field_clear_key_int_bits Interface Reference
Set integer bits matching a mask to 0 for a given key for a field. More...
+ Collaboration diagram for field_clear_key_int_bits:
Public Member Functions
subroutine field_clear_key_int_bits (f_id, k_id, k_value)
If the key id is not valid, or the value type or field category is not compatible, a fatal error is provoked.
[in]f_idfield id
[in]k_idid of associated key
[in]maskassociated mask
Constructor & Destructor Documentation
◆ field_clear_key_int_bits()
subroutine field_clear_key_int_bits ( integer(c_int), value  f_id,
integer(c_int), value  k_id,
integer(c_int), value  k_value
The documentation for this interface was generated from the following file:
