7.1
cs_atmo.h File Reference
+ Include dependency graph for cs_atmo.h:
Data Structures
struct  cs_atmo_option_t
struct  cs_atmo_constants_t
struct  cs_atmo_chemistry_t
Enumerations
enum  cs_atmo_model_t { CS_ATMO_OFF = -1, CS_ATMO_CONSTANT_DENSITY = 0, CS_ATMO_DRY = 1, CS_ATMO_HUMID = 2 }
enum  cs_atmo_nucleation_type_t { CS_ATMO_NUC_OFF = 0, CS_ATMO_NUC_PRUPPACHER_KLETT = 1, CS_ATMO_NUC_COHARD = 2, CS_ATMO_NUC_ABDUL_RAZZAK = 3 }
enum  cs_atmo_aerosol_type_t { CS_ATMO_AEROSOL_OFF = 0, CS_ATMO_AEROSOL_SSH = 1 }
void cs_atmo_init_meteo_profiles (void)
 Initialize meteo profiles if no meteo file is given. More...
void cs_atmo_compute_meteo_profiles (void)
 Compute meteo profiles if no meteo file is given. More...
void cs_atmo_z_ground_compute (void)
 This function computes the ground elevation. More...
void cs_atmo_hydrostatic_profiles_compute (void)
 Compute hydrostatic profiles of density and pressure. More...
cs_real_t cs_mo_phim (cs_real_t z, cs_real_t dlmo)
 Universal function phim for neutral, stable and unstable. More...
cs_real_t cs_mo_phih (cs_real_t z, cs_real_t dlmo)
 Universal function phih for neutral, stable and unstable. More...
cs_real_t cs_mo_psim (cs_real_t z, cs_real_t z0, cs_real_t dlmo)
 Universal function psim for neutral, stable and unstable. More...
cs_real_t cs_mo_psih (cs_real_t z, cs_real_t z0, cs_real_t dlmo)
 Universal function psih for neutral, stable and unstable. More...
void cs_atmo_set_meteo_file_name (const char *file_name)
 This function set the file name of the meteo file. More...
void cs_atmo_set_chem_conc_file_name (const char *file_name)
 This function set the file name of the chemistry concentration file. More...
void cs_atmo_set_aero_conc_file_name (const char *file_name)
 This function set the file name of the aerosol concentration file. More...
void cs_atmo_chemistry_set_spack_file_name (const char *file_name)
 This function set the file name of the SPACK file. More...
void cs_atmo_chemistry_set_aerosol_file_name (const char *file_name)
 This function sets the file name to initialize the aerosol library. More...
void cs_atmo_declare_chem_from_spack (void)
 This function declare additional transported variables for atmospheric module for the chemistry defined from SPACK. More...
void cs_atmo_compute_solar_angles (cs_real_t xlat, cs_real_t xlong, cs_real_t jour, cs_real_t heurtu, int imer, cs_real_t *albe, cs_real_t *muzero, cs_real_t *omega, cs_real_t *fo)
 1D Radiative scheme - Solar data + zenithal angle) More...
void cs_atmo_log_setup (void)
 Print the atmospheric module options to setup.log. More...
void cs_atmo_chemistry_log_setup (void)
 Print the atmospheric chemistry options to setup.log. More...
void cs_atmo_aerosol_log_setup (void)
 Print the atmospheric aerosols options to setup.log. More...
void cs_atmo_finalize (void)
 Deallocate arrays for atmo module. More...
cs_atmo_option_tcs_glob_atmo_option
cs_atmo_constants_tcs_glob_atmo_constants
cs_atmo_chemistry_tcs_glob_atmo_chemistry
◆ cs_atmo_aerosol_type_t
Enumerator
CS_ATMO_AEROSOL_OFF
CS_ATMO_AEROSOL_SSH
◆ cs_atmo_model_t
Enumerator
CS_ATMO_OFF
CS_ATMO_DRY
CS_ATMO_HUMID
◆ cs_atmo_nucleation_type_t
Enumerator
CS_ATMO_NUC_OFF
CS_ATMO_NUC_COHARD
◆ cs_atmo_aerosol_log_setup()
void cs_atmo_aerosol_log_setup ( void  )
◆ cs_atmo_chemistry_log_setup()
void cs_atmo_chemistry_log_setup ( void  )
◆ cs_atmo_chemistry_set_aerosol_file_name()
void cs_atmo_chemistry_set_aerosol_file_name ( const char *  file_name)
[in]file_namename of the file.
