Functions to handle extended definitions of quantities thanks to the cs_xdef_t structures. More...
#include <stdlib.h>#include <stdio.h>#include <string.h>#include <assert.h>#include "bft_mem.h"#include "cs_field.h"#include "cs_flag.h"#include "cs_log.h"#include "cs_mesh_location.h"#include "cs_xdef.h"
Include dependency graph for cs_xdef.c:Macros | |
| #define | CS_XDEF_DBG 0 |
| cs_xdef_t * | cs_xdef_volume_create (cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *context) |
| Allocate and initialize a new cs_xdef_t structure based on volumic elements. More... | |
| cs_xdef_t * | cs_xdef_boundary_create (cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *context) |
| Allocate and initialize a new cs_xdef_t structure based on boundary elements. More... | |
| cs_xdef_t * | cs_xdef_timestep_create (cs_xdef_type_t type, cs_flag_t state, cs_flag_t meta, void *context) |
| Allocate and initialize a new cs_xdef_t structure for setting the time step. More... | |
| cs_xdef_t * | cs_xdef_free (cs_xdef_t *d) |
| Free a cs_xdef_t structure. More... | |
| cs_xdef_t * | cs_xdef_copy (cs_xdef_t *src) |
| copy a cs_xdef_t structure More... | |
| void | cs_xdef_set_input_context (cs_xdef_t *d, void *input) |
| In the case of a definition by an analytic function, a time function or a function relying on degrees of freedom (DoFs), this function allows one to set a more or less complex input data structure. This call should be done before the first evaluation call of the associated cs_xdef_t structure. More... | |
| void | cs_xdef_set_free_input_function (cs_xdef_t *d, cs_xdef_free_input_t *free_input) |
| In case of a definition by an analytic function, a time function or a function relying on degrees of freedom (DoFs). One can set a function to free a complex input data structure (please refer to cs_xdef_free_input_t) for more details. More... | |
| void | cs_xdef_set_array (cs_xdef_t *d, bool is_owner, cs_real_t *array) |
| In case of definition by array, set the array after having added this definition. More... | |
| void | cs_xdef_set_array_index (cs_xdef_t *d, cs_lnum_t *array_index) |
| In case of definition by array, set the index to get access to the array values. More... | |
| void | cs_xdef_set_quadrature (cs_xdef_t *d, cs_quadrature_type_t qtype) |
| Set the type of quadrature to use for evaluating the given description. More... | |
| cs_quadrature_type_t | cs_xdef_get_quadrature (cs_xdef_t *d) |
| Get the type of quadrature to use for evaluating the given description. More... | |
| cs_xdef_type_t | cs_xdef_get_type (const cs_xdef_t *d) |
| Retrieve the flag dedicated to the state. More... | |
| cs_flag_t | cs_xdef_get_state_flag (const cs_xdef_t *d) |
| void | cs_xdef_log (const char *prefix, const cs_xdef_t *d) |
| Output the settings related to a cs_xdef_t structure. More... | |
| const char * | cs_xdef_type_get_name (cs_xdef_type_t xdef_type) |
| Retrieve a pointer to the cs_xdef_type's name string. More... | |
| #define CS_XDEF_DBG 0 |
| cs_xdef_t* cs_xdef_boundary_create | ( | cs_xdef_type_t | type, |
| int | dim, | ||
| int | z_id, | ||
| cs_flag_t | state, | ||
| cs_flag_t | meta, | ||
| void * | context | ||
| [in] | type | type of definition |
| [in] | dim | dimension of the values to define |
| [in] | z_id | volume zone id |
| [in] | state | flag to know if this uniform, cellwise, steady... |
| [in] | meta | metadata associated to this description |
| [in] | context | pointer to a structure |
| cs_quadrature_type_t cs_xdef_get_quadrature | ( | cs_xdef_t * | d | ) |
| [in] | d | pointer to a cs_xdef_t structure |
| cs_xdef_type_t cs_xdef_get_type | ( | const cs_xdef_t * | d | ) |
| void cs_xdef_log | ( | const char * | prefix, |
| const cs_xdef_t * | d | ||
| [in,out] | d | pointer to a cs_xdef_t structure |
| [in] | is_owner | manage or not the lifecycle of the array values |
| [in] | array | values |
| [in] | array_index | index on array values |
| void cs_xdef_set_free_input_function | ( | cs_xdef_t * | d, |
| cs_xdef_free_input_t * | free_input | ||
| [in] | free_input | pointer to a function which free the input structure |
| void cs_xdef_set_input_context | ( | cs_xdef_t * | d, |
| void * | input | ||
| [in] | input | pointer to an input structure |
| void cs_xdef_set_quadrature | ( | cs_xdef_t * | d, |
| cs_quadrature_type_t | qtype | ||
| [in] | qtype | type of quadrature |
| cs_xdef_t* cs_xdef_timestep_create | ( | cs_xdef_type_t | type, |
| [in] | context | pointer to a structure storing the parameters (cast on-the-fly according to the type of definition) |
| const char* cs_xdef_type_get_name | ( | cs_xdef_type_t | xdef_type | ) |
| [in] | xdef_type | type to query |
| cs_xdef_t* cs_xdef_volume_create | ( | cs_xdef_type_t | type, |
| int | dim, | ||
| int | z_id, | ||
