cs_paramedmem_remapper_t * | cs_paramedmem_remapper_create (char *name, const char *sel_criteria, char *file_name, char *mesh_name, cs_real_t center[3], cs_real_t radius) |
| Creates a new cs_paramedmem_remapper_t instance. More...
cs_paramedmem_remapper_t * | cs_paramedmem_remapper_by_name_try (const char *name) |
| get a remapper by its name More...
cs_real_t * | cs_paramedmem_remap_field (cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int time_choice, double tval) |
| Interpolate a given field on the local mesh for a given time. More...
cs_real_t * | cs_paramedmem_remap_field_one_time (cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int dt, int it) |
| Remaps a field from the med file to the local mesh for a given time. More...
void | cs_paramedmem_remapper_translate (cs_paramedmem_remapper_t *r, cs_real_t translation[3]) |
| translate the mesh using a given vector More...
void | cs_paramedmem_remapper_rotate (cs_paramedmem_remapper_t *r, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle) |
| Rotate the mesh using a center point, axis and angle. More...
void | cs_paramedmem_remapper_destroy_all (void) |
| Destroy all remappers. More...
◆ cs_paramedmem_remap_field()
cs_real_t* cs_paramedmem_remap_field |
r, |
char * |
field_name, |
cs_real_t |
default_val, |
int |
time_choice, |
double |
tval |
- Parameters
[in] | r | pointer to cs_paramedmem_remapper_t struct |
[in] | field_name | name of the field to remap from the file |
[in] | default_val | default value for unmapped elements |
[in] | time_choice | Choice of the time interpolation. 0: Value of field interpolated at t=tval from the med file. 1: Returns field values for the first time step in the file. tval is then ignored. 2: Returns field values for the last time step in the file. tval is then ignored. |
[in] | tval | requested time instant. If time choice is 0 and tval outside of the file time bounds, return value will be at the the first time step (if tval < tmin) or last time step (if tval > tmax) |
- Returns
- cs_real_t pointer containing the new values on target mesh
◆ cs_paramedmem_remap_field_one_time()
cs_real_t* cs_paramedmem_remap_field_one_time |
r, |
char * |
field_name, |
cs_real_t |
default_val, |
int |
dt, |
int |
it |
- Parameters
[in] | dt | time value to use from the file |
[in] | it | time iteration to use from the file |
- Returns
◆ cs_paramedmem_remapper_by_name_try()
cs_paramedmem_remapper_t* cs_paramedmem_remapper_by_name_try |
const char * |
name | ) |
- Parameters
[in] | name | name of the remapper |
- Returns
- pointer to cs_paramedmem_remapper_t struct
◆ cs_paramedmem_remapper_create()
cs_paramedmem_remapper_t* cs_paramedmem_remapper_create |
char * |
name, |
const char * |
sel_criteria, |
char * |
file_name, |
char * |
mesh_name, |
cs_real_t |
center[3], |
cs_real_t |
radius |
- Parameters
[in] | sel_criteria | cells selection criteria |
[in] | file_name | med file name |
[in] | mesh_name | name of the mesh in the med file |
[in] | center | center of bounding sphere |
[in] | radius | radius of bounding sphere |
- Returns
- cs_paramedmem_remapper_t struct
◆ cs_paramedmem_remapper_destroy_all()
void cs_paramedmem_remapper_destroy_all |
void |
◆ cs_paramedmem_remapper_rotate()
- Parameters
[in] | r | pointer to the cs_paramedmem_remapper_t struct |
[in] | invariant | coordinates of the invariant point |
[in] | axis | rotation axis vector |
[in] | angle | rotation angle in radians |
◆ cs_paramedmem_remapper_translate()
void cs_paramedmem_remapper_translate |
r, |
cs_real_t |
translation[3] |
- Parameters
[in] | translation | translation vector |
