7.1
cs_c_bindings.f90 File Reference
Definition of C function and subroutine bindings. More...
Data Types
type  var_cal_opt
type  solving_info
type  gwf_soilwater_partition
type  gas_mix_species_prop
interface  beta_limiter_building
interface  boundary_conditions_mapped_set
 Set mapped boundary conditions for a given field and mapping locator. More...
interface  cs_f_field_set_key_struct_var_cal_opt
interface  cs_f_field_get_key_struct_var_cal_opt
interface  equation_param_from_vcopt
interface  cs_fan_n_fans
 Return the number of fans. More...
interface  cs_log_default_activate
interface  cs_log_default_is_active
interface  log_iteration
interface  log_l2residual
interface  cs_turb_model_init
interface  cs_set_type_order_turbulence_model
interface  cs_intprf
interface  cs_intprz
interface  les_filter
 Compute filters for dynamic models. More...
interface  les_balance_create
 Create the LES balance structure. More...
interface  les_balance_finalize
 Destroy the LES balance structure. More...
interface  les_balance_write_restart
 Write the LES balance restart file. More...
interface  les_balance_update_gradients
 Compute additional time averages for LES balance. More...
interface  les_balance_compute
 Compute the LES balance. More...
interface  cs_map_name_to_id_destroy
 Destroy name to id map structure. More...
interface  parameters_read_restart_info
 Read restart metadata. More...
interface  restart_destroy
 Destroy structure associated with a restart file (and close the file). More...
interface  restart_check_base_location
 Check the locations associated with a restart file. More...
interface  restart_read_field_info
 Read field metadata from checkpoint. More...
interface  restart_write_field_info
 Write field metadata to checkpoint. More...
interface  restart_read_bc_coeffs
 Read boundary condition coefficients for all fields from checkpoint. More...
interface  restart_write_bc_coeffs
 Write boundary condition coefficients for all fields to checkpoint. More...
interface  restart_write_fields
 Loop over all fields and save them in the restart file which id is passed in argument if it matches their "restart_file" key value. More...
interface  restart_read_fields
 Loop over all fields and read them in the restart file which id is passed in argument if it matches their "restart_file" key value. More...
interface  restart_clean_multiwriters_history
 Remove all previous dumps of checkpoint files which are not to be saved. More...
interface  cs_syr_coupling_n_couplings
interface  cs_time_moment_n_moments
 Return the number of temporal moments. More...
interface  cs_time_moment_is_active
 Return if moment is active (1) or not (0). More...
interface  time_moment_update_all
 Update temporal moments. More...
interface  time_moment_log_iteration
 Log temporal moments initialization. More...
interface  time_moment_field_id
 Get field id associated with a given moment. More...
interface  time_moment_restart_read
 Read temporal moments checkpoint information. More...
interface  time_moment_restart_write
 Checkpoint temporal moments. More...
interface  timer_stats_increment_time_step
 Increment time step for timer statistics. More...
interface  timer_stats_set_plot
 Enable or disable plotting for a timer statistic. More...
interface  timer_stats_start
 Start a timer for a given statistic. More...
interface  timer_stats_stop
 Stop a timer for a given statistic. More...
interface  timer_stats_switch
 Start a timer for a given statistic, stopping previous timers of the same type which are not a parent, and starting inactive parent timers if necessary. More...
interface  turbulence_bc_ke_hyd_diam
 Calculation of $ u^\star $, $ k $ and $\varepsilon $ from a diameter $ D_H $ and the reference velocity $ U_{ref} $ for a circular duct flow with smooth wall (use for inlet boundary conditions). More...
interface  turbulence_bc_ke_turb_intensity
 Calculation of $ k $ and $\varepsilon$ from a diameter $ D_H $, a turbulent intensity $ I $ and the reference velocity $ U_{ref} $ for a circular duct flow with smooth wall (for inlet boundary conditions). More...
interface  turbulence_bc_rij_transform
 Compute matrix $ \tens{alpha} $ used in the computation of the Reynolds stress tensor boundary conditions. More...
interface  turbulence_bc_inlet_hyd_diam
 Set inlet boundary condition values for turbulence variables based on a diameter $ D_H $ and the reference velocity $ U_{ref} $ for a circular duct flow with smooth wall. More...
interface  turbulence_bc_inlet_turb_intensity
 Set inlet boundary condition values for turbulence variables based on a diameter $ D_H $, a turbulent intensity $ I $ and the reference velocity $ U_{ref} $ for a circular duct flow with smooth wall. More...
