7.1
Further reading
Build and Tool chain
Different parts of the code_saturne tool chain are built with different programming languages and libraries.
  • Build system based on GNU autotools: autoconf, automake, libtool
    • Requires optional sh shell and m4 macro languages, some make file syntax, some Python code.
  • GUI and scripts (TUI): Python, PyQt.
  • Preprocessor: C compiler (C99 or above)
    • Optional mesh format libraries: MED, CGNS, libCCMIO (see install guide for details).
  • Solver: C and Fortran compilers (C11 or above, Fortran 2003 or above.
    • Multiple optional external libraries: MPI, PT-SCOTCH, MED, CGNS, Catalyst, CoolProp, PETSc, and others (see install guide for details)
Recommended learning material
Depending on the part of the code one is working on, further reading and training may be useful.
For the Git source code management system:
Fortran programming
C programming
C and Fortran basics
A very brief comparison of equivalent C and Fortran Syntax is provided here, which may be useful for those already familiar with one or the other.
C Fortran
Basic types
char
_Bool, bool
int
float
double
character
logical
integer
real
double precision
Basic math functions
(a)cos (a)sin (a)tan
cosh sinh tanh
exp log
sqrt pow(x, y)
abs fabs
(a)dcos(a)dsin(a)dtan
dcosh dsinh dtanh
dexp dlog
sqrt x**y
iabs dabs
mod(a,b)
Logical expressions
.and. .or. .not.
.lt. .gt. .le. .ge. .eq. .ne.
.eqv. .neqv.
Function/subroutine call
x = f(y);
g(a);
x = f(y)
call g(a)
Conditional
if (expr) {
operations;
if (expr) then
operations
end if
Simple loops
for (i = 0; i < n; i++) {
y /= 2.;
z = x + i + y*5.;
do i = 0, n
y = y/2.d0
z = x + i + y*5.d0
end do
Complex loops
while (expr) {
operations
do while (expr)
operations
end do
Loop control
if (ignore_condition)
continue;
else if (exit_loop_condition)
break;
do i = 0, n
cycle;
exit;
end do
Variable declaration and initialization
int i, j,
k = 0, l = 1;
double a = 1.;
integer :: i, j, &
k = 0, l = 1
double precision :: a = 1.d0
Array declaration and initialization
int tab[2][3] = {{1, 2, 3},
{4, 5, 6}};
printf("%d", tab[1][0]); // 4
integer, dimension(3,2) :: tab
data / 1, 2, 3, 4, 5, 6 /
write(*,*) tab(2, 1) ! 2
An important difference to be aware of between C and Fortran is that when calling functions, C passes arguments by copy (so changing argument values in C has not effect unless that argument is a pointer or array (see following sections), while in Fortran, variables are passed by reference, allowing their modification directly.
C language
C variable declarations
A variable may be initialized upon its declaration:
double a[4] = {1, 2, 3, 4};
double b[] = {1, 2, 3, 4};
double matrix[3][4] = {{1., 0., 0., 0.},
{0., 1., 0., 0.},
{0., 0., 1., 0.}};
static int call_id = 0; /* static C equivalent
to Fortran save */
const double pi = 4.*atan(1.), e = exp(1);
In Fortran, initialization with declaration implies save attribute, so the following are equivalent:
integer :: i = 4
integer, save :: i = 4
C Types and Structures
C allows defining additional types, as well as structures.
  • typedef double cs_real_t defines a cs_real_t type identical to double
  • typedef cs_real_t cs_real_3_t[3] defines a cs_real_3_t type identical to an array of 3 cs_real_t types
    • indirectly equivalent to an array of 3 double types
  • code_saturne makes use of this to define additional types (see especially cs_defs.h and integer type descriptions
  • the _t postfix is a convention, which is recognized by some text editors (such as Emacs) for syntax coloring.
Pointers and arrays
Understanding pointers is essential in C
  • In any language, variables are stored in memory.
  • C allows access not only to a variable's value, but to its memory location (based on its memory model; this is usually a logical, not physical address)
    • A pointer is a variable referencing another variable's memory location.
    • In C, some operations cannot be done without handling pointers.
