7.1
cs_join_mesh.h
1 #ifndef __CS_JOIN_MESH_H__
2 #define __CS_JOIN_MESH_H__
5  * Subroutines useful to manipulate a cs_join_mesh_t structure
6  *===========================================================================*/
32  *---------------------------------------------------------------------------*/
34 #include <stdio.h>
37  * Local library headers
38  *---------------------------------------------------------------------------*/
40 #include "fvm_defs.h"
42 #include "cs_base.h"
43 #include "cs_join_util.h"
45 /*---------------------------------------------------------------------------*/
46
48
50  * Macro and type definitions
51  *===========================================================================*/
52
55 typedef enum {
56
57  CS_JOIN_FACE_UNDEFINED,
58  CS_JOIN_FACE_DISCARD,
59  CS_JOIN_FACE_BORDER,
60  CS_JOIN_FACE_MULTIPLE_BORDER,
61  CS_JOIN_FACE_INTERIOR
62
63 } cs_join_face_type_t;
64
65 typedef struct {
66
67  cs_join_state_t state; /* State of the vertices (perio/origin/...) */
68  cs_gnum_t gnum; /* Global vertex number */
69  double tolerance; /* Tolerance = radius of the sphere in which
70  intersection and merge is possible. */
71  double coord[3]; /* Coordinates of the vertex */
72
73 } cs_join_vertex_t;
74
75 typedef struct {
76
77  /* Edge numbering is defined by the ordering of the couples of vertices
78  in their global numbering */
79
80  cs_lnum_t n_edges; /* Local number of edges */
81  cs_gnum_t n_g_edges; /* Global number of edges */
82  cs_lnum_t *def; /* Definition of each edge by a couple of vertex
83  numbers */
84  cs_gnum_t *gnum; /* Global numbering of edges */
85
86  /*
87  Edge definition through the relation between vertices :
88
89  vtx_idx: index on vertices : -> define first vertex :
90  V1
91  adj_vtx_lst: list of coupled vertices with the first vertex V1:
92  V1a, V1b, ...
93  edge_lst: list of edge numbers relative to the defined couple:
94  (V1, V1a), (V1, V1b), ...
95  */
96
97  cs_lnum_t n_vertices; /* Number of vertices in index */
98  cs_lnum_t *vtx_idx; /* Index on first vertices */
99  cs_lnum_t *adj_vtx_lst; /* List of adjacent vertices */
100  cs_lnum_t *edge_lst; /* List of corresponding edge ids */
101
102 } cs_join_edges_t;
103
104 /* Structure defining a mesh on selected faces for the joining operation */
105
106 typedef struct {
107
108  char *name; /* For post-processing and dump purpose */
109
110  /* Face connectivity */
111
112  cs_lnum_t n_faces;
113  cs_gnum_t n_g_faces;
114  cs_gnum_t *face_gnum;
115  cs_lnum_t *face_vtx_idx;
116  cs_lnum_t *face_vtx_lst;
117
118  /* Vertex data */
119
120  cs_lnum_t n_vertices;
121  cs_gnum_t n_g_vertices;
122  cs_join_vertex_t *vertices;
123
124 } cs_join_mesh_t;
125
128 /*============================================================================
129  * Public function prototypes
130  *===========================================================================*/
131
132 /*----------------------------------------------------------------------------
133  * Allocate and initialize a new cs_join_mesh_t structure.
134  *
135  * parameters:
136  * name <-- name of the mesh
137  *
138  * returns:
139  * a pointer to a cs_join_mesh_t structure.
140  *---------------------------------------------------------------------------*/
141
142 cs_join_mesh_t *
143 cs_join_mesh_create(const char *name);
144
145 /*----------------------------------------------------------------------------
146  * Get a cs_join_mesh_t structure with the given list of global faces inside.
147  *
148  * Exchange between ranks to get the connectivity associated to each
149  * face of the global numbering list.