interface  turbulence_bc_inlet_k_eps
 Set inlet boundary condition values for turbulence variables based on given k and epsilon values. More...
interface  turbulence_bc_set_uninit_inlet_k_eps
 Set inlet boundary condition values for turbulence variables based on given k and epsilon values only if not initialized already. More...
interface  yg2xye
 Compute molar and mass fractions of elementary species Ye, Xe (fuel, O2, CO2, H2O, N2) from global species Yg (fuel, oxidant, products) More...
interface  user_parameters
 General user parameters. More...
interface  user_porosity
Modules
module  cs_c_bindings
Functions/Subroutines
subroutine balance_by_zone (sel_crit, name)
 Compute balance on a given zone for a given scalar. More...
subroutine intprf (nprofz, nproft, profz, proft, profv, xz, temps, var)
 Temporal and z-axis interpolation for meteorological profiles. More...
subroutine intprz (nprofz, profz, profv, xz, iz1, iz2, var)
 z-axis interpolation for meteorological profiles More...
subroutine pressure_drop_by_zone (sel_crit)
 Compute pressure drop for a given zone. More...
subroutine promav (isym, ibsize, iesize, f_id, dam, xam, vx, vy)
subroutine surface_balance (sel_crit, name, normal)
 Compute surface scalar balance for a given surface area. More...
subroutine boundary_conditions_error (bc_type)
 Handle boundary condition definition errors and associated output. More...
type(c_ptr) function boundary_conditions_map (location_type, n_location_elts, n_faces, location_elts, faces, coord_shift, coord_stride, tolerance)
 Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later interpolation. More...
subroutine field_set_key_struct_var_cal_opt (f_id, k_value)
 Assign a var_cal_opt for a cs_var_cal_opt_t key to a field. More...
subroutine field_set_key_struct_solving_info (f_id, k_value)
 Assign a solving_info for a cs_solving_info_t key to a field. More...
subroutine field_set_key_struct_gwf_soilwater_partition (f_id, k_value)
 Assign a gwf_soilwater_partition for a cs_gwf_soilwater_partition_t key to a field. More...
subroutine field_set_key_struct_gas_mix_species_prop (f_id, k_value)
 Assign a gas_mix_species_prop for a cs_gas_mix_species_prop_t key to a field. More...
subroutine field_get_key_struct_var_cal_opt (f_id, k_value)
 Return a pointer to the var_cal_opt structure for cs_var_cal_opt key associated with a field. More...
subroutine field_get_key_struct_solving_info (f_id, k_value)
 Return a pointer to the solving_info structure for cs_solving_info_t key associated with a field. More...
subroutine field_get_key_struct_gwf_soilwater_partition (f_id, k_value)
 Return a pointer to the gwf_soilwater_partition structure for cs_gwf_soilwater_partition_t key associated with a field. More...
subroutine field_get_key_struct_gas_mix_species_prop (f_id, k_value)
 Return a pointer to the gas_mix_species_prop structure for cs_gas_mix_species_prop_t key associated with a field. More...
subroutine gradient_s (f_id, imrgra, inc, recompute_cocg, nswrgp, imligp, iwarnp, epsrgp, climgp, pvar, coefap, coefbp, grad)
 Compute cell gradient. More...
subroutine gradient_weighted_s (f_id, imrgra, inc, recompute_cocg, nswrgp, imligp, hyd_p_flag, iwarnp, epsrgp, climgp, f_ext, pvar, c_weight, coefap, coefbp, grad)
 Compute cell gradient of a scalar with weighting. More...
subroutine locator_destroy (this_locator)
 Destruction of a locator structure. More...
subroutine log_iteration_add_array (name, category, location, is_intensive, dim, val)
 Add array not saved as permanent field to logging of fields. More...
subroutine log_iteration_clipping (name, dim, n_clip_min, n_clip_max, min_pre_clip, max_pre_clip)
subroutine log_iteration_clipping_field (f_id, n_clip_min, n_clip_max, min_pre_clip, max_pre_clip, n_clip_min_comp, n_clip_max_comp)
subroutine restart_create (name, path, mode, r)
 Initialize a restart file. More...
subroutine restart_read_variables (r, old_field_map, t_id_flag)
 Read variables from checkpoint. More...
subroutine restart_write_variables (r, t_id_flag)
 Write variables to checkpoint. More...
subroutine restart_read_section_int_t (r, sec_name, location_id, n_loc_vals, val, ierror)
 Read a section of integers from a restart file. More...
