cs_time_moment.h
1 #ifndef __CS_TIME_MOMENT_H__
2 #define __CS_TIME_MOMENT_H__
5  * Moments management
35  * Local headers
38 #include "cs_base.h"
39 #include "cs_field.h"
40 #include "cs_restart.h"
45
47  * Macro definitions
49
51  * Type definitions
53
54 /* Moment type */
55
56 typedef enum {
57
60
62
63 /* Moment restart behavior */
64
65 typedef enum {
66
70
72
73 /*----------------------------------------------------------------------------
74  * Function pointer for computation of data values for moments computation.
75  *
76  * If the matching values are multidimensional, they must be interleaved.
77  *
78  * Note: if the input pointer is non-NULL, it must point to valid data
79  * when the selection function is called, so either:
80  * - that value or structure should not be temporary (i.e. local);
81  * - post-processing output must be ensured using cs_post_write_meshes()
82  * with a fixed-mesh writer before the data pointed to goes out of scope;
83  *
84  * parameters:
85  * input <-- pointer to optional (untyped) value or structure.
86  * vals --> pointer to values (size: n_local elements*dimension)
87  *----------------------------------------------------------------------------*/
88
89 typedef void
90 (cs_time_moment_data_t) (const void *input,
91  cs_real_t *vals);
92
93 /*=============================================================================
94  * Global variables
95  *============================================================================*/
96
97 /* Names associated with moment types */
98
99 extern const char *cs_time_moment_type_name[];
100
101 /*============================================================================
102  * Public function prototypes
103  *============================================================================*/
104
105 /*----------------------------------------------------------------------------
106  * Destroy all moments management metadata.
107  *----------------------------------------------------------------------------*/
108
109 void
111
112 /*----------------------------------------------------------------------------
113  * Map time step values array for temporal moments.
114  *
115  * If this function is not called, the field referenced by field pointer
116  * CS_F_(dt) will be used instead.
117  *----------------------------------------------------------------------------*/
118
119 void
121
122 /*----------------------------------------------------------------------------
123  * Update all moment accumulators.
124  *----------------------------------------------------------------------------*/
125
126 void
128
129 /*----------------------------------------------------------------------------
130  * Return 1 if a moment is active, 0 if it is not active yet.
131  *
132  * parameters:
133  * moment_id <-- id of associated moment
134  *
135  * returns:
136  * 0 in case of success, 1 if moment accumulation has not started yet
137  *----------------------------------------------------------------------------*/
138
139 int
141
142 /*----------------------------------------------------------------------------
143  * Define a moment of a product of existing field components
144  *
145  * Moments will involve the tensor products of their component fields,
146  * and only scalar, vector, or rank-2 tensors are handled (for
147  * post-processing output reasons), so a moment may not involve more than
148  * 2 vectors or 1 tensor, unless single components are specified.
149  *
150  * If of dimension > 1, the moment array is always interleaved.
151  *
152  * parameters:
153  * name <-- name of associated moment
154  * n_fields <-- number of associated fields
155  * field_id <-- ids of associated fields
156  * component_id <-- ids of matching field components (-1 for all)
157  * type <-- moment type
158  * nt_start <-- starting time step (or -1 to use t_start)
159  * t_start <-- starting time
160  * restart_mode <-- behavior in case of restart (reset, auto, or strict)
161  * restart_name <-- if not NULL, previous name in case of restart
162  *
163  * returns:
164  * id of new moment in case of success, -1 in case of error.
165  *----------------------------------------------------------------------------*/
166
167 int
168 cs_time_moment_define_by_field_ids(const char *name,
169  int n_fields,
170  const int field_id[],
171  const int component_id[],
173  int nt_start,
174  double t_start,
175  cs_time_moment_restart_t restart_mode,
176  const char *restart_name);
177
178 /*----------------------------------------------------------------------------
179  * Define a moment whose data values will be computed using a
180  * specified function.
181  *
182  * If of dimension > 1, the moment array is always interleaved.