150  *
151  * parameters:
152  * mesh_name <-- name of the created mesh
153  * n_elts <-- number of elements in the global list
154  * glob_sel <-- list of global elements (ordered)
155  * gnum_rank_index <-- index on ranks for the global elements
156  * local_mesh <-- pointer to the local part of the distributed
157  * cs_join_mesh_t structure on selected elements
158  *
159  * returns:
160  * a pointer to a new allocated cs_join_mesh_t structure
161  *---------------------------------------------------------------------------*/
162
163 cs_join_mesh_t *
164 cs_join_mesh_create_from_glob_sel(const char *mesh_name,
165  cs_lnum_t n_elts,
166  const cs_gnum_t glob_sel[],
167  const cs_gnum_t gnum_rank_index[],
168  const cs_join_mesh_t *local_mesh);
169
170 /*----------------------------------------------------------------------------
171  * Allocate and define a cs_join_mesh_t structure relative to an extraction
172  * of selected faces.
173  *
174  * The selection must be ordered.
175  *
176  * parameters:
177  * mesh_name <-- name of the name to create
178  * subset_size <-- number of selected faces in the subset
179  * selection <-- list of selected faces. Numbering in parent mesh
180  * parent_mesh <-- parent cs_join_mesh_t structure
181  *
182  * returns:
183  * a pointer to a cs_join_mesh_t structure
184  *---------------------------------------------------------------------------*/
185
186 cs_join_mesh_t *
187 cs_join_mesh_create_from_subset(const char *mesh_name,
188  cs_lnum_t subset_size,
189  const cs_lnum_t selection[],
190  const cs_join_mesh_t *parent_mesh);
191
192 /*----------------------------------------------------------------------------
193  * Define a cs_join_mesh_t structure from a selection of faces and its
194  * related vertices.
195  *
196  * parameters:
197  * name <-- mesh name of the resulting cs_join_mesh_t structure
198  * param <-- set of user-defined parameters for the joining
199  * selection <-> selected entities
200  * b_f2v_idx <-- border "face -> vertex" connectivity index
201  * b_f2v_lst <-- border "face -> vertex" connectivity
202  * i_f2v_idx <-- interior "face -> vertex" connectivity index
203  * i_f2v_lst <-- interior "face -> vertex" connectivity
204  * n_vertices <-- number of vertices in the parent mesh
205  * vtx_coord <-- vertex coordinates in parent mesh
206  * vtx_gnum <-- global numbering of vertices
207  *
208  * returns:
209  * a pointer to a cs_join_mesh_t structure
210  *---------------------------------------------------------------------------*/
211
212 cs_join_mesh_t *
213 cs_join_mesh_create_from_select(const char *name,
214  const cs_join_param_t param,
215  cs_join_select_t *selection,
216  const cs_lnum_t b_f2v_idx[],
217  const cs_lnum_t b_f2v_lst[],
218  const cs_lnum_t i_f2v_idx[],
219  const cs_lnum_t i_f2v_lst[],
220  const cs_lnum_t n_vertices,
221  const cs_real_t vtx_coord[],
222  const cs_gnum_t vtx_gnum[]);
223
224 /*----------------------------------------------------------------------------
225  * Destroy a cs_join_mesh_t structure.
226  *
227  * parameters:
228  * mesh <-> pointer to pointer to cs_join_mesh_t structure to destroy
229  *---------------------------------------------------------------------------*/
230
231 void
232 cs_join_mesh_destroy(cs_join_mesh_t **mesh);
233
234 /*----------------------------------------------------------------------------
235  * Re-initialize an existing cs_join_mesh_t structure.
236  *
237  * parameters:
238  * mesh <-> pointer to a cs_join_mesh_t structure
239  *---------------------------------------------------------------------------*/
240
241 void
242 cs_join_mesh_reset(cs_join_mesh_t *mesh);
243
244 /*----------------------------------------------------------------------------
245  * Copy a cs_join_mesh_t structure into another.