subroutine restart_read_int_t_compat (r, sec_name, old_name, location_id, n_loc_vals, val, ierror)
 Read a section of integers from a restart file, when that section may have used a different name in a previous version. More...
subroutine restart_write_section_int_t (r, sec_name, location_id, n_loc_vals, val)
 Write a section of integers to a checkpoint file. More...
subroutine restart_read_section_real_t (r, sec_name, location_id, n_loc_vals, val, ierror)
 Read a section of doubles from a restart file. More...
subroutine restart_read_real_t_compat (r, sec_name, old_name, location_id, n_loc_vals, val, ierror)
 Read a section of double precision reals from a restart file, when that section may have used a different name in a previous version. More...
subroutine restart_read_real_3_t_compat (r, sec_name, old_name_x, old_name_y, old_name_z, location_id, val, ierror)
 Read a vector of double precision reals of dimension (3,*) from a restart file, when that section may have used a different name and been non-interleaved in a previous version. More...
subroutine restart_write_section_real_t (r, sec_name, location_id, n_loc_vals, val)
 write a section of doubles to a checkpoint file. More...
subroutine restart_read_field_vals (r, f_id, t_id, ierror)
 Read field values from checkpoint. More...
subroutine restart_write_field_vals (r, f_id, t_id)
 Write field values to checkpoint. More...
subroutine restart_read_linked_fields (r, old_field_map, key, n_w)
 Read fields depending on others from checkpoint. More...
subroutine restart_write_linked_fields (r, key, n_w)
 Write fields depending on others to checkpoint. More...
subroutine sles_solve_native (f_id, name, isym, ibsize, iesize, dam, xam, epsilp, rnorm, niter, residue, rhs, vx)
 Call sparse linear equation solver using native matrix arrays. More...
subroutine sles_free_native (f_id, name)
 Free sparse linear equation solver setup using native matrix arrays. More...
subroutine sles_push (f_id, name)
 Temporarily replace field id with name for matching calls to sles_solve_native. More...
subroutine sles_pop (f_id)
 Revert to normal behavior of field id for matching calls to sles_solve_native. More...
integer function timer_stats_create (parent_name, name, label)
 Create a timer statistics structure. More...
integer function timer_stats_id_by_name (name)
 Return the id of a defined statistic based on its name. More...
subroutine variable_field_create (name, label, location_id, dim, id)
 Add field defining a general solved variable, with default options. More...
subroutine variable_cdo_field_create (name, label, location_id, dim, has_previous, id)
 Add a CDO field defining a general solved variable, with default options. More...
integer function volume_zone_n_type_zones (type_flag)
 Return the number of volume zones associated with a given type flag. More...
integer function volume_zone_n_type_cells (type_flag)
 Return the number of volume zone cells associated with a given type flag. More...
subroutine volume_zone_select_type_cells (type_flag, cell_list)
 Return the list of volume zone cells associated with a given type flag. More...
subroutine field_get_coupled_faces (f_id, cpl_faces)
 Return pointer to coupling face indicator for a field. More...
double precision function notebook_parameter_value_by_name (name)
 Return notebook parameter value. More...
integer function cell_is_active (iel)
 Indicate of a cell is active fo the current variable. More...
subroutine atmo_set_meteo_file_name (name)
 Sets the meteo file name. More...
subroutine atmo_set_chem_conc_file_name (name)
 Sets the chemistry concentration file name. More...
subroutine atmo_set_aero_conc_file_name (name)
 Sets the aerosol concentration file name. More...
subroutine atmo_chemistry_set_spack_file_name (name)
 Sets the file name used to initialize SPACK. More...
subroutine atmo_chemistry_set_aerosol_file_name (name)
 Sets the file name used to initialize the aerosol shared library. More...
integer mesh_location_none
integer mesh_location_cells
integer mesh_location_interior_faces
integer mesh_location_boundary_faces
integer mesh_location_vertices
integer mesh_location_particles
integer mesh_location_other
integer restart_val_type_int_t
integer restart_val_type_real_t
integer restart_disabled
integer restart_main
integer restart_auxiliary
integer restart_rad_transfer
integer restart_lagr
integer restart_lagr_stat
integer restart_1d_wall_thermal
integer restart_les_inflow
integer volume_zone_initialization
integer volume_zone_porosity
integer volume_zone_head_loss
integer volume_zone_source_term
integer volume_zone_mass_source_term