  • For a given type, prefixing * to the variable's declaration declares it as a pointer to a variable of that type
  • For a pointer, prefixing * to the pointer's name dereferences a pointer (that is accesses the value pointed to)
  • Prefixing & to a variable obtains a reference (pointer) to that variable.
A simple example is best:
double x;
double a = 1.0, b = 2.0; // variables
double *p = NULL;
p = &a; // p points to a
x = *p; // x now has a's value
p = &b; // p points to b
*p = 12; // b's value is now 12.
Note that pointers in other languages (especially Fortran) are often more restrictive, or include additional metadata.
  • Pointers in C are simply a memory address.
  • Associated type information (used for pointer arithmetic and checks) is defined in the source code and managed by the compiler, not stored in the pointer (i.e. no runtime introspection)
C Pointers and arrays
  • Array syntax may be used with pointers.
  • Pointer "arithmetic" is based on the pointer's type (unless void).
  • A single (but important) difference between pointers and arrays:
    • An array declaration implies local memory allocation, a pointer does not.
    • This is reflected by the different behavior of the sizeof
  • In addition to the following example, check the tutorial at: https://boredzo.org/pointers/
double x;
double a[3] = {1.0, 2.0, 3.0};
double *p = a; // p points to beginning of a
x = *p; // same as a[0]
x = p[0]; // same as a[0]
x = p[2]; // same as a[2]
p[1] *= 2; // a[1] *= 2
p++; // point to next value
x = *p; // same as a[1]
Remarks on pointers
Character strings do not have a dedicated type in C:
  • Strings are simply arrays or pointers to characters.
  • Strings end when a character with code 0 (\0) is encountered
Pointers may be cast from one type to another. For example:
int a[3][3] = {{11, 12, 13},
{21, 22, 23},
{31, 32, 33}};
int *p = (int *)a;
const int *q = (const int *)a;
C structures
We will refer to other sources to detail usage of structures in code_saturne, focusing here on specific aspects.
  • Some structures are defined directly in a header (.h) file
    typedef struct {
    int n; /* number of elements */
    double *val; /* list of element values */
    } cs_simple_struct_t;
    • Such structures may be used normally, with full access to members from any file including the header
  • Other structures are defined in in a source (.c) file
    typedef struct _cs_opaque_t {
    with a matching entry in a header (.h) file
    typedef struct _cs_opaque_t cs_opaque_t;
    • Such structures may be used normally inside the source file, but their members are hidden from within other files.
    • This allows protecting structure members, ensuring they are only accessed from within the associated module
    • If the file is large and needs to be split, we place the definition in a separate header file, accessed only from a restricted set of files (see for example src/base/cs_matrix*.h).
Using opaque structures has advantages:
  • It conveys the information to most users that they can use the structure without worrying about its internals
  • Structure internals can be modified without breaking compatibility (changing access functions
It also has some disadvantages:
  • Access is more cumbersome, requiring functions.
  • Due to function call overheads, many calls to simple functions in a loop are more costly than direct access, or than a function which loops internally
C storage class specifiers
A variable declaration can be combined with a {storage class specifier}.
  • static indicates the variable is "permanent":
    • Its values are saved from one call to the next, like save in Fortran
  • extern indicates we reference a variable, but its memory location is not defined here; for example:
    • int option = 2; in a single (owning) .c file.
    • extern int option; in a .h or other .c file. This ensures the variable is accessible from multiple files, but defined in a single location.
    • For global variables, avoids conflicts (bugs) due to multiple copies
  • auto is the default, so no point in specifying it.
  • register recommends to keep an often-used variable in a register
    • Very fast, very small memory; the compiler does what it can / wants
  • volatile indicates the variable may be modified by concurrent thread
    • Reload from memory, not from cache.
C const attribute
A variable declaration may specify one or more const attributes.
  • A const attribute indicates the function may not modify this variable
    • For a pointer, be careful where const is placed:
      const double a[]; /* cannot modify
      content of a */
      const double *b; /* same with b */
      double *const c; /* can not modify pointer
      to c, but can modify
      content pointed to */
      const double *const c; /* can modify neither pointer
      nor content */
C const attribute
  • As variables are passed by copy, some constructs are not very useful.
  • For example, inline int f(const int *const t) and inline int f(const int *t) are equivalent from the caller's side.
