ppincl.f90 File Reference
General module for specific physics. More...
Modules
module  ppincl
Functions/Subroutines
subroutine pp_models_init
 Initialize Fortran physical models properties API. This maps Fortran pointers to global C variables. More...
integer nmodmx
 number of specific physics More...
integer(c_int), dimension(:), pointer, save ippmod
 global indicator for speciphic physics By default, all the indicators ippmod(i.....) are initialized to -1, which means that no specific physics is activated. More...
integer iphpar
 ippmod(iphpar) is a global indicator for the specific physics: More...
integer icod3p
 pointer for specific physics More...
integer icoebu
 pointer to specify Eddy Break Up pre-mixed flame with indicator ippmod(icoebu) More...
integer icolwc
 pointer to specify Libby-Williams pre-mixed flame withy indicator ippmod(icolwc) More...
integer(c_int), pointer, save isoot
integer ieljou
 pointer to specify Joule effect module (Laplace forces not taken into account) with indicator ippmod(ieljou): More...
integer ielarc
 pointer to specify Electric arcs module (Joule effect and Laplace forces) with indicator ippmod(ielarc): More...
integer icpl3c
 pointer to specify Lagrangian modelling of multi-coals and multi-classes pulverised coal combustion with indicator ippmod(icpl3c). The number of different coals must be inferior or equal to ncharm = 3. The number of particle size classes nclpch(icha) for the coal icha, must be inferior or equal to ncpcmx = 10. More...
integer iccoal
 pointer to specify multi-coals and multi-classes pulverised coal combustion with indicator ippmod(iccoal). The number of different coals must be inferior or equal to ncharm = 3. The number of particle size classes nclpch(icha) for the coal icha, must be inferior or equal to ncpcmx = 10. More...
integer i_comb_drift
 coal with drift (0: without drift (default), 1: with) More...
integer icfuel
 pointer to specify multi-classes pulverised heavy fuel combustion with indicator ippmod(icfuel) More...
integer icompf
 pointer to specify compressible module with indicator ippmod(icompf) More...
integer iatmos
 pointer to specify atmospheric flow module with indicator ippmod(iatmos) More...
integer iaeros
 pointer to specify cooling towers module with indicator ippmod(iaeros) More...
integer igmix
 pointer to specify gas mixture module with indicator ippmod(igmix) More...
integer idarcy
 pointer to specify richards model More...
integer, save icondb
 Specific condensation modelling if = -1 module not activated if = 0 condensation source terms activated. More...
integer, save icondv
 Specific condensation modelling if = -1 module not activated if = 0 condensation source terms with metal structures activate. More...
integer, save ifm
 pointer to specify the mixing rate in isca(ifm) More...
integer, save ifp2m
 pointer to specify the variance of the mixing rate in isca(ifp2m) More...
integer, save iygfm
 pointer to specify the fresh gas mass fraction in isca(iygfm) More...
integer, save icm
 the intersection computation mode. If its value is: More...
integer, save icp2m
 transported variable More...
integer, save ifpcpm
integer, save iyfm
integer, save iyfp2m
integer, save icoyfp
integer, dimension(ngazgm), save iym
 mass fractions : More...
integer, dimension(ngazgm), save ibym
integer, save itemp
 state variable (temperature) More...
integer, save ifmin
 state variable More...
integer, save ifmax
integer, save ickabs
 state variable: absorption coefficient, when the radiation modelling is activated More...
integer, save it3m
 state variable: $T^3$ term, when the radiation modelling is activated More...
integer, save it4m
 state variable: $T^4$ term, when the radiation modelling is activated More...
integer, save itsc
integer, save inpm
 pointer for soot precursor number in isca (isoot = 1) More...
integer, save ifsm
 pointer for soot mass fraction in isca (isoot = 1) More...
integer, dimension(ncharm), save if1m
 mean value of the tracer 1 representing the light volatiles released by the coal icha More...
integer, dimension(ncharm), save if2m
 mean value of the tracer 2 representing the heavy volatiles released by the coal icha More...
integer, save if3m
 mean value of the tracer 3 representing the carbon released as CO during coke burnout More...
integer, save if4m
 transported variable of countinuous phase (gas mixture) More...
integer, save if5m
integer, save if6m
integer, save if7m
integer, save if8m
integer, save if9m
integer, save if4p2m
 the variance associated with the tracer 4 representing the air (the mean value of this tracer is not transported, it can be deduced directly from the three others) More...
integer, save ifvp2m
 f1f2 variance More...
integer, dimension(nclcpm), save ixck
 coke mass fraction related to the class icla More...
integer, dimension(nclcpm), save ixch
 reactive coal mass fraction related to the class icla More...
integer, dimension(nclcpm), save inp
 number of particles of the class icla per kg of air-coal mixture More...
integer, dimension(nclcpm), save ih2
 mass enthalpy of the coal of class icla, if we are in permeatic conditions More...
integer, dimension(nclcpm), save ixwt
 transported variable of dispersed phase (particle class) More...
integer, dimension(nclcpm), save inagecp
 Pointer to Np*age(particles) More...
integer, save iage
 Pointer to age of bulk. More...
integer, dimension(nclcpm), save iv_p_x
integer, dimension(nclcpm), save iv_p_y
integer, dimension(nclcpm), save iv_p_z
integer, dimension(ngazem), save iym1
 mass fractions: More...
integer, save irom1
 State variables of continuous phase (gas mixture) More...
integer, save immel
 molar mass of the gas mixture More...
integer, dimension(nclcpm), save itemp2
 temperature of the particles of the class icla More...
integer, dimension(nclcpm), save irom2
 density of the particles of the class icla More...
integer, dimension(nclcpm), save idiam2
 diameter of the particles of the class icla More...
integer, dimension(nclcpm), save ix2
 solid mass fraction of the class icla More...
integer, dimension(nclcpm), save igmdch
 disappearance rate of the reactive coal of the class icla More...
integer, dimension(nclcpm), save igmhet
 coke disappearance rate of the coke burnout of the class icla More...
integer, dimension(nclcpm), save igmtr
 Implicite part of the exchanges to the gas by molecular distribution. More...
integer, dimension(nclcpm), save ighco2
 State variables of dispersed phase (particles class) More...
integer, dimension(nclcpm), save igmdv1
 mass transfer caused by the release of light volatiles of the class icla More...
integer, dimension(nclcpm), save igmdv2
 mass transfer caused by the release of heavy volatiles of the class icla More...
integer, dimension(nclcpm), save igmsec
integer, save ibcarbone
 Used for bulk balance of Carbon. More...
integer, save iboxygen
 Used for bulk balance of Oxygen. More...
integer, save ibhydrogen
 Used for bulk balance of Hydrogen. More...
integer, save ifvap
 transported variable of continuous phase More...
integer, dimension(nclcpm), save ihlf
 transported variable of dispersed phase More...
integer, dimension(nclcpm), save ixkf
integer, dimension(nclcpm), save ixfol
integer, dimension(nclcpm), save ing
integer, dimension(nclcpm), save iyfol
 state variable of continuous phase More...
integer, dimension(nclcpm), save ih1hlf
 state variable of dispersed phase More...
integer, dimension(nclcpm), save igmhtf
integer, dimension(nclcpm), save igmeva
integer, save ienerg
 specific total energy for compressible algorithm More...
integer, save itempk
 temperature deduced from the specific total energy More...
integer, save ifracv
integer, save ifracm
integer, save ifrace
integer, save iviscv
 additional property: More...
integer, save irun
 alias for boundary conditions More...
integer, save irunh
real(c_double), pointer, save viscv0
 reference volume viscosity More...
integer, save ippred
 pressure predicion by an evolution equation More...
integer, save igrdpp
 indicates whether the pressure should be updated (=1) or not (=0) after the solution of the acoustic equation always usef More...
integer, save icfgrp
 indicates if the boundary conditions should take into account (=1) or not (=0) the hydrostatic balance. More...
double precision molmass_rat
 Molar mass ratio = Ratio of the molar mass (H2O) over the molar mass (air) More...
integer, save iyml
 Pointer to define mass fraction of liquid water which is injected in the packing. More...
integer, save iy_p_l
 Pointer to define mass fraction of liquid water which is injected in the rain zones. More...
integer, save it_p_l
 Pointer to define the temperature of liquide water in rain zone (in fact Y_l.T_l) More...
integer, save itml
 Pointer to define the temperature (property, deduced from enthalpy) of liquid water which is injected in the packing. More...
integer, save ihml
 Pointer to define the field enthalpy of liquid water. More...
integer, save ihumid
 Pointer to define the air humidity. More...
integer, save ivertvel
 Pointer to define the vertical velocity of liquid water. More...
integer, save ihm
 enthalpy, if transported or if deduced More...
double precision, save srrom
integer, dimension(nozppm), save iqimp
 imposed flow zone indicator in a way which is similar to the process described in the framework of the EBU module, the user chooses for every inlet face to impose the mass flow or not (iqimp(izone)=1 or 0). If the mass flow is imposed, the user must set the air mass flow value qimpat(izone), its direction in rcodcl(ifac,iu), rcodcl(ifac,iv) and rcodcl(ifac,iw) and the incoming air temperature timpat(izone) in Kelvin. If the velocity is imposed, he has to set rcodcl(ifac,iu), rcodcl(ifac,iv), and rcodcl(ifac,iw). More...
integer, dimension(nozppm), save icalke
 condition type turbulence indicator More...
double precision, dimension(nozppm), save xintur
 turbulent intensity (k=1.5(uref*xintur)**2) More...
double precision, dimension(nozppm), save dh
 hydraulic diameter More...
integer, save nozapm
 index of maximum reached boundary zone More...
integer, save nzfppp
 number of boundary zones on current process More...
integer, dimension(nbzppm), save ilzppp
 list of boundary zones index More...
