Include dependency graph for cs_parall.h:Go to the source code of this file.
| void | cs_parall_allgather_r (int n_elts, int n_g_elts, cs_real_t array[], cs_real_t g_array[]) |
| Build a global array from each local array in each domain. More... | |
| void | cs_parall_allgather_ordered_r (int n_elts, int n_g_elts, int stride, cs_real_t o_key[], cs_real_t array[], cs_real_t g_array[]) |
| Build an ordered global array from each local array in each domain. More... | |
| void | cs_parall_gather_r (int root_rank, int n_elts, int n_g_elts, const cs_real_t array[], cs_real_t g_array[]) |
| Build a global array on the given root rank from all local arrays. More... | |
| void | cs_parall_gather_ordered_r (int root_rank, int n_elts, int n_g_elts, int stride, cs_real_t o_key[], cs_real_t array[], cs_real_t g_array[]) |
| Build an ordered global array on the given root rank from all local arrays. More... | |
| void | cs_parall_scatter_r (int root_rank, int n_elts, int n_g_elts, const cs_real_t g_array[], cs_real_t array[]) |
| Distribute a global array from a given root rank over all ranks. Each rank receive the part related to its local elements. More... | |
| void | cs_parall_gather_f (int root_rank, int n_elts, int n_g_elts, const float array[], float g_array[]) |
| Build a global array on the given root rank from all local arrays. Function dealing with single-precision arrays. More... | |
| void | cs_parall_scatter_f (int root_rank, int n_elts, int n_g_elts, const float g_array[], float array[]) |
| Distribute a global array from a given root rank over all ranks. Each rank receive the part related to its local elements. Function dealing with single-precision arrays. More... | |
| void | cs_parall_max_loc_vals (int n, cs_real_t *max, cs_real_t max_loc_vals[]) |
| Maximum value of a real and the value of related array on all default communicator processes. More... | |
| void | cs_parall_min_loc_vals (int n, cs_real_t *min, cs_real_t min_loc_vals[]) |
| Minimum value of a real and the value of related array on all default communicator processes. More... | |
| void | cs_parall_min_id_rank_r (cs_lnum_t *elt_id, int *rank_id, cs_real_t dis2mn) |
| Given an (id, rank, value) tuple, return the local id and rank corresponding to the global minimum value. More... | |
| size_t | cs_parall_get_min_coll_buf_size (void) |
| Return minimum recommended scatter or gather buffer size. More... | |
| void | cs_parall_set_min_coll_buf_size (size_t buffer_size) |
| Define minimum recommended scatter or gather buffer size. More... | |
| void cs_parall_allgather_ordered_r | ( | int | n_elts, |
| int | n_g_elts, | ||
| int | stride, | ||
| cs_real_t | o_key[], | ||
| cs_real_t | array[], | ||
| cs_real_t | g_array[] | ||
Local array elements are ordered based on a given key value (usually some form of coordinate, so the result should be independent of partitioning as long as the definition of the o_key array's defintion is itself independent of the partitioning.
Use of this function may be quite practical, but should be limited to user functions, as it may limit scalability (especially as regards memory usage).
| [in] | n_elts | number of local elements |
| [in] | n_g_elts | number of global elements |
| [in] | stride | number of values per element |
| [in] | o_key | ordering key (coordinate) value per element |
| [in] | array | local array (size: n_elts*stride) |
| [out] | g_array | global array (size: n_g_elts*stride) |
Local arrays are appended in order of owning MPI rank. The size of each local array may be different.
| [in] | n_elts | size of the local array |
| [in] | n_g_elts | size of the global array |
| [in] | array | local array (size: n_elts) |
| [out] | g_array | global array (size: n_g_elts) |
| void cs_parall_gather_f | ( | int | root_rank, |
| int | n_elts, | ||
| const float | array[], | ||
| float | g_array[] | ||
| [in] | root_rank | rank which stores the global array |
| [out] | g_array | global array (size: n_g_elts) only usable by the root rank |
| void cs_parall_gather_ordered_r | ( | int | root_rank, |
| int | n_elts, | ||
| int | stride, | ||
| void cs_parall_gather_r | ( | int | root_rank, |
| int | n_elts, | ||
| const cs_real_t | array[], | ||
| size_t cs_parall_get_min_coll_buf_size | ( | void | ) |
This is used by some internal part to block or scatter/gather algorithms, so as to allow I/O buffer size tuning.
| [in] | n | size of the related array |
| [in,out] | max | local max in, global max out |
| [in,out] | max_loc_vals | array values at location of local max in, and at location of global max out |
| [in,out] | elt_id | element id for which the value is the smallest (local in, global out) |
| [in,out] | rank_id | rank id for which the value is the smallest (local in, global out) |
| [in] | val | associated local minimum value |
| [in,out] | min | local min in, global min out |
| [in,out] | min_loc_vals | array values at location of local min in, and at location of global min out |
| void cs_parall_scatter_f | ( | int | root_rank, |
| int | n_elts, | ||
| const float | g_array[], | ||
| float | array[] | ||
Use of this function may be quite practical, but should be limited to specific usage, as it may limit scalability (especially as regards memory usage).
| [in] | g_array | global array (size: n_g_elts) only usable by the root rank |
| [out] | array | local array (size: n_elts) |
| void cs_parall_scatter_r | ( | int | root_rank, |
| int | n_elts, | ||
| const cs_real_t | g_array[], | ||
| cs_real_t | array[] | ||
| void cs_parall_set_min_coll_buf_size | ( | size_t | buffer_size | ) |
| [in] | buffer_size | minimum recommended part to block or gather buffer size (in bytes) |
