cs_lagr_time_scheme_t Struct Reference
#include <cs_lagr.h>
+ Collaboration diagram for cs_lagr_time_scheme_t:
Data Fields
int iilagr
int isttio
int isuila
int t_order
int ilapoi
int iadded_mass
cs_real_t added_mass_const
Time and coupling scheme for the Lagrangian module
Field Documentation
◆ added_mass_const
Added-mass constant ( $ C_A = 1$)
◆ iadded_mass
int iadded_mass
activation (=1) or not (=0) of the added-mass term.
\[ \DP{u_p} = - \dfrac{1}{\rho_p} \grad P + \dfrac{u_s-u_p}{\tau_p} + g +1/2 C_A \dfrac{\rho_f}{\rho_p} \left( \dfrac{Du}{Dt}-\DP{u_p} \right) \]
and
\[ \rho_f \dfrac{Du}{Dt} \simeq - \grad P + \rho_f g \]
with $ C_A = 1$. Then
\[ \DP{u_p} = - \dfrac{1}{\rho_p} \dfrac{1+C_A/2} {1+C_A/2\dfrac{\rho_f}{\rho_p}} \grad P + \dfrac{u_s-u_p}{\widetilde{\tau}_p} + g \]
with
\[ \widetilde{\tau_p} = (1 + C_A /2 \dfrac{\rho_f}{\rho_p}) \tau_p \]
◆ iilagr
int iilagr
Lagrangian module status.
  • CS_LAGR_OFF: Lagrangian module off
  • CS_LAGR_ONEWAY_COUPLING: Lagrangian two-phase flow in one-way coupling (no influence of the particles on the continuous phase)
  • CS_LAGR_TWOWAY_COUPLING: Lagrangian two-phase flow with two-way coupling (influence of the particles on the dynamics of the continuous phase). Dynamics, temperature and mass may be coupled independently.
  • CS_LAGR_FROZEN_CONTINUOUS_PHASE: Lagrangian two-phase flow on frozen i continuous phase. This option may only be used in the case of a calculation restart. All the Eulerian fields are frozen (including the scalar fields). This option automatically implies iccvfg = 1
◆ ilapoi
int ilapoi
activation (=1) or not (=0) of the solution of a Poisson's equation for the correction of the particle instantaneous velocities (in order to obtain a null divergence). this option is not validated and reserved to the development team. Do not change the default value
◆ isttio
int isttio
◆ isuila
int isuila
activation (=1) or not (=0) of a Lagrangian calculation restart. The calculation restart file read when this option is activated only contains the data related to the particles; the global calculation must also be a restart calculation
◆ t_order
int t_order
trajectory algorithm order in time
