integer(c_int), pointer, save | ischtp |
time order of time stepping More... | |
integer, save | istmpf |
time order of the mass flux scheme The chosen value for istmpf will automatically determine the value given to the variable thetfl. More... | |
integer(c_int), pointer, save | nterup |
number of iterations on the velocity-pressure coupling on Navier-Stokes (for the U/P inner iterations scheme) More... | |
integer, save | isno2t |
isno2t specifies the time scheme activated for the source terms of the momentum equation, apart from convection and diffusion (for instance: head loss, transposed gradient, ...). More... | |
integer(c_int), pointer, save | isto2t |
Time scheme for source terms of turbulence equations (see isto2t in cs_time_scheme_t). More... | |
integer, dimension(nscamx), save | isso2t |
for each scalar, isso2t specifies the time scheme activated for the source terms of the equation for the scalar, apart from convection and diffusion (for instance: variance production, user-specified terms, ...). More... | |
integer, save | initvi |
initvi : =1 if total viscosity read from checkpoint file More... | |
integer, save | initro |
initro : =1 if density read from checkpoint file More... | |
integer, save | initcp |
initcp : =1 if specific heat read from checkpoint file More... | |
integer, dimension(nscamx), save | initvs |
initvs : =1 if scalar diffusivity read from checkpoint file More... | |
double precision, save | thetsn |
![]() ![]() ![]() The value of ![]() | |
real(c_double), pointer, save | thetst |
double precision, dimension(nscamx), save | thetss |
double precision, save | thetvi |
double precision, save | thetcp |
double precision, dimension(nscamx), save | thetvs |
real(c_double), pointer, save | epsup |
relative precision for the convergence test of the iterative process on velocity-pressure coupling (inner iterations) More... | |
real(c_double), pointer, save | xnrmu |
norm of the increment ![]() | |
real(c_double), pointer, save | xnrmu0 |
norm of ![]() | |
real(c_double), pointer, save epsup |
integer, save initcp |
integer, save initro |
integer, save initvi |
integer, dimension(nscamx), save initvs |
integer(c_int), pointer, save ischtp |
integer, save isno2t |
integer, dimension(nscamx), save isso2t |
integer, save istmpf |
integer(c_int), pointer, save isto2t |
integer(c_int), pointer, save nterup |
double precision, save thetcp |
-scheme for the extrapolation of the physical property
"specific heat" when the extrapolation has been activated (see time_extrapolated field key int), according to the formula
The value of = thetcp is deduced from the value chosen for the specific heat. Generally, only the value 0.5 is used.
double precision, save thetsn |
-scheme for the source terms
in the Navier-Stokes equations when the source term extrapolation has been activated (see isno2t), following the formula
The value of = thetsn is deduced from the value chosen for isno2t. Generally only the value 0.5 is used.
double precision, dimension(nscamx), save thetss |
-scheme for the extrapolation of the nonlinear explicit source term
of the scalar transport equation when the source term extrapolation has been activated (see isso2t), following the formula
The value of = thetss is deduced from the value chosen for isso2t. Generally, only the value 0.5 is used.
real(c_double), pointer, save thetst |
The value of (see thetst in cs_time_scheme_t).
double precision, save thetvi |
"total viscosity" when the extrapolation has been activated (see time_extrapolated key word), according to the formula
The value of = thetvi is deduced from the value chosen for time_extrapolated key word for the viscosity. Generally, only the value 0.5 is used.
double precision, dimension(nscamx), save thetvs |
"diffusivity" when the extrapolation has been activated (see time_extrapolated key word), according to the formula
The value of = thetvs is deduced from the value chosen for time_extrapolated key word. Generally, only the value 0.5 is used.
real(c_double), pointer, save xnrmu |
norm of the increment of the iterative process on velocity-pressure coupling (inner iterations)
real(c_double), pointer, save xnrmu0 |
norm of (used by velocity-pressure inner iterations)