183  *
184  * parameters:
185  * name <-- name of associated moment
186  * location_id <-- id of associated mesh location
187  * dim <-- dimension associated with element data
188  * data_func <-- function used to define data values
189  * data_input <-- pointer to optional (untyped) value or structure
190  * to be used by data_func
191  * weight_func <-- function used to define weight values
192  * weight_input <-- pointer to optional (untyped) value or structure
193  * to be used by weight_func
194  * type <-- moment type
195  * nt_start <-- starting time step (or -1 to use t_start)
196  * t_start <-- starting time
197  * restart_mode <-- behavior in case of restart (reset, auto, or strict)
198  * restart_name <-- if not NULL, previous name in case of restart
199  *
200  * returns:
201  * id of new moment in case of success, -1 in case of error.
202  *----------------------------------------------------------------------------*/
203
204 int
205 cs_time_moment_define_by_func(const char *name,
206  int location_id,
207  int dim,
208  cs_time_moment_data_t *data_func,
209  const void *data_input,
210  cs_time_moment_data_t *w_data_func,
211  void *w_data_input,
213  int nt_start,
214  double t_start,
215  cs_time_moment_restart_t restart_mode,
216  const char *restart_name);
217
218 /*----------------------------------------------------------------------------
219  * Return the number of defined time moments.
220  *
221  * returns:
222  * number of defined time moments
223  *----------------------------------------------------------------------------*/
224
225 int
227
228 /*----------------------------------------------------------------------------
229  * Return the number of time moments in the restart file, if any
230  *
231  * returns:
232  * number of defined moments in restart file, or 0
233  *----------------------------------------------------------------------------*/
234
235 int
237
238 /*----------------------------------------------------------------------------
239  * Define a moment restart mode and name by an id.
240  *
241  * This is a utility function, to allow simplification of automatic setups.
242  * It must be called just before defining a moment to work properly if
243  * restart_id < -1 (automatic mode).
244  *
245  * parameters:
246  * restart_id <-- -2: automatic, -1: reset, >= 0: id of
247  * matching moment in restart data
248  * restart_mode --> matching restart mode
249  * restart_name --> matching restart name
250  *----------------------------------------------------------------------------*/
251
252 void
254  cs_time_moment_restart_t *restart_mode,
255  const char **restart_name);
256
257 /*----------------------------------------------------------------------------
258  * Return name of a given time moments in the restart file, if any
259  * (check also \ref cs_time_moment_n_moments_restart).
260  *
261  * parameters:
262  * restart_id <-- id of time moment in restart data
263  *
264  * returns:
265  * name of defined moment in restart file, or NULL
266  *----------------------------------------------------------------------------*/
267
268 const char *
269 cs_time_moment_restart_name(int restart_id);
270
271 /*----------------------------------------------------------------------------
272  * Return pointer to field associated with a given moment.
273  *
274  * For moments defined automatically to assist computation of higher
275  * order moments, which do not have an associated field, NULL is returned.
276  *
277  * parameters:
278  * moment_id <-- id of associated moment
279  *
280  * returns:
281  * pointer to field associated with given moment, or NULL
282  *----------------------------------------------------------------------------*/
283
284 cs_field_t *
286
287 /*----------------------------------------------------------------------------
288  * Return 1 if moment is active, 0 if it is not active yet.
289  *
290  * parameters:
291  * moment_id <-- id of associated moment
292  *
293  * returns:
294  * 1 if moment is active, 0 if it is not active yet
295  *----------------------------------------------------------------------------*/
296
297 int
299
300 /*----------------------------------------------------------------------------*/
306 /*----------------------------------------------------------------------------*/
307
308 void
310
311 /*----------------------------------------------------------------------------
312  * Update all moment accumulators.
313  ----------------------------------------------------------------------------*/
314
315 void
317
318 /*----------------------------------------------------------------------------
319  * Log moment definition setup information.
320  *----------------------------------------------------------------------------*/
321
322 void
324
325 /*----------------------------------------------------------------------------
326  * Log moment definition information for a given iteration.
327  *----------------------------------------------------------------------------*/
328
329 void
331
332 /*----------------------------------------------------------------------------
333  * Indicate if restart API should use "main" instead of "auxiliary" file.