246  *
247  * parameters:
248  * mesh <-> pointer to a cs_join_mesh_t structure to fill
249  * ref_mesh <-- pointer to the reference
250  *---------------------------------------------------------------------------*/
251
252 void
253 cs_join_mesh_copy(cs_join_mesh_t **mesh,
254  const cs_join_mesh_t *ref_mesh);
255
256 /*----------------------------------------------------------------------------
257  * Compute the global min/max tolerance defined on vertices and display it
258  *
259  * parameters:
260  * param <-- user-defined parameters for the joining algorithm
261  * mesh <-- pointer to a cs_join_mesh_t structure
262  *---------------------------------------------------------------------------*/
263
264 void
266  cs_join_mesh_t *mesh);
267
268 #if defined(HAVE_MPI)
269
270 /*----------------------------------------------------------------------------
271  * Get the connectivity of a list of global elements distributed over the
272  * ranks.
273  *
274  * parameters:
275  * n_send <-- number of face/rank couples to send
276  * send_rank <-- index on ranks for the face distribution
277  * send_faces <-- list of face ids to send
278  * send_mesh <-- pointer to the sending cs_join_mesh_t structure
279  * recv_mesh <-> pointer to the receiving cs_join_mesh_t structure
280  * comm <-- mpi communicator on which take places comm.
281  *---------------------------------------------------------------------------*/
282
283 void
284 cs_join_mesh_exchange(cs_lnum_t n_send,
285  const int send_rank[],
286  const cs_lnum_t send_faces[],
287  const cs_join_mesh_t *send_mesh,
288  cs_join_mesh_t *recv_mesh,
289  MPI_Comm comm);
290
291 #endif /* defined(HAVE_MPI) */
292
293 /*----------------------------------------------------------------------------
294  * Destroy a cs_join_edges_t structure.
295  *
296  * parameters:
297  * edges <-> pointer to pointer to cs_join_edges_t structure to destroy
298  *---------------------------------------------------------------------------*/
299
300 void
301 cs_join_mesh_destroy_edges(cs_join_edges_t **edges);
302
303 /*----------------------------------------------------------------------------
304  * Order a cs_join_mesh_t structure according to its global face numbering
305  *
306  * Delete redundancies.
307  *
308  * parameters:
309  * mesh <-> pointer to a cs_join_mesh_t structure to order
310  *---------------------------------------------------------------------------*/
311
312 void
313 cs_join_mesh_face_order(cs_join_mesh_t *mesh);
314
315 /*----------------------------------------------------------------------------
316  * Synchronize vertices definition over the rank. For a vertex with the same
317  * global number but a not equal tolerance, we keep the minimal tolerance.
318  *
319  * parameters:
320  * mesh <-> pointer to the cs_join_mesh_t structure to synchronize
321  *---------------------------------------------------------------------------*/
322
323 void
324 cs_join_mesh_sync_vertices(cs_join_mesh_t *mesh);
325
326 /*----------------------------------------------------------------------------
327  * Delete vertices which appear several times (same global number) and
328  * vertices which are not used in face definition.
329  *
330  * parameters:
331  * mesh <-> pointer to cs_join_mesh_t structure to clean
332  *---------------------------------------------------------------------------*/
333
334 void
335 cs_join_mesh_vertex_clean(cs_join_mesh_t *mesh);
336
337 /*----------------------------------------------------------------------------
338  * Clean the given cs_join_mesh_t structure, removing degenerate edges.
339  *
340  * parameters:
341  * mesh <-> pointer to the cs_join_mesh_t structure to clean
342  * verbosity <-- level of display
343  *---------------------------------------------------------------------------*/
344
345 void
346 cs_join_mesh_clean(cs_join_mesh_t *mesh,
347  int verbosity);
348
349 /*----------------------------------------------------------------------------
350  * Define a list of edges associated to a cs_join_mesh_t structure.
351  *
352  * parameters:
353  * mesh <-- pointer to a cs_join_mesh_t structure
354  *
355  * returns:
356  * a pointer to the new defined cs_join_edges_t structure.
357  *---------------------------------------------------------------------------*/
358
359 cs_join_edges_t *
360 cs_join_mesh_define_edges(const cs_join_mesh_t *mesh);
361
362 /*----------------------------------------------------------------------------
363  * Get the edge number relative to a couple of vertex numbers.
