(cs_user_zones.c)
Volume and boundary zones may be defined using the GUI, or through the cs_user_zones (in cs_user_zones.c).
Simple volume zone example
Most zones may be defined in a simple manner using the general selection criteria, such as in the following example:
"box[4.0, 6.0, -1e6, 2.0, 8.0, 1e6]",
Or you can define 3 spherical source term zones based on geometrical criteria described by a rule.
char name[128], criteria[128];
for (int i = 0; i < 3; i++) {
double s_coords[] = {0, 0, 2.0*i};
snprintf(name, 127, "source_%d", i);
snprintf(criteria, 127, "sphere[%f, %f, %f, 0.5]",
s_coords[0], s_coords[1], s_coords[2]);
Advanced volume zone examples
More complex selections can be done by defining an appropriate selection function. For example, to select cells adjacent to boundary faces belonging to a group named "G3", the following selection function must first be defined:
static void
_g3_boundary_cells(void *input,
int location_id,
char *cell_flag;
cell_flag[i] = 0;
cell_flag[c_id] = 1;
if (cell_flag[i] != 0)
_n_elts++;
_n_elts = 0;
if (cell_flag[i] != 0) {
_elt_ids[_n_elts] = i;
_n_elts++;
*n_elts = _n_elts;
*elt_ids = _elt_ids;
It can then simply be used in a zone definition:
Advanced boundary zone examples
You can define simple boundary zones, allowing all faces not in the "INLET" or "OUTLET" groups to be considered as walls
Or simply allow overlapping for an existing zone:
