void | cs_timer_stats_initialize (void) |
Initialize timer statistics handling. More... | |
void | cs_timer_stats_finalize (void) |
Finalize timer statistics handling. More... | |
void | cs_timer_stats_set_start_time (int time_id) |
Set a start time for time stats. More... | |
void | cs_timer_stats_set_plot_options (cs_time_plot_format_t format, int frequency, int n_buffer_steps, double flush_wtime) |
Set global timer statistics plot options. More... | |
void | cs_timer_stats_increment_time_step (void) |
Increment time step for timer statistics. More... | |
int | cs_timer_stats_create (const char *parent_name, const char *name, const char *label) |
Create a timer statistics structure. More... | |
int | cs_timer_stats_id_by_name (const char *name) |
Return the id of a defined statistic based on its name. More... | |
void | cs_timer_stats_set_plot (int id, int plot) |
Enable or disable plotting for a timer statistic. More... | |
int | cs_timer_stats_is_active (int id) |
indicate if a timer for a given statistic is currently active. More... | |
void | cs_timer_stats_start (int id) |
Start a timer for a given statistic. More... | |
void | cs_timer_stats_stop (int id) |
Stop a timer for a given statistic. More... | |
int | cs_timer_stats_switch (int id) |
Start a timer for a given statistic, stopping previous timers of the same type which are not a parent, and starting inactive parent timers if necessary. More... | |
void | cs_timer_stats_add_diff (int id, const cs_timer_t *t0, const cs_timer_t *t1) |
Add a timing range to an inactive timer. More... | |
void | cs_timer_stats_define_defaults (void) |
Define default timer statistics. More... | |
void cs_timer_stats_add_diff | ( | int | id, |
const cs_timer_t * | t0, | ||
const cs_timer_t * | t1 | ||
This does not modify parent timers, so consistency of active and inactive timers must be ensured by the caller.
[in] | id | id of statistic |
[in] | t0 | oldest timer value |
[in] | t1 | most recent timer value |
int cs_timer_stats_create | ( | const char * | parent_name, |
const char * | name, | ||
const char * | label | ||
[in] | parent_name | name of parent statistic, or NULL |
[in] | name | associated canonical name |
[in] | label | associated label, or NULL |
void cs_timer_stats_define_defaults | ( | void | ) |
This creates 2 statistic timer trees, whose roots ids are:
void cs_timer_stats_finalize | ( | void | ) |
int cs_timer_stats_id_by_name | ( | const char * | name | ) |
If no timer with the given name exists, -1 is returned.
[in] | name | statistic name |
[in] | name | statitic name |
void cs_timer_stats_increment_time_step | ( | void | ) |
void cs_timer_stats_initialize | ( | void | ) |
int cs_timer_stats_is_active | ( | int | id | ) |
void cs_timer_stats_set_plot | ( | int | id, |
int | plot | ||
By default plotting is enabled for all statistics, except root statistic 1 (as it measures the same total time as root 0, with a different subtree).
This function is only effective before the first call to cs_timer_stats_increment_time_step.
[in] | plot | 0 to disable, 1 to enable |
void cs_timer_stats_set_plot_options | ( | cs_time_plot_format_t | format, |
int | frequency, | ||
int | n_buffer_steps, | ||
double | flush_wtime | ||
[in] | format | associated file format |
[in] | frequency | plot every n time steps |
[in] | n_buffer_steps | number of time steps in output buffer if file is not to be kept open |
[in] | flush_wtime | elapsed time interval between file flushes (if < 0, no forced flush) |
void cs_timer_stats_set_start_time | ( | int | time_id | ) |
This is useful to shift the time id for restarts. This function must not be called after cs_timer_stats_increment_time_step.
[in] | time_id | associated starting time id |
void cs_timer_stats_start | ( | int | id | ) |
Parents of the current statistic are also started, if not active.
If a timer with the same root but different parents is active, we assume the current operation is a subset of the active timer, so the timer is not started, so as to avoid having a sum of parts larger than the total.
void cs_timer_stats_stop | ( | int | id | ) |
Children of the current statistic are also stopped, if active.
int cs_timer_stats_switch | ( | int | id | ) |
[in] | id | id of statistic with same root |