364  *
365  * edge_num > 0 if couple is in the same order as the edge->def
366  * edge_num < 0 otherwise
367  *
368  * parameters:
369  * v1_num <-- vertex number for the first vertex
370  * v2_num <-- vertex number for the second vertex
371  * edges <-- pointer to a cs_join_edges_t structure
372  *
373  * returns:
374  * an edge number relative to the couple of vertices
375  *---------------------------------------------------------------------------*/
376
377 cs_lnum_t
379  cs_lnum_t v2_num,
380  const cs_join_edges_t *edges);
381
382 /*----------------------------------------------------------------------------
383  * Re-organize the cs_join_mesh_t structure after a renumbering of
384  * the vertices following the merge operation + a new description of each
385  * face.
386  *
387  * parameters:
388  * mesh <-> pointer to the cs_join_mesh_t structure to update
389  * edges <-- pointer to a cs_join_edges_t structure
390  * edge_index <-- index on edges for the new vertices
391  * edge_new_vtx_lst <-- list of new vertices for each edge
392  * n_new_vertices <-- new local number of vertices after merge
393  * old2new <-- array storing the relation between old/new vertex id
394  *---------------------------------------------------------------------------*/
395
396 void
397 cs_join_mesh_update(cs_join_mesh_t *mesh,
398  const cs_join_edges_t *edges,
399  const cs_lnum_t edge_index[],
400  const cs_lnum_t edge_new_vtx_lst[],
401  cs_lnum_t n_new_vertices,
402  const cs_lnum_t old2new[]);
403
404 /*----------------------------------------------------------------------------
405  * Compute for each face of the cs_join_mesh_t structure the face normal.
406  * || face_normal || = 1 (divided by the area of the face)
407  *
408  * The caller is responsible for freeing the returned array.
409  *
410  * parameters:
411  * mesh <-- pointer to a cs_join_mesh_t structure
412  *
413  * Pi+1
414  * *---------* B : barycenter of the polygon
415  * / . . \
416  * / . . \ Pi : vertices of the polygon
417  * / . . \
418  * / . . Ti \ Ti : triangle
419  * *.........B.........* Pi
420  * Pn-1 \ . . /
421  * \ . . /
422  * \ . . /
423  * \ . T0 . /
424  * *---------*
425  * P0
426  *
427  *
428  * returns:
429  * an array with the face normal for each face of the mesh
430  *---------------------------------------------------------------------------*/
431
432 cs_real_t *
433 cs_join_mesh_get_face_normal(const cs_join_mesh_t *mesh);
434
435 /*----------------------------------------------------------------------------
436  * Allocate and define an "edge -> face" connectivity
437  *
438  * parameters:
439  * mesh <-- pointer to a cs_join_mesh_t structure
440  * edges <-- pointer to a cs_join_edges_t structure
441  * edge_face_idx --> pointer to the edge -> face connect. index
442  * edge_face_lst --> pointer to the edge -> face connect. list
443  *---------------------------------------------------------------------------*/
444
445 void
446 cs_join_mesh_get_edge_face_adj(const cs_join_mesh_t *mesh,
447  const cs_join_edges_t *edges,
448  cs_lnum_t *edge_face_idx[],
449  cs_lnum_t *edge_face_lst[]);
450
451 /*----------------------------------------------------------------------------
452  * Dump a cs_join_vertex_t structure into a file.
453  *
454  * parameters:
455  * f <-- handle to output file
456  * vertex <-- cs_join_vertex_t structure to dump
457  *---------------------------------------------------------------------------*/
458
459 void
461  const cs_join_vertex_t vertex);
462
463 /*----------------------------------------------------------------------------
464  * Dump a cs_join_mesh_t structure into a file.
465  *
466  * parameters:
467  * f <-- handle to output file
468  * mesh <-- pointer to cs_join_mesh_t structure to dump
469  *---------------------------------------------------------------------------*/
470
471 void
472 cs_join_mesh_dump(FILE *f,
473  const cs_join_mesh_t *mesh);
474
475 /*----------------------------------------------------------------------------
476  * Dump a list of cs_join_edge_t structures.
