cs_user_radiative_transfer_bcs.c File Reference
#include "cs_headers.h"
+ Include dependency graph for cs_user_radiative_transfer_bcs.c:
void cs_user_radiative_transfer_bcs (int nvar, const int bc_type[], int icodcl[], int isothp[], cs_real_t *tmin, cs_real_t *tmax, cs_real_t *tx, const cs_real_t dt[], cs_real_t rcodcl[], const cs_real_t thwall[], const cs_real_t qincid[], cs_real_t hfcnvp[], cs_real_t flcnvp[], cs_real_t xlamp[], cs_real_t epap[], cs_real_t epsp[], cs_real_t textp[])
 User definition of radiative transfer boundary conditions. More...
◆ cs_user_radiative_transfer_bcs()
void cs_user_radiative_transfer_bcs ( int  nvar,
int  icodcl[],
int  isothp[],
cs_real_t tmin,
cs_real_t tmax,
cs_real_t tx,
cs_real_t  rcodcl[],
cs_real_t  hfcnvp[],
cs_real_t  flcnvp[],
cs_real_t  xlamp[],
cs_real_t  epap[],
cs_real_t  epsp[],
cs_real_t  textp[]
See Examples of data settings for radiative transfers for examples.
Warning
the temperature unit here is the Kelvin
Zone definitions
For each boundary face face_id, a specific output (logging and postprocessing) class id may be assigned. This allows realizing balance sheets by treating them separately for each zone. By default, the output class id is set to the general (input) zone id associated to a face.
To access output class ids (both for reading and modifying), use the cs_boundary_zone_face_class_id function. The zone id values are arbitrarily chosen by the user, but must be positive integers; very high numbers may also lead to higher memory consumption.
Wall characteristics
The following face characteristics must be set:
  • isothp(face_id) boundary face type
    • CS_BOUNDARY_RAD_WALL_GRAY: Gray wall with temperature based on fluid BCs
    • CS_BOUNDARY_RAD_WALL_GRAY_EXTERIOR_T: Gray wall with fixed outside temperature
    • CS_BOUNDARY_RAD_WALL_REFL_EXTERIOR_T: Reflecting wall with fixed outside temperature
    • CS_BOUNDARY_RAD_WALL_GRAY_COND_FLUX: Gray wall with fixed conduction flux
    • CS_BOUNDARY_RAD_WALL_REFL_COND_FLUX: Reflecting wall with fixed conduction flux
Depending on the value of isothp, other values may also need to be set:
  • rcodcl = conduction flux
  • epsp = emissivity
  • xlamp = conductivity (W/m/K)
  • epap = thickness (m)
  • textp = outside temperature (K)
[in]nvartotal number of variable BC's
[in]bc_typeboundary face types
[in]icodclboundary face code
[in]isothpboundary face type for radiative transfer
[out]tminmin allowed value of the wall temperature
[out]tmaxmax allowed value of the wall temperature
[in]txrelaxation coefficient (0 < tx < 1)
[in]dttime step (per cell)
[in]rcodclboundary condition values rcodcl(3) = flux density value (negative for gain) in W/m2
[in]thwallinside current wall temperature (K)
[in]qincidradiative incident flux (W/m2)
[in]hfcnvpconvective exchange coefficient (W/m2/K)
[in]flcnvpconvective flux (W/m2)
[out]xlampconductivity (W/m/K)
[out]epapthickness (m)
[out]epspemissivity (>0)
[out]textpoutside temperature (K)