    • Only in the function body, the first syntax indicates we cannot locally modify the pointer to t.
    • Compilers allow mixing the first syntax in the body with one or the other in the prototype.
      • Proof if needed that for the caller, it is all the same.
    • From a readability standpoint, we prefer the second syntax, as it is less cluttered.
      • There may still be relics of the first syntax in code_saturne, especially in src/gui; choose more recent code examples, such as cs_field.c;
    • It is strongly recommended to use const as much as possible
    • It is more or less equivalent to intent(in) in Fortran, and can allow detecting unintentional variable modifications at compile time.
C restrict attribute
A variable declaration may also be qualified with a restrict attribute.
  • The restrict attribute indicates that no other pointer refers to the same content.
  • For example, with int f(double *restrict a, double *restrict b), we tell the compiler that arrays a and b do not overlap.
    • Allows a better optimization, possibly vectorisation.
    • Most performance differences between C and Fortran are due to aliasing (forbidden in Fortran, assumed by default in C).
    • C strict aliasing rules: between different types double and int for example, aliasing is automatically forbidden.
  • This is useful only to help optimization of costly loops
    • If we forget to use this, we may lose some performance
    • If we incorrectly declare a variable restrict, we may have undefined behavior...
      • In Fortran, passing the same array (or overlapping arrays) twice as function arguments may also lead to similar behavior...
C functions
Like most programming languages, C allows grouping statements in functions.
  • A function definition is composed of a header and a body.
    • The header describes the return type, the function name, and function arguments. if no value is returned or the function has no arguments, void is used to indicate this.
    • A function body contains the actual instructions of the function
  • The following example function returns the dot product of 2 arrays
    double f(int n, double x[], double y[])
    int i;
    double r = 0;
    r = r + x[i]*y[i];
    return r;
  • Modern C strongly recommends functions be described by a prototype (i.e. interface), declared before defining or calling functions.
    • C++ requires this absolutely.
    • A function prototype resembles its header, ended by a semicolon (;).
  • For the previous example, the matching prototype is:
    double f(int n, double x[], double y[]);
  • Only parameter types are required to match in the definition and prototype, so compilers will not complain if names are different
    • But the code maintainers will !
    • And the documentation generator will emit warnings
Prototypes are usually grouped in header files, inserted locally using the #include preprocessor directive.
  • If the static qualifier is prefixed to a function declaration, that function is defined locally only
    • In this case, prototypes are not necessary (functions referenced by others must appear first).
    • Functions with the same name may be used in different files with no risk.
  • Using static inline, the function body is copied at each call
    • Avoids call overhead for short functions, leads to larger code.
    • inline without static is tricky: see a more complete C course, or avoid it.
  • In code_saturne, some simple computation functions are defined as static inline;
    • Their definition appear in header (.h) files in this case
    • See for example cs_math.h.
  • In code_saturne, many low-level functions are defined as static
    • When they are only needed locally, this avoids cluttering the Doxygen documentation with low-level functions
    • This also allows using shorter names, without worrying about cs_<module>_ "namespace" issues.
      • As per static (i.e. file-local) global variables, we simply prefix the names of those functions with an underscore: _
    • As those functions do not require prototypes, they are defined at the beginning of the file; if function b calls function a, then a must be defined first.
    • If such functions may become useful elsewhere, it is best to make them non-static (i.e. global), move them in the file, and add a prototype rather than to adopt a copy-paste programming style...
  • A function is called by providing its name and arguments
    r = f(3, x, y); // returns r
    g(x); // returns no value
    s = h(); // takes no argument
  • A function returning a value is equivalent to a Fortran function, and a function returning void to a Fortran subroutine.
  • In C, functions pass arguments by value.
    • Item array contents, or values referenced by pointers may be modified normally
    • Non-pointer (or array) arguments are copied, so the original is unchanged in the calling code
  • In Fortran, functions and subroutines pass arguments by reference.
    • Unless otherwise specified (using for example integer, value :: n)
    • Values modified in the function are still after its return.
