#include <petscversion.h>
#include <petscconf.h>
#include <petscviewer.h>
#include <petscksp.h>
#include "cs_matrix.h"
#include "cs_sles.h"
| void | cs_user_sles_petsc_hook (void *context, KSP ksp) |
| cs_sles_petsc_t * | cs_sles_petsc_define (int f_id, const char *name, MatType matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context) |
| | Define and associate a PETSc linear system solver for a given field or equation name. More...
| cs_sles_petsc_t * | cs_sles_petsc_create (MatType matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context) |
| | Create PETSc linear system solver info and context. More...
| void * | cs_sles_petsc_copy (const void *context) |
| | Create PETSc linear system solver info and context based on existing info and context. More...
| void | cs_sles_petsc_destroy (void **context) |
| | Destroy PETSc linear system solver info and context. More...
| void | cs_sles_petsc_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| | Setup PETSc linear equation solver. More...
| cs_sles_convergence_state_t | cs_sles_petsc_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, cs_halo_rotation_t rotation_mode, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| | Call PETSc linear equation solver. More...
| void | cs_sles_petsc_free (void *context) |
| | Free PETSc linear equation solver setup context. More...
| bool | cs_sles_petsc_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, cs_halo_rotation_t rotation_mode, const cs_real_t *rhs, cs_real_t *vx) |
| | Error handler for PETSc solver. More...
| void | cs_sles_petsc_log (const void *context, cs_log_t log_type) |
| | Log sparse linear equation solver info. More...
◆ cs_sles_petsc_setup_hook_t
| cs_sles_petsc_setup_hook_t |
Function pointer for user settings of a PETSc KSP solver setup.
This function is called the end of the setup stage for a KSP solver.
Note that using the advanced KSPSetPostSolve and KSPSetPreSolve functions, this also allows setting further function pointers for pre and post-solve operations (see the PETSc documentation).
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that value or structure should not be temporary (i.e. local);
- Parameters
| [in,out] | context | pointer to optional (untyped) value or structure |
| [in,out] | ksp | pointer to PETSc KSP context |
◆ cs_sles_petsc_t
◆ cs_sles_petsc_copy()
| void* cs_sles_petsc_copy |
const void * |
context | ) |
- Parameters
| [in] | context | pointer to reference info and context (actual type: cs_sles_petsc_t *) |
- Returns
- pointer to newly created solver info object. (actual type: cs_sles_petsc_t *)
◆ cs_sles_petsc_create()
- Parameters
| [in] | matrix_type | PETSc matrix type |
| [in] | setup_hook | pointer to optional setup epilogue function |
| [in,out] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
- Returns
- pointer to associated linear system object.
◆ cs_sles_petsc_define()
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_petsc_create.
Note that this function returns a pointer directly to the iterative solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
- Parameters
- Returns
- pointer to newly created iterative solver info object.
◆ cs_sles_petsc_destroy()
| void cs_sles_petsc_destroy |
void ** |
context | ) |
- Parameters
| [in,out] | context | pointer to iterative solver info and context (actual type: cs_sles_petsc_t **) |
◆ cs_sles_petsc_error_post_and_abort()
In case of divergence or breakdown, this error handler outputs an error message It does nothing in case the maximum iteration count is reached.
- Parameters
| [in] | a | matrix |
- Returns
- false (do not attempt new solve)
◆ cs_sles_petsc_free()
| void cs_sles_petsc_free |
void * |
context | ) |
- Parameters
| [in,out] | context | pointer to iterative solver info and context (actual type: cs_sles_petsc_t *) |
◆ cs_sles_petsc_log()
| void cs_sles_petsc_log |
const void * |
context, |
cs_log_t |
log_type |
- Parameters
| [in] | context | pointer to iterative solver info and context (actual type: cs_sles_petsc_t *) |
◆ cs_sles_petsc_setup()
| void cs_sles_petsc_setup |
void * |
context, |
const char * |
name, |
const cs_matrix_t * |
a, |
int |
verbosity |
- Parameters
◆ cs_sles_petsc_solve()
| cs_sles_convergence_state_t cs_sles_petsc_solve |
void * |
context, |
const char * |
name, |
a, |
int |
verbosity, |
cs_halo_rotation_t |
rotation_mode, |
double |
precision, |
double |
r_norm, |
int * |
n_iter, |
double * |
residue, |
const cs_real_t * |
rhs, |
cs_real_t * |
vx, |
size_t |
aux_size, |
void * |
aux_vectors |
- Parameters
| [in] | a | matrix |
| [out] | residue | residue |
- Returns
- convergence state
◆ cs_user_sles_petsc_hook()
| void cs_user_sles_petsc_hook |
void * |
context, |
KSP |
ksp |
