Include dependency graph for cs_mesh_intersect.h:Go to the source code of this file.
| void | cs_mesh_intersect_segment_cell_select (void *input, cs_lnum_t *n_cells, cs_lnum_t **cell_ids) |
| Select cells cut by a given segment. More... | |
| void | cs_mesh_intersect_polyline_cell_select (void *input, cs_lnum_t n_points, cs_lnum_t *n_cells, cs_lnum_t **cell_ids, cs_real_t **seg_c_len) |
| Select cells cut by a line composed of segments. More... | |
| void cs_mesh_intersect_polyline_cell_select | ( | void * | input, |
| cs_lnum_t | n_points, | ||
| cs_lnum_t * | n_cells, | ||
| cs_lnum_t ** | cell_ids, | ||
| cs_real_t ** | seg_c_len | ||
This selection function may be used as an elements selection function for postprocessing.
In this case, the input points to a real array containing the segment's start and end coordinates.
Note: the input pointer must point to valid data when this selection function is called, so either:
The caller is responsible for freeing the returned cell_ids array. When passed to postprocessing mesh or probe set definition functions, this is handled automatically.
| [in] | input | pointer to segments starts and ends: [x0, y0, z0, x1, y1, z1] |
| [in] | n_points | number of vertices in the polyline |
| [out] | n_cells | number of selected cells |
| [out] | cell_ids | array of selected cell ids (0 to n-1 numbering) |
| [out] | seg_c_len | array of length of the segment in the selected cells |
| void cs_mesh_intersect_segment_cell_select | ( | void * | input, |
| cs_lnum_t ** | cell_ids | ||
| [in] | input | pointer to segment start and end: [x0, y0, z0, x1, y1, z1] |
