◆ CS_TIMER_COUNTER_ADD
| #define CS_TIMER_COUNTER_ADD |
_res, |
_c0, |
_c1 |
| (_res.nsec = _c0.nsec + _c1.nsec) |
◆ CS_TIMER_COUNTER_INIT
| #define CS_TIMER_COUNTER_INIT |
_t | ) |
(_t.nsec = 0) |
◆ cs_timer_cpu_time()
| double cs_timer_cpu_time |
void |
Return CPU time.
Note that in the rare case that only the minimal C library clock() method is available (see cs_timer_cpu_time_method()), at least one of the cs_timer_...() functions (possibly this one) must be called upon program start for this function to be used. In addition, in this case, time may "loop" back to 0 every multiple of 2^size_t / CLOCKS_PER_SEC seconds.
- Returns
- current CPU time usage, or -1 if unable to compute.
◆ cs_timer_cpu_time_method()
| const char* cs_timer_cpu_time_method |
void |
Return method used to return CPU time.
- Returns
- short description of method used to return CPU time.
◆ cs_timer_cpu_times()
| void cs_timer_cpu_times |
double * |
user_time, |
double * |
system_time |
Return separate user and system CPU times.
Note that in the rare case that only the minimal C library clock() method is available, this function will return -1 values.
- Parameters
| [out] | user_time | current user CPU usage. |
| [out] | system_time | current system CPU usage. |
◆ cs_timer_diff()
Compute the difference between 2 timers.
- Parameters
| [in] | t0 | oldest timer value |
| [in] | t1 | most recent timer value |
- Returns
- last - first timer value.
◆ cs_timer_time()
Return a timer's value.
- Returns
- timer structure.
◆ cs_timer_wtime()
| double cs_timer_wtime |
void |
Return Wall clock time.
- Returns
- elapsed time from first call of a function of the cs_timer_...() series, or -1 if unable to compute.
◆ cs_timer_wtime_method()
| const char* cs_timer_wtime_method |
void |
Return method used to return wall clock time.
- Returns
- short description of method used to return wall clock time.
