+ Collaboration diagram for Compressible module:
Modules
 Homogeneous two-phase flow model
 Physical properties
Data Types
struct  cs_cf_model_t
 Compressible model general options descriptor. More...
integer(c_int), pointer, save ieos
 indicator of equation of state mapping cs_cf_model_t::ieos More...
integer(c_int), pointer, save ithvar
 thermodynamic variables indicator for initialization mapping cs_cf_model_t::ithvar More...
integer, dimension(:), allocatable ifbet
 imposed thermal flux indicator at the boundary (some boundary contributions of the total energy eq. have to be cancelled) More...
integer, dimension(:), allocatable icvfli
 boundary convection flux indicator of a Rusanov or an analytical flux (some boundary contributions of the momentum eq. have to be cancelled) More...
real(c_double), pointer, save psginf
 Stiffened gas limit pressure (Pa) for single phase model Equal to zero in perfect gas mapping cs_cf_model_t::psginf. More...
real(c_double), pointer, save gammasg
 Stiffened gas polytropic coefficient (dimensionless) for single phase model mapping cs_cf_model_t::gammasg. More...
integer, save ienerg
 specific total energy for compressible algorithm More...
integer, save itempk
 temperature deduced from the specific total energy More...
int ieos
int ithvar
double psginf
double gammasg
◆ gammasg [1/2]
gammasg
stiffened gas polytropic coefficient (dimensionless) for single phase model
◆ gammasg [2/2]
◆ icvfli
◆ ienerg
◆ ieos [1/2]
◆ ieos [2/2]
ieos
  • CS_EOS_IDEAL_GAS: ideal gas with a constant adiabatic coefficient
  • CS_EOS_STIFFENED_GAS: stiffened gas
  • CS_EOS_GAS_MIX: mix of ideal gas
  • CS_EOS_HOMOGENEOUS_TWO_PHASE: two-phase homogeneous model only, each phase follows a stiffened gas law.
◆ ifbet
◆ itempk
◆ ithvar [1/2]
◆ ithvar [2/2]
ithvar
indicator for thermodynamic variables initialization
◆ psginf [1/2]
psginf
stiffened gas limit pressure (zero in perfect gas) for single phase model in Pa
◆ psginf [2/2]
