#include <cs_join_util.h>
Collaboration diagram for cs_join_param_t:Data Fields | |
| int | num |
| int | perio_type |
| double | perio_matrix [3][4] |
| int | tree_max_level |
| int | tree_n_max_boxes |
| float | tree_max_box_ratio |
| float | tree_max_box_ratio_distrib |
| float | fraction |
| float | plane |
| double | plane_criteria |
| float | merge_tol_coef |
| float | pre_merge_factor |
| int | n_max_equiv_breaks |
| int | tcm |
| int | icm |
| int | max_sub_faces |
| int | verbosity |
| int | visualization |
| bool | preprocessing |
| float fraction |
| int icm |
| int max_sub_faces |
| float merge_tol_coef |
| int n_max_equiv_breaks |
| int num |
| double perio_matrix[3][4] |
| int perio_type |
| float plane |
| double plane_criteria |
| float pre_merge_factor |
| bool preprocessing |
| int tcm |
| float tree_max_box_ratio |
| float tree_max_box_ratio_distrib |
| int tree_max_level |
| int tree_n_max_boxes |
| int verbosity |
| int visualization |
