subroutine | field_create (name, type_flag, location_id, dim, has_previous, id) |
| Define a field. More...
subroutine | field_find_or_create (name, type_flag, location_id, dim, id) |
| Return the id of a field matching a given name and attributes, creating it if necessary. More...
subroutine | field_get_n_fields (nfld) |
| Return the number of defined fields. More...
subroutine | field_get_id (name, id) |
| Return an id associated with a given field name. More...
subroutine | field_get_location (f_id, f_loc) |
| Return the location of a given field. More...
subroutine | field_get_id_try (name, id) |
| Return an id associated with a given field name if present. More...
subroutine | field_get_name (f_id, name) |
| Return a given field's name. More...
subroutine | field_get_dim (f_id, f_dim) |
| Return a given field's dimension. More...
subroutine | field_get_ownership (f_id, f_is_owner) |
| Return the field ownership flag. More...
subroutine | field_get_type (f_id, f_type) |
| Return a given field's type. More...
subroutine | field_have_previous (f_id, have_previous) |
| Indicate if a field maintains values at the previous time step. More...
subroutine | field_lock_key (f_id, k_id) |
| Interface to C function locking a key value. More...
subroutine | field_set_n_previous (f_id, n_previous) |
| Modify a field's handling of values at the previous time step. More...
subroutine | field_get_n_previous (f_id, f_n) |
| Return a given field's number of previous values. More...
subroutine | field_allocate_values (id) |
| Allocate field's value arrays. More...
subroutine | field_allocate_bc_coeffs (id, have_flux_bc, have_mom_bc, have_conv_bc, have_exch_bc) |
| Allocate boundary condition coefficient arrays if applicable. More...
subroutine | field_init_bc_coeffs (id) |
| Initialize boundary condition coefficient arrays if applicable. More...
subroutine | field_current_to_previous (id) |
| Copy current values to previous values. More...
subroutine | field_is_key_set (f_id, k_id, is_set) |
| Query if a given key has been set for a field. More...
subroutine | field_get_key_id (name, id) |
| Return an id associated with a given key name if present. More...
subroutine | field_get_key_int (f_id, k_id, k_value) |
| Return an integer value for a given key associated with a field. More...
subroutine | field_get_key_int_by_name (f_id, k_name, k_value) |
subroutine | field_get_key_double (f_id, k_id, k_value) |
| Return a floating-point value for a given key associated with a field. More...
subroutine | field_set_key_str (f_id, k_id, str) |
| Assign a character string for a given key to a field. More...
subroutine | field_get_key_str (f_id, k_id, str) |
| Return a character string for a given key associated with a field. More...
subroutine | fldsnv (name1, name2, name3) |
subroutine | field_get_label (f_id, str) |
| Return a label associated with a field. More...
subroutine | field_get_val_s (field_id, p) |
| Return pointer to the values array of a given scalar field. More...
subroutine | field_get_val_s_by_name (name, p) |
subroutine | field_get_val_prev_s_by_name (name, p) |
| Return pointer to the array's previous values of a given scalar field. More...
subroutine | field_get_val_v (field_id, p) |
| Return pointer to the values array of a given vector field. More...
subroutine | field_get_val_v_by_name (name, p) |
subroutine | field_get_val_prev_v_by_name (name, p) |
| Return pointer to the array's previous values of a given vector field. More...
subroutine | field_get_val_prev_s (field_id, p) |
| Return pointer to the previous values array of a given scalar field. More...
subroutine | field_get_val_prev2_s (field_id, p) |
subroutine | field_get_val_prev_s_try (field_id, p) |
| Return pointer to the previous values array of a given scalar field if it exists, to the current value otherwise. More...
subroutine | field_get_val_prev_v (field_id, p) |
| Return pointer to the previous values array of a given vector field. More...
subroutine | field_get_coefa_s (field_id, p) |
| Return pointer to the coefa array of a given scalar field. More...
subroutine | field_get_coefa_v (field_id, p) |
| Return pointer to the coefa array of a given vector field. More...
subroutine | field_get_coefad_s (field_id, p) |
| Return pointer to the coefad array of a given scalar field (used in the divergence operator such as div(Rij)) More...
subroutine | field_get_coefad_v (field_id, p) |
| Return pointer to the coefa array of a given vector field (used in the divergence operator such as div(u'T')) More...
subroutine | field_get_coefac_v (field_id, p) |
| Return pointer to the coefac array of a given vector field. More...
subroutine | field_get_coefb_s (field_id, p) |
| Return pointer to the coefb array of a given scalar field. More...
subroutine | field_get_coefbc_s (field_id, p) |
| Return pointer to the coefbc array of a given scalar field. More...
subroutine | field_get_coefb_uv (field_id, p) |
| Return pointer to the coefb array of a given uncoupled vector field. More...
subroutine | field_get_coefbc_uv (field_id, p) |
| Return pointer to the coefbc array of a given uncoupled vector field. More...
subroutine | field_get_coefb_v (field_id, p) |
| Return pointer to the coefb array of a given coupled vector field. More...
subroutine | field_get_coefbc_v (field_id, p) |
| Return pointer to the coefbc array of a given coupled vector field. More...
subroutine | field_get_coefaf_s (field_id, p) |
| Return pointer to the coefaf array of a given scalar field. More...
subroutine | field_get_coefac_s (field_id, p) |
| Return pointer to the coefac array of a given scalar field. More...
subroutine | field_get_coefaf_v (field_id, p) |
| Return pointer to the coefaf array of a given vector field. More...
subroutine | field_get_coefbf_s (field_id, p) |
| Return pointer to the coefbf array of a given scalar field. More...
subroutine | field_get_coefbf_uv (field_id, p) |
| Return pointer to the coefbf array of a given uncoupled vector field. More...
subroutine | field_get_coefbf_v (field_id, p) |
| Return pointer to the coefbf array of a given coupled vector field. More...
subroutine | field_get_coefbd_s (field_id, p) |
| Return pointer to the coefbd array of a given scalar field (used in the divergence operator such as div(Rij)) More...
subroutine | field_get_coefbd_v (field_id, p) |
| Return pointer to the coefbd array of a given coupled vector field (used in the divergence operator such as div(u'T')) More...
subroutine | field_get_hext (field_id, p) |
| Return pointer to the hext array of a given variable field. More...
subroutine | field_get_hint (field_id, p) |
| Return pointer to the hint array of a given variable field. More...
Module for field-related operations.