334  *
335  * parameters:
336  * use_main <-- use "main" restart if nonzero, "auxiliary" otherwise
337  *----------------------------------------------------------------------------*/
338
339 void
340 cs_time_moment_restart_use_main(int use_main);
341
342 /*----------------------------------------------------------------------------
343  * Read restart moment data
344  *
345  * parameters:
346  * <-> restart associated restart file pointer
347  *----------------------------------------------------------------------------*/
348
349 void
351
352 /*----------------------------------------------------------------------------
353  * Checkpoint moment data
354  *
355  * parameters:
356  * <-> restart associated restart file pointer
357  *----------------------------------------------------------------------------*/
358
359 void
361
362 /*----------------------------------------------------------------------------*/
363
365
366 #endif /* __CS_TIME_MOMENT_H__ */
const char * cs_time_moment_restart_name(int restart_id)
Return name of a given time moments in the restart file, if any (check also cs_time_moment_n_moments_...
Definition: cs_time_moment.c:1813
void cs_time_moment_destroy_all(void)
Definition: cs_time_moment.c:1487
void cs_time_moment_map_cell_dt(const cs_real_t *dt)
Definition: cs_time_moment.c:1962
Definition: cs_field.h:125
int cs_time_moment_define_by_func(const char *name, int location_id, int dim, cs_time_moment_data_t *data_func, const void *data_input, cs_time_moment_data_t *w_data_func, void *w_data_input, cs_time_moment_type_t type, int nt_start, double t_start, cs_time_moment_restart_t restart_mode, const char *restart_name)
Define a moment whose data values will be computed using a specified function.
Definition: cs_time_moment.c:1579
const char * cs_time_moment_type_name[]
Definition: cs_time_moment.c:243
int cs_time_moment_n_moments(void)
Definition: cs_time_moment.c:1740
Definition: cs_defs.h:495
Moment restart behavior.
Definition: cs_time_moment.h:65
void cs_time_moment_restart_write(cs_restart_t *restart)
Checkpoint moment data.
Definition: cs_time_moment.c:2648
void cs_time_moment_update_all(void)
Definition: cs_time_moment.c:1974
void() cs_time_moment_data_t(const void *input, cs_real_t *vals)
Definition: cs_time_moment.h:90
void cs_time_moment_restart_read(cs_restart_t *restart)
Read restart moment data.
Definition: cs_time_moment.c:2580
Moment type.
Definition: cs_time_moment.h:56
Definition: cs_time_moment.h:58
void cs_time_moment_restart_use_main(int use_main)
Definition: cs_time_moment.c:2563
Definition: cs_defs.h:307
int cs_time_moment_define_by_field_ids(const char *name, int n_fields, const int field_id[], const int component_id[], cs_time_moment_type_t type, int nt_start, double t_start, cs_time_moment_restart_t restart_mode, const char *restart_name)
Define a moment of a product of existing fields components.
Definition: cs_time_moment.c:1522
cs_field_t * cs_time_moment_get_field(int moment_id)
Definition: cs_time_moment.c:1842
void cs_time_moment_log_iteration(void)
Definition: cs_time_moment.c:2370
Definition: cs_restart.h:93
int cs_time_moment_n_moments_restart(void)
Return the number of time moments in the restart file, if any.
Definition: cs_time_moment.c:1754
void cs_time_moment_reset(int moment_id)
Reset a time moment.
Definition: cs_time_moment.c:1892
void cs_time_moment_log_setup(void)
Definition: cs_time_moment.c:2198
Definition: cs_defs.h:496
int cs_time_moment_is_active(int moment_id)
Definition: cs_time_moment.c:1866
Definition: cs_time_moment.h:69
void cs_time_moment_restart_options_by_id(int restart_id, cs_time_moment_restart_t *restart_mode, const char **restart_name)
Definition: cs_time_moment.c:1783
Definition: cs_time_moment.h:68
int moment_id
Definition: keywords.h:91
Definition: cs_time_moment.h:59
Definition: cs_time_moment.h:67