◆ cs_atmo_chemistry_set_spack_file_name()
void cs_atmo_chemistry_set_spack_file_name ( const char *  file_name)
◆ cs_atmo_compute_meteo_profiles()
void cs_atmo_compute_meteo_profiles ( void  )
◆ cs_atmo_compute_solar_angles()
void cs_atmo_compute_solar_angles ( cs_real_t  latitude,
cs_real_t  longitude,
cs_real_t  squant,
cs_real_t  utc,
int  sea_id,
cs_real_t albedo,
cs_real_t muzero,
cs_real_t omega,
cs_real_t fo
Compute:
  • zenithal angle
  • solar contant (with correction for earth - solar length)
  • albedo if above the sea (Use analytical formulae of Paltrige and Platt dev.in atm. science no 5)
    [in]xlatlatitude
    [in]xlonglongitude
    [in]jourday in the year
    [in]heurtuUniversal time (hour)
    [in]imersea index
    [out]albealbedo
    [out]muzerocosin of zenithal angle
    [out]omegasolar azimut angle
    [out]fosolar constant
    Compute:
  • zenithal angle
    [in]latitudelatitude
    [in]longitudelongitude
    [in]squantstart day in the year
    [in]utcUniversal time (hour)
    [in]sea_idsea index
    [out]albedoalbedo
◆ cs_atmo_declare_chem_from_spack()
void cs_atmo_declare_chem_from_spack ( void  )
◆ cs_atmo_finalize()
void cs_atmo_finalize ( void  )
◆ cs_atmo_hydrostatic_profiles_compute()
void cs_atmo_hydrostatic_profiles_compute ( void  )
This function solves the following transport equation on $ \varia $:
\[ \divs \left( \grad \varia \right) = \divs \left( \dfrac{\vect{g}}{c_p \theta} \right) \]
where $ \vect{g} $ is the gravity field and $ \theta $ is the potential temperature.
The boundary conditions on $ \varia $ read:
\[ \varia = \left(\dfrac{P_{sea}}{p_s}\right)^{R/C_p} \textrm{on the ground} \]
and Neumann elsewhere.
◆ cs_atmo_init_meteo_profiles()
void cs_atmo_init_meteo_profiles ( void  )
◆ cs_atmo_log_setup()
void cs_atmo_log_setup ( void  )
◆ cs_atmo_set_aero_conc_file_name()
void cs_atmo_set_aero_conc_file_name ( const char *  file_name)
◆ cs_atmo_set_chem_conc_file_name()
void cs_atmo_set_chem_conc_file_name ( const char *  file_name)
◆ cs_atmo_set_meteo_file_name()
void cs_atmo_set_meteo_file_name ( const char *  file_name)
◆ cs_atmo_z_ground_compute()
void cs_atmo_z_ground_compute ( void  )
\[ \dfrac{\partial \varia}{\partial t} + \divs \left( \varia \vect{g} \right) - \divs \left( \vect{V} \right) \varia = 0 \]
\[ \varia = z \textrm{ on walls} \]
\[ \dfrac{\partial \varia}{\partial n} = 0 \textrm{ elsewhere} \]
Remarks:
  • a steady state is looked for.
Remarks:
◆ cs_mo_phih()
cs_real_t cs_mo_phih ( cs_real_t  z,
cs_real_t  dlmo
[in]zaltitude
[in]dlmoInverse Monin Obukhov length
factor
◆ cs_mo_phim()
cs_real_t cs_mo_phim ( cs_real_t  z,
cs_real_t  dlmo
[in]zaltitude
factor
◆ cs_mo_psih()
cs_real_t cs_mo_psih ( cs_real_t  z,
cs_real_t  z0,
cs_real_t  dlmo
[in]zaltitude
[in]z0roughness
factor
◆ cs_mo_psim()
cs_real_t cs_mo_psim ( cs_real_t  z,
cs_real_t  z0,
cs_real_t  dlmo
[in]zaltitude
[in]z0roughness
factor
◆ cs_glob_atmo_chemistry
cs_atmo_chemistry_t* cs_glob_atmo_chemistry
◆ cs_glob_atmo_constants
cs_atmo_constants_t* cs_glob_atmo_constants
◆ cs_glob_atmo_option
cs_atmo_option_t* cs_glob_atmo_option
