7.1
cs_user_lagr_particle.c File Reference
#include <limits.h>
#include <stddef.h>
#include <ctype.h>
#include <float.h>
#include "cs_headers.h"
+ Include dependency graph for cs_user_lagr_particle.c:
void cs_user_lagr_ef (cs_real_t dt_p, const cs_real_t taup[], const cs_real_3_t tlag[], const cs_real_3_t piil[], const cs_real_33_t bx[], const cs_real_t tsfext[], const cs_real_33_t vagaus[], const cs_real_3_t gradpr[], const cs_real_33_t gradvf[], cs_real_t rho_p[], cs_real_3_t fextla[])
 User definition of an external force field acting on the particles. More...
void cs_user_lagr_extra_operations (const cs_real_t dt[])
 User function (non-mandatory intervention) More...
void cs_user_lagr_imposed_motion (const cs_real_t coords[3], cs_real_t dt, cs_real_t disp[3])
 Impose the motion of a particle flagged CS_LAGR_PART_IMPOSED_MOTION. More...
void cs_user_lagr_in (cs_lagr_particle_set_t *particles, const cs_lagr_injection_set_t *zis, const cs_lnum_t particle_range[2], const cs_lnum_t particle_face_id[], const cs_real_t visc_length[])
 User modification of newly injected particles. More...
void cs_user_lagr_rt (cs_lnum_t id_p, cs_real_t re_p, cs_real_t uvwr, cs_real_t rho_f, cs_real_t rho_p, cs_real_t nu_f, cs_real_t taup[], const cs_real_t dt[])
 Modification of the calculation of the particle relaxation time with respect to the chosen formulation for the drag coefficient. More...
void cs_user_lagr_rt_t (cs_lnum_t id_p, cs_real_t re_p, cs_real_t uvwr, cs_real_t rho_f, cs_real_t rho_p, cs_real_t nu_f, cs_real_t cp_f, cs_real_t k_f, cs_real_t tauc[], const cs_real_t dt[])
 Modification of the computation of the thermal relaxation time of the particles with respect to the chosen formulation of the Nusselt number. More...
void cs_user_lagr_sde (const cs_real_t dt[], cs_real_t taup[], cs_real_3_t tlag[], cs_real_t tempct[])
 User integration of the SDE for the user-defined variables. More...
◆ cs_user_lagr_ef()
void cs_user_lagr_ef ( cs_real_t  dt_p,
cs_real_t  rho_p[],
It must be prescribed in every cell and be homogeneous to gravity (m/s^2) By default gravity and drag force are the only forces acting on the particles (the gravity components gx gy gz are assigned in the GUI or in usipsu)
[in]dt_ptime step (for the cell)
[in]taupparticle relaxation time
[in]tlagrelaxation time for the flow
[in]piilterm in the integration of the sde
[in]bxcharacteristics of the turbulence
[in]tsfextinfos for the return coupling
[in]vagausGaussian random variables
[in]gradprpressure gradient
[in]gradvfgradient of the flow velocity
[in,out]rho_pparticle density
[out]fextlauser external force field (m/s^2)$
◆ cs_user_lagr_extra_operations()
void cs_user_lagr_extra_operations ( const cs_real_t  dt[])
User-defined modifications on the variables at the end of the Lagrangian time step and calculation of user-defined additional statistics on the particles.
[in]dttime step (per cell)
◆ cs_user_lagr_imposed_motion()
void cs_user_lagr_imposed_motion ( const cs_real_t  coords[3],
cs_real_t  dt,
cs_real_t  disp[3]
User-defined modifications on the particle position and its velocity.
[in]coordsold particle coordinates
[in]dttime step (per particle)
[out]dispparticle dispacement
◆ cs_user_lagr_in()
void cs_user_lagr_in ( cs_lagr_particle_set_t particles,
const cs_lagr_injection_set_t zis,
This function is called after the initialization of the new particles in order to modify them according to new particle profiles (injection profiles, position of the injection point, statistical weights, correction of the diameter if the standard-deviation option is activated).
This function is called for each injection zone and set. Particles with ids between pset->n_particles and n_elts are initialized but may be modified by this function.
[in,out]particlesparticle set
[in]ziszone injection set data
[in]particle_rangestart and past-the-end ids of new particles for this zone and class
[in]particle_face_idface ids of new particles if zone is a boundary, NULL otherwise
[in]visc_lengthviscous layer thickness (size: number of mesh boundary faces)
◆ cs_user_lagr_rt()
void cs_user_lagr_rt ( cs_lnum_t  id_p,
cs_real_t  re_p,
cs_real_t  uvwr,
cs_real_t  rho_f,
cs_real_t  rho_p,
cs_real_t  nu_f,
cs_real_t  taup[],
This function is called in a loop on the particles, so be careful to avoid too costly operations.
           m   Cp
            p    p
  Tau = ---------------
     c          2
           PI d    h
               p    e
 Tau  : Thermal relaxation time (value to be computed)
    c
 m    : Particle mass
  p
 Cp   : Particle specific heat
   p
 d    : Particle diameter
  p
 h    : Coefficient of thermal exchange
  e
he coefficient of thermal exchange is calculated from a Nusselt number, itself evaluated by a correlation (Ranz-Marshall by default)
       h  d
        e  p
Nu = --------  = 2 + 0.55 Re **(0.5) Prt**(0.33)
      Lambda                p
Lambda : Thermal conductivity of the carrier field
Re     : Particle Reynolds number
  p
Prt    : Prandtl number
[in]id_pparticle id
[in]re_pparticle Reynolds number
[in]uvwrrelative velocity of the particle (flow-seen velocity - part. velocity)
[in]rho_ffluid density at particle position
[in]rho_pparticle density
[in]nu_fkinematic viscosity of the fluid at particle position
[out]taupthermal relaxation time
◆ cs_user_lagr_rt_t()
void cs_user_lagr_rt_t ( cs_lnum_t  id_p,
cs_real_t  re_p,
cs_real_t  uvwr,
cs_real_t  rho_f,
cs_real_t  rho_p,
cs_real_t  nu_f,
cs_real_t  cp_f,
cs_real_t  k_f,
cs_real_t  tauc[],
Modification of the calculation of the thermal relaxation time of the particles with respect to the chosen formulation of the Nusselt number.
[in]id_pparticle id
[in]cp_fspecific heat of the fluid at particle position
[in]k_fdiffusion coefficient of the fluid at particle position
[out]taucthermal relaxation time
◆ cs_user_lagr_sde()
void cs_user_lagr_sde ( const cs_real_t  dt[],
cs_real_t  taup[],
cs_real_3_t  tlag[],
cs_real_t  tempct[]
The variables are constant by default. The SDE must be of the form:
\[ \frac{dT}{dt}=\frac{T - PIP}{Tca} \]
T: particle attribute representing the variable Tca: characteristic time for the sde to be prescribed in the array auxl1 PIP: coefficient of the SDE (pseudo RHS) to be prescribed in the array auxl2. If the chosen scheme is first order (nordre=1) then, at the first and only call pip is expressed as a function of the quantities of the previous time step (contained in the particle data). If the chosen scheme is second order (nordre=2) then, at the first call (nor=1) pip is expressed as a function of the quantities of the previous time step, and at the second passage (nor=2) pip is expressed as a function of the quantities of the current time step.
[in]tempctcharacteristic thermal time and implicit source term of return coupling