Example of call by value semantics:
/* callee function */
void f(double x, double y[2]) {
x = x/2;
y[1] = x;
/* caller function */
void g(void) {
double x = 10, y[] = {1., 2.}; /* initialization */
f(x, y); /* call to f */
/* now x = 10, y[] = {1., 5.} */
C function pointers
Generic functions may be called using function pointers
  • Don't be intimidated by the name
    • Some users don't even realize they are using function pointers.
  • In practical terms, function pointers allow passing a function as an argument to a function
  • To illustrate this, let us look at the examples in cs_post.h and in cs_user_postprocess.c.
    • ... not so hard, is it now ?
Memory management
Explicit memory allocation operations return pointers
  • Using the malloc, realloc, and free functions or similar
  • Explicit allocation as described above is usually done on a memory area called the heap, which is a large, usually extensible memory area.
    • If memory is allocated but never freed, memory "leaks" then possibly runs out
    • Use Valgrind, the GCC and Clang AddressSanitizer tools, or export CS_MEM_LOG=mem_log in your environment to check for this.
  • Automatic allocation of variables and fixed-size arrays is done on a smaller memory area called the stack
    • Does not incurr any overhead (fast).
    • Automatically freed when variable goes out of scope.
    • Overwrites on the stack may crash even your debugger...
      • they also may crash Valgrind, but can be detected with the AddressSanitizer tools.
C Preprocessing
Before the C compilation proper, a first stage replaces character sequences based on several rules.
  • It is called the preprocessor
  • Directives start with #
    • #include, #if, #ifdef, #ifndef, #define,
Allows defining macros
  • Using a common coding convention, we write them in capitals.
#define CS_MIN(a,b) ((a) < (b) ? (a) : (b))
  • No need for ; at the end of the line (or statement).
Do not define macros if another solution is possible
  • Avoid arguments with side effects; for example, CS_MIN(f(x),g(x)) calls either f(x) or g(x) twice...
Some macros are predefined; to know them, the solution is compiler dependent. With gcc, the following command is useful: gcc -dM -E - < /dev/null
  • One of the main uses of the preprocessor is conditional compilation
#if defined (HAVE_MPI)
#endif
  • To disable code containing comments, nothing beats: ```{.c} #if 0 ... #endif ```
    • This avoids comment nesting issues, and some editors such as vim even colorize the block as a comment.
C Preprocessor macros in code_saturne
  • code_saturne defines several preprocessor macros, among which the following:
  • Note: the C language also defines double fmax(double x, double y) and double fmaxf(float x, float y);
    • They do not have multiple macro argument evaluation side effects
    • They are applicable only to double or float values, though automatic type casting in C allows use of either (with a different precision).
    • Applying them to integers would lead to non-natural rounding and overflow behavior.
Preprocessors in various programming languages
Preprocessors do not exist in all "modern" languages, are often decried by purists, but are very useful in C and C++ for optional library support.
  • in Python, not missed, as we can use try...import sequences
  • Almost all Fortran compilers allow for the use of the C preprocessor, or a slightly adapted version of it (fpp)
    • The Fortran 95 standard suggested (as an optional appendix) a conditional compilation mechanism, named coco (conditional compilation)
      • Very few compilers support it
      • As always, before trying to follow a standard, check how well it is supported
      • In this specific case, a tool less powerful the the C preprocessor was invented, 15 or so years later; it is not surprising it failed
      • coco was recently retired from the latest Fortran standards, so it can be safely forgotten.
C variable and function scoping
Compared to Fortran, variables may have a local scope:
int f(int n, double x[]) {
int i;
i = 6;
int i, j; /* i masks previous definition */
for (i = 0, j = 1; i < n; i++, j+= rand())
x[i] += j;
/* i = 6 again */
int j; /* the previous definition is unknown here ! */
for (j = 0; j < n; j++)
x[j] += 1.;
Advantages and precautions:
  • Avoid multiple definitions of a variable on different levels
    • Check for compiler warnings: definition shadows previous definition
  • Local definitions may improve readability.
  • Local definitions ensure variables are local (and thus automatically private) in OpenMP sections.
Since the C99 standard, variables may be defined in a function body, or even in a control structure:
int i;
i = 6;
for (int j = 0; j < n; j++)
x[j] += 1.;
x[j] += 1.;
printf("value of j: %d\n", j); /* error, j not
defined here */
The C scoping rules also allow definition of global variables.