477  *
478  * parameters:
479  * f <-- handle to output file
480  * edges <-- cs_join_edges_t structure to dump
481  * mesh <-- associated cs_join_mesh_t structure
482  *---------------------------------------------------------------------------*/
483
484 void
486  const cs_join_edges_t *edges,
487  const cs_join_mesh_t *mesh);
488
489 /*---------------------------------------------------------------------------*/
490
492
493 #endif /* __CS_JOIN_MESH_H__ */
void cs_join_mesh_destroy(cs_join_mesh_t **mesh)
Definition: cs_join_mesh.c:1873
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
void cs_join_mesh_update(cs_join_mesh_t *mesh, const cs_join_edges_t *edges, const cs_lnum_t edge_index[], const cs_lnum_t edge_new_vtx_lst[], cs_lnum_t n_new_vertices, const cs_lnum_t old2new[])
Definition: cs_join_mesh.c:3054
void cs_join_mesh_copy(cs_join_mesh_t **mesh, const cs_join_mesh_t *ref_mesh)
Definition: cs_join_mesh.c:1924
cs_real_t * cs_join_mesh_get_face_normal(const cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:3268
void cs_join_mesh_dump(FILE *f, const cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:3557
cs_lnum_t cs_join_mesh_get_edge(cs_lnum_t v1_num, cs_lnum_t v2_num, const cs_join_edges_t *edges)
Definition: cs_join_mesh.c:3003
void cs_join_mesh_get_edge_face_adj(const cs_join_mesh_t *mesh, const cs_join_edges_t *edges, cs_lnum_t *edge_face_idx[], cs_lnum_t *edge_face_lst[])
Definition: cs_join_mesh.c:3392
Definition: cs_defs.h:322
cs_join_edges_t * cs_join_mesh_define_edges(const cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:2660
void cs_join_mesh_clean(cs_join_mesh_t *mesh, int verbosity)
Definition: cs_join_mesh.c:2612
void cs_join_mesh_minmax_tol(cs_join_param_t param, cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:1981
void cs_join_mesh_face_order(cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:2282
void cs_join_mesh_dump_edges(FILE *f, const cs_join_edges_t *edges, const cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:3678
cs_join_mesh_t * cs_join_mesh_create_from_glob_sel(const char *mesh_name, cs_lnum_t n_elts, const cs_gnum_t glob_sel[], const cs_gnum_t gnum_rank_index[], const cs_join_mesh_t *local_mesh)
Definition: cs_join_mesh.c:1515
void cs_join_mesh_dump_vertex(FILE *f, const cs_join_vertex_t vertex)
Definition: cs_join_mesh.c:3536
cs_join_mesh_t * cs_join_mesh_create_from_select(const char *name, const cs_join_param_t param, cs_join_select_t *selection, const cs_lnum_t b_f2v_idx[], const cs_lnum_t b_f2v_lst[], const cs_lnum_t i_f2v_idx[], const cs_lnum_t i_f2v_lst[], const cs_lnum_t n_vertices, const cs_real_t vtx_coord[], const cs_gnum_t vtx_gnum[])
Definition: cs_join_mesh.c:1773
cs_join_state_t
Definition: cs_join_util.h:63
cs_join_mesh_t * cs_join_mesh_create(const char *name)
Definition: cs_join_mesh.c:1466
void cs_join_mesh_reset(cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:1897
Definition: cs_defs.h:316
void cs_join_mesh_destroy_edges(cs_join_edges_t **edges)
Definition: cs_join_mesh.c:2253
void cs_join_mesh_sync_vertices(cs_join_mesh_t *mesh)
Definition: cs_join_util.h:115
void cs_join_mesh_vertex_clean(cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:2505
cs_join_mesh_t * cs_join_mesh_create_from_subset(const char *mesh_name, cs_lnum_t subset_size, const cs_lnum_t selection[], const cs_join_mesh_t *parent_mesh)
Definition: cs_join_mesh.c:1600
Definition: mesh.f90:26
