Definition of physical variable laws. More...
Functions/Subroutines | |
| subroutine | usphyv (nvar, nscal, mbrom, dt) |
| Definition of physical variable laws. More... | |
| subroutine | usvist (nvar, nscal, ncepdp, ncesmp, icepdc, icetsm, itypsm, dt, ckupdc, smacel) |
| Modify turbulent viscosity. More... | |
| subroutine | ussmag (nvar, nscal, ncepdp, ncesmp, icepdc, icetsm, itypsm, dt, ckupdc, smacel, mijlij, mijmij) |
| user modification of the Smagorinsky constant in the case of a dynamic model More... | |
See Define user laws for physical properties for examples.
| subroutine usphyv | ( | integer | nvar, |
| integer | nscal, | ||
| integer | mbrom, | ||
| double precision, dimension(ncelet) | dt | ||
It is forbidden to modify turbulent viscosity visct here (a specific subroutine is dedicated to that: usvist)
viscls.ro0)viscl0)Warning: if the scalar is the temperature, cpro_vscalt corresponds to its conductivity (Lambda) in W/(m K)
The types of boundary faces at the previous time step are available (except at the first time step, where arrays itypfb and itrifb have not been initialized yet)
It is recommended to keep only the minimum necessary in this file (i.e. remove all unused example code)
Cells may be identified using the getcel subroutine. The syntax of this subroutine is described in the cs_user_boundary_conditions subroutine, but a more thorough description can be found in the user guide.
| [in] | nscal | total number of scalars |
| [in] | mbrom | indicator of filling of romb array |
| subroutine ussmag | ( | integer | nvar, |
| integer | ncepdp, | ||
| integer | ncesmp, | ||
| integer, dimension(ncepdp) | icepdc, | ||
| integer, dimension(ncesmp) | icetsm, | ||
| integer, dimension(ncesmp,nvar) | itypsm, | ||
| double precision, dimension(ncelet) | dt, | ||
| double precision, dimension(6,ncepdp) | ckupdc, | ||
| double precision, dimension(ncesmp,nvar) | smacel, | ||
| double precision, dimension(ncelet) | mijlij, | ||
| double precision, dimension(ncelet) | mijmij | ||
SMAGOR = Mij.Lij / Mij.Mij
The local averages of the numerator and denominator are done before calling this subroutine, so
SMAGOR = < Mij.Lij > / < Mij.Mij >
In this subroutine, Mij.Lij and Mij.Mij are passed as arguments before the local average.
| [in] | ncepdp | number of cells with head loss |
| [in] | icepdc | head loss cell numbering |
| [in] | icetsm | numbering of cells with mass source term |
| [in] | itypsm | kind of mass source for each variable |
| [in] | ckupdc | work array for head loss terms |
| [in] | smacel | values of variables related to mass source term. If ivar=ipr, smacel=mass flux |
| [in] | mijlij | mij.lij before the local averaging |
| [in] | mijmij | mij.mij before the local averaging |
| subroutine usvist | ( | integer | nvar, |
| double precision, dimension(ncesmp,nvar) | smacel | ||
This subroutine is called at beginning of each time step after the computation of the turbulent viscosity (physical quantities have already been computed in usphyv).
Turbulent viscosity
(kg/(m s)) can be modified.
A modification of the turbulent viscosity can lead to very significant differences between solutions and even give wrong results.
This subroutine is therefore reserved to expert users.
