cs_user_mesh.c File Reference
Definition and modification of the calculation mesh. More...
#include <stdarg.h>
#include "cs_headers.h"
+ Include dependency graph for cs_user_mesh.c:
void cs_user_mesh_input (void)
 Define mesh files to read and optional associated transformations. More...
void cs_user_join (void)
 Define mesh joinings. More...
void cs_user_periodicity (void)
 Define periodic faces. More...
void cs_user_mesh_warping (void)
 Set options for cutting of warped faces. More...
void cs_user_mesh_boundary (cs_mesh_t *mesh)
 Insert boundaries into a mesh. More...
void cs_user_mesh_modify (cs_mesh_t *mesh)
 Modify geometry and mesh. More...
void cs_user_mesh_smoothe (cs_mesh_t *mesh)
 Mesh smoothing. More...
void cs_user_mesh_save (cs_mesh_t *mesh)
 Enable or disable mesh saving. More...
void cs_user_mesh_bad_cells_tag (cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
 Tag bad cells within the mesh based on user-defined geometric criteria. More...
void cs_user_mesh_modify_partial (cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
 Apply partial modifications to the mesh after the preprocessing and initial postprocessing mesh building stage. More...
void cs_user_mesh_cartesian_define (void)
 Define a cartesian mesh. More...
See Examples of mesh modifications for examples.
◆ cs_user_join()
void cs_user_join ( void  )
◆ cs_user_mesh_bad_cells_tag()
void cs_user_mesh_bad_cells_tag ( cs_mesh_t mesh,
cs_mesh_quantities_t mesh_quantities
[in,out]meshpointer to a cs_mesh_t structure
[in,out]mesh_quantitiespointer to a cs_mesh_quantities_t structure
◆ cs_user_mesh_boundary()
void cs_user_mesh_boundary ( cs_mesh_t mesh)
◆ cs_user_mesh_cartesian_define()
void cs_user_mesh_cartesian_define ( void  )
◆ cs_user_mesh_input()
void cs_user_mesh_input ( void  )
◆ cs_user_mesh_modify()
void cs_user_mesh_modify ( cs_mesh_t mesh)
◆ cs_user_mesh_modify_partial()
void cs_user_mesh_modify_partial ( cs_mesh_t mesh,
◆ cs_user_mesh_save()
void cs_user_mesh_save ( cs_mesh_t mesh)
By default, mesh is saved when modified.
◆ cs_user_mesh_smoothe()
void cs_user_mesh_smoothe ( cs_mesh_t mesh)
Mesh smoothing.
◆ cs_user_mesh_warping()
void cs_user_mesh_warping ( void  )
◆ cs_user_periodicity()
void cs_user_periodicity ( void  )
