7.1
cs_wall_functions_t Struct Reference
wall functions descriptor. More...
#include <cs_wall_functions.h>
+ Collaboration diagram for cs_wall_functions_t:
Data Fields
cs_wall_f_type_t iwallf
cs_wall_f_s_type_t iwalfs
double ypluli
Members of this wall functions descriptor are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
Field Documentation
◆ iwalfs
iwalfs
wall functions for scalar
  • CS_WALL_F_S_ARPACI_LARSEN: three layers (Arpaci and Larsen) or two layers (Prandtl-Taylor) for Prandtl number smaller than 0.1
  • CS_WALL_F_S_VDRIEST: consistant with the 2 scales wall function for velocity using Van Driest mixing length
  • CS_WALL_F_S_LOUIS: default wall function for atmospheric flows for potential temperature. This has influence on the dynamic.
  • CS_WALL_F_S_MONIN_OBUKHOV: Monin Obukhov wall function for atmospheric flows for potential temperature. This has influence on the dynamic.
◆ iwallf
iwallf
Indicates the type of wall function used for the velocity boundary conditions on a frictional wall.
  • CS_WALL_F_DISABLED: no wall functions
  • CS_WALL_F_1SCALE_POWER: one scale of friction velocities (power law)
  • CS_WALL_F_1SCALE_LOG: one scale of friction velocities (log law)
  • CS_WALL_F_2SCALES_LOG: two scales of friction velocities (log law)
  • CS_WALL_F_SCALABLE_2SCALES_LOG: two scales of friction velocities (log law) (scalable wall functions)
  • CS_WALL_F_2SCALES_VDRIEST: two scales of friction velocities (mixing length based on V. Driest analysis)
  • CS_WALL_F_2SCALES_SMOOTH_ROUGH: wall function unifying rough and smooth friction regimes
  • CS_WALL_F_2SCALES_CONTINUOUS: All $ y^+ $ for low Reynolds models
    iwallf is initialised to CS_WALL_F_1SCALE_LOG for iturb = 10, 40, 41 or 70 (mixing length, LES and Spalart Allmaras).
    iwallf is initialised to CS_WALL_F_DISABLED for iturb = 0, 32, 50 or 51
    iwallf is initialised to CS_WALL_F_2SCALES_LOG for iturb = 20, 21, 30, 31 or 60 ( $k-\epsilon$, $R_{ij}-\epsilon$ LRR, $R_{ij}-\epsilon$ SSG and $k-\omega$ SST models).
    The v2f model (iturb=50) is not designed to use wall functions (the mesh must be low Reynolds).
    The value iwallf = CS_WALL_F_2SCALES_LOG is not compatible with iturb=0, 10, 40 or 41 (laminar, mixing length and LES).
    Concerning the $k-\epsilon$ and $R_{ij}-\epsilon$ models, the two-scales model is usually at least as satisfactory as the one-scale model.
    The scalable wall function allows to virtually shift the wall when necessary in order to be always in a logarithmic layer. It is used to make up for the problems related to the use of High-Reynolds models on very refined meshes.
    Useful if iturb is different from 50.
◆ ypluli
ypluli
limit value of $y^+$ for the viscous sublayer
ypluli depends on the chosen wall function: it is initialized to 10.88 for the scalable wall function (iwallf=CS_WALL_F_SCALABLE_2SCALES_LOG), otherwise it is initialized to $1/\kappa\approx 2,38$. In LES, ypluli is taken by default to be 10.88. Always useful.
