#include "cs_cdo_connect.h"#include "cs_cdo_quantities.h"#include "cs_mesh.h"#include "cs_quadrature.h"#include "cs_xdef.h"
Include dependency graph for cs_xdef_eval.h:Go to the source code of this file.
| typedef void() | cs_xdef_eval_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) More... | |
| void | cs_xdef_eval_scalar_by_val (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a scalar-valued quantity for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_vector_by_val (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a vector-valued quantity for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_symtens_by_val (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a tensor-valued quantity for a list of elements with symmetric storage. This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_tensor_by_val (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a tensor-valued quantity for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_scalar_at_cells_by_time_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a scalar-valued quantity with only a time-dependent variation for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_vector_at_cells_by_time_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a vector-valued quantity with only a time-dependent variation for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_symtens_at_cells_by_time_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a tensor-valued quantity with a symmetric storage and with only a time-dependent variation for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_tensor_at_cells_by_time_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a tensor-valued quantity with only a time-dependent variation for a list of elements This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_at_cells_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity defined at cells using an analytic function This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_at_b_faces_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity defined at border faces using an analytic function This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_at_vertices_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity defined at vertices using an analytic function This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_at_cells_by_dof_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity defined at primal cells using a function associated to dof (dof = degrees of freedom). This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_at_vertices_by_dof_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity defined at vertices using a function associated to dof (dof = degrees of freedom). This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_at_b_faces_by_dof_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity defined at boundary faces using a function associated to dof (dof = degrees of freedom). This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_scalar_at_cells_by_array (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a scalar-valued quantity at cells defined by an array. Array is assumed to be interlaced. This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_nd_at_cells_by_array (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a nd-valued quantity at cells defined by an array. Array is assumed to be interlaced. This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_at_vertices_by_array (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity defined at vertices using an array This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_cell_by_field (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity inside a cell defined using a field This function complies with the generic function type defined as cs_xdef_eval_t. More... | |
| void | cs_xdef_eval_avg_at_b_faces_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, int dim, cs_real_t *eval) |
| Evaluate a quantity defined at border faces using an analytic function. More... | |
| typedef void() cs_xdef_eval_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval) |
| [in] | elt_ids | list of element ids |
| [in] | dense_output | perform an indirection for output (true/false) |
| [in] | context | NULL or pointer to a context structure |
| [in,out] | eval | array storing the result (must be allocated) |
| void cs_xdef_eval_at_b_faces_by_analytic | ( | cs_lnum_t | n_elts, |
| bool | dense_output, | ||
| cs_real_t | time_eval, | ||
| void * | context, | ||
| cs_real_t * | eval | ||
| void cs_xdef_eval_at_b_faces_by_dof_func | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_at_cells_by_analytic | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_at_cells_by_dof_func | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_at_vertices_by_analytic | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_at_vertices_by_array | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_at_vertices_by_dof_func | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_avg_at_b_faces_by_analytic | ( | cs_lnum_t | n_elts, |
| cs_quadrature_type_t | qtype, | ||
| int | dim, | ||
| [in] | qtype | quadrature type |
| [in] | dim | dimension of the analytic function return |
| void cs_xdef_eval_cell_by_field | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_nd_at_cells_by_array | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_scalar_at_cells_by_array | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_scalar_at_cells_by_time_func | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_scalar_by_val | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_symtens_at_cells_by_time_func | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_symtens_by_val | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_tensor_at_cells_by_time_func | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_tensor_by_val | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_vector_at_cells_by_time_func | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_vector_by_val | ( | cs_lnum_t | n_elts, |