  • Declaring a variable in a source file outside a function makes it global
    • It is recommended to add an initialization to the declaration when possible, which is safer and simple than requiring additional initialization functions
  • Adding the static qualifier makes that variable accessible only from the file in which it is declared.
    • Another similar variable in another file would be completely independent.
  • If global visibility is desired, the definition should be unique, and the variable defined using the the extern qualifier.
  • An extern const qualifier may be used to make the variable read only.
    • Useful for pointers to structures, allowing safe reading of structure members, but modification only though a specific function (see the handling of cs_glob_time_step in src/base/cs_glob_time_step.c src/base/cs_glob_time_step.h for example).
Main global variables in code_saturne
  • In code_saturne, we try to minimize the use of global variables, but a few are used, as placing them in a structure would be cumbersome for C/Fortran interoperability.
(int) cs_glob_n_ranks // cs_defs.h
(int) cs_glob_rank_id // cs_defs.h
(cs_matrix_t} cs_glob_matrix_default // cs_matrix.h
(cs_matrix_structure_t} cs_glob_matrix_default_struct
(cs_mesh_t) cs_glob_mesh // cs_mesh.h
(cs_time_step_t) cs_glob_time_step // cs_time_step.h
(cs_field_pointer_val_t) cs_glob_field_pointers // ...
C Undefined behavior
Some ambiguous constructions lead to what is called unspecified behavior.
  • The compiler is free to do whatever it wants in such cases.
    • different compilers may exhibit different behaviors
    • Avoid at all costs, but in general, there is nothing to worry about as long as the code's conventions are followed.
  • Example: incorrect character string usage
    char *p = "Code_Saturne"; // forbidden in C++11,
    // obsolete in C++98/C++03
    p[0] = 'C'; // undefined behavior due to above
    // (but works with most compilers)
  • Correct character string usage
    char p[] = "Code_Saturne"; // array, not just pointer
    p[0] = 'C'; // OK
  • Example: division by zero
    int x = 1;
    return x/0; // undefined behavior
  • Example: out of bounds array access
    • this detected by Address Sanitizer, but not by Valgrind: as arr is declared as a local array, it is instanciated on the stack, not the heap.
      int arr[4] = {0, 1, 2, 3};
      int j = arr[5]; // stack buffer overflow
  • Example: out of scope return value
    *double badarray(void) {
    double t[] = {0, 1, 2};
    return t; // memory location freed on return
  • Example: undefined (or not always defined) return value
    • Very easy to avoid, as current compilers emit a warning.
    • You check compiler warnings, of course ?
      int
      f(int x)
      if (x < 1) {
      return -x;
      } /* undefined behavior if x >= 1 */
  • Example: incrementation before/after use (note 84) C11 standard?
    printf("%d %d\n",
    ++n, pow(2, n)); /* is n incremented
    before or after
    calling power ? */
    i = ++i + 1;
    a[i++] = i; /* is i incremented before or
    after assignment ?*/
    /* The constructs below are safe: */
    i = i + 1;
    a[i] = i;
    a[i++] = j;
  • Rule of thumb: to be safe, avoid incrementation operators on an index which appears multiple times in an expression.
C Pragmas
Another type of element may start with a #, but is not related to the preprocessor: pragmas
  • #pragma omp ... for optional thread/task parallelism using the OpenMP model
  • #pragma disjoint(<variable list) for directives specific to optimizations using the IBM XL compilers (at least in older versions); in most cases, the restrict keyword is a more portable alternative
  • #pragma GCC ... for directives specific to GCC
The most frequent pragmas in code_saturne are related to OpenMP parallelism
  • They are used only if this programming model is activated
In a general manner, a pragma not known to a given compiler is ignored
C Decorators
In a few rare places, we use decorators
  • In the following example, the __attribute__ decorator is used to specify that the function behaves like printf regarding its arguments, so as to benefit from compiler argument checking
    #if defined(__GNUC__)
    int
    bft_printf(const char *const format,
    __attribute__((format(printf, 1, 2)));
    #else
    int
    #endif
Various decorators exist, but we do not use them much in code_saturne, as they are not portable.
