in] | t_eval | time at which one evaluates the advection field |
static |
| [in] | stab_coef | default value of the stabilization coefficient |
static |
| [in] | stab_coef | value of the stabilization coefficient |
| void cs_cdo_advection_cell_upwind_coef | ( | const cs_cdo_quantities_t * | cdoq, |
| cs_param_advection_scheme_t | scheme, | ||
| cs_real_t | coefval[] | ||
| [in] | cdoq | pointer to the cdo quantities structure |
| [in] | scheme | type of scheme used for the advection term |
| [in,out] | coefval | pointer to the pointer of real numbers to fill in: Peclet number in each cell out: value of the upwind coefficient |
| double cs_cdo_advection_get_cip_coef | ( | void | ) |
| void cs_cdo_advection_set_cip_coef | ( | double | new_value | ) |
(DOXYGEN_SHOULD_SKIP_THIS)
| [in] | new_value | value of the stabilization coefficient |
| void cs_cdo_advection_vb_bc | ( | const cs_cell_mesh_t * | cm, |
| cs_real_t | t_eval, | ||
| cs_face_mesh_t * | fm, | ||
| cs_cell_sys_t * | csys | ||
| [in,out] | fm | pointer to a cs_face_mesh_t structure |
| [in,out] | cb | pointer to a convection builder structure |
| [in,out] | csys | cell-wise structure storing the local system |
| void cs_cdo_advection_vb_cencsv | ( | const cs_equation_param_t * | eqp, |
| const cs_property_data_t * | diff_pty, | ||
| [in] | diff_pty | pointer to a cs_property_data_t structure |
| void cs_cdo_advection_vb_cennoc | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vb_mcucsv | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vb_upwcsv | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vb_upwcsv_wpty | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vb_upwnoc | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vb_upwnoc_wpty | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vcb | ( | const cs_equation_param_t * | eqp, |
| [in] | diff_pty | pointer to the property associated to diffusion |
| void cs_cdo_advection_vcb_bc | ( | const cs_cell_mesh_t * | cm, |
| void cs_cdo_advection_vcb_cw_cst | ( | const cs_equation_param_t * | eqp, |
| void cs_cdofb_advection | ( | const cs_equation_param_t * | eqp, |
| cs_cdofb_adv_scheme_t * | scheme_func, | ||
One assumes that a diffusion term is present so that there is no need to perform additional checkings on the well-posedness of the operator.
| [in] | scheme_func | pointer to the function building the system |
| void cs_cdofb_advection_cencsv | ( | int | dim, |
| cs_sdm_t * | adv | ||
A scalar-valued version is built. Only the enforcement of the boundary condition depends on the variable dimension. Remark: Usually the local matrix called hereafter adv is stored in cb->loc
| [in] | dim | dimension of the variable (1 or 3) |
| [in] | cb | pointer to a cs_cell_builder_t structure |
| [in,out] | adv | pointer to a local matrix to build |
| void cs_cdofb_advection_cennoc | ( | int | dim, |
| void cs_cdofb_advection_close_default_scal | ( | const cs_equation_param_t * | eqp, |
| [in,out] | adv | pointer to the local advection matrix |
| void cs_cdofb_advection_close_default_vect | ( | const cs_equation_param_t * | eqp, |
| void cs_cdofb_advection_close_exp_none_scal | ( | const cs_equation_param_t * | eqp, |
| void cs_cdofb_advection_close_exp_none_vect | ( | const cs_equation_param_t * | eqp, |
| void cs_cdofb_advection_no_diffusion | ( | const cs_equation_param_t * | eqp, |
Main function to build the cellwise advection operator for CDO-Fb schemes The local matrix related to this operator is stored in cb->loc.
Case of an advection term without a diffusion operator. In this situation, a numerical issue may arise if an internal or a border face is such that there is no advective flux. A specil treatment is performed to tackle this issue.
| void cs_cdofb_advection_open_default | ( | const cs_equation_param_t * | eqp, |
| void * | input, | ||
| [in,out] | input | NULL or pointer to a structure cast on-the-fly |
| void cs_cdofb_advection_upwcsv | ( | int | dim, |
| void cs_cdofb_advection_upwnoc | ( | int | dim, |
