cs_lagr_source_terms_t Struct Reference
#include <cs_lagr.h>
+ Collaboration diagram for cs_lagr_source_terms_t:
Data Fields
int ltsdyn
int ltsmas
int ltsthe
int itsli
int itske
int itste
int itsti
int itsmas
int * itsmv1
int * itsmv2
int itsco
int itsfp4
int nstits
int npts
int ntxerr
cs_real_t vmax
cs_real_t tmamax
cs_real_tst_val
2-way coupling and source term information.
Field Documentation
◆ itsco
int itsco
source term for the carbon released during heterogeneous combustion
◆ itsfp4
int itsfp4
variance of the air scalar
◆ itske
int itske
◆ itsli
int itsli
implicit source term for the continuous phase velocity and for the turbulent energy if the $k-\varepsilon$ model is used
◆ itsmas
int itsmas
mass source term
◆ itsmv1
int* itsmv1
◆ itsmv2
int* itsmv2
◆ itste
int itste
explicit thermal source term for the thermal scalar of the continuous phase
◆ itsti
int itsti
implicit thermal source term for the thermal scalar of the continuous phase
◆ ltsdyn
int ltsdyn
activation (=1) or not (=0) of the two-way coupling on the dynamics of the continuous phase. Useful if iilagr = CS_LAGR_TWOWAY_COUPLING and iccvfg = 0
◆ ltsmas
int ltsmas
activation (=1) or not (=0) of the two-way coupling on the mass. Useful if iilagr = CS_LAGR_TWOWAY_COUPLING, physical_model = 1 and impvar = 1
◆ ltsthe
int ltsthe
◆ npts
int npts
number of time steps for source terms accumulations
◆ nstits
int nstits
number of absolute time steps (including the restarts) after which a time-average of the two-way coupling source terms is calculated. Indeed, if the flow is steady (isttio=1), the average quantities that appear in the two-way coupling source terms can be calculated over different time steps, in order to get a better precision. if the number of absolute time steps is strictly inferior to nstits, the code considers that the flow has not yet reached its steady state (transition period) and the averages appearing in the source terms are reinitialized at each time step, as it is the case for unsteady flows (isttio=0). Useful if iilagr = CS_LAGR_TWOWAY_COUPLING and isttio=1
◆ ntxerr
int ntxerr
number of cells, whose vulumetric rate DODO (concentration ?)is greather than 0.8
◆ st_val
cs_real_t* st_val
source term values
◆ tmamax
cs_real_t tmamax
maximum massic concentration reached
◆ vmax
cs_real_t vmax
maximum volumetric concentration reached
