Set of functions to handle the interface with the MUMPS library to solve sparse linear system with a direct approach.
More...
#include <dmumps_c.h>
#include "cs_halo_perio.h"
#include "cs_matrix.h"
#include "cs_time_plot.h"
#include "cs_sles.h"
typedef void() | cs_sles_mumps_setup_hook_t(void *context, DMUMPS_STRUC_C *dmumps) |
| Function pointer for user settings of a MUMPS solver. This function is called at the end of the setup stage. More...
typedef struct _cs_sles_mumps_t | cs_sles_mumps_t |
void | cs_user_sles_mumps_hook (void *context, DMUMPS_STRUC_C *mumps) |
cs_sles_mumps_t * | cs_sles_mumps_define (int f_id, const char *name, int sym, int verbosity, cs_sles_mumps_setup_hook_t *setup_hook, void *context) |
| Define and associate a MUMPS linear system solver for a given field or equation name. More...
cs_sles_mumps_t * | cs_sles_mumps_create (int sym, int verbosity, cs_sles_mumps_setup_hook_t *setup_hook, void *context) |
| Create MUMPS linear system solver info and context. More...
void * | cs_sles_mumps_copy (const void *context) |
| Create MUMPS linear system solver info and context based on existing info and context. More...
void | cs_sles_mumps_free (void *context) |
| Free MUMPS linear equation solver setup context. More...
void | cs_sles_mumps_destroy (void **context) |
| Destroy MUMPS linear system solver info and context. More...
void | cs_sles_mumps_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| Setup MUMPS linear equation solver. More...
cs_sles_convergence_state_t | cs_sles_mumps_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, cs_halo_rotation_t rotation_mode, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| Call MUMPS linear equation solver. More...
void | cs_sles_mumps_log (const void *context, cs_log_t log_type) |
| Log sparse linear equation solver info. More...
◆ CS_SLES_MUMPS_JOB_INIT
#define CS_SLES_MUMPS_JOB_INIT -1 |
◆ cs_sles_mumps_setup_hook_t
cs_sles_mumps_setup_hook_t |
Function pointer for user settings of a MUMPS DMUMPS_STRUC_C solver setup.
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that value or structure should not be temporary (i.e. local);
- Parameters
[in,out] | context | pointer to optional (untyped) value or structure |
[in,out] | dmumps | pointer to DMUMPS_STRUCT_C structure |
This function is called the end of the setup stage.
- Parameters
[in,out] | dmumps | pointer to DMUMPS_STRUC_C structure |
◆ cs_sles_mumps_t
◆ cs_sles_mumps_copy()
void* cs_sles_mumps_copy |
const void * |
context | ) |
- Parameters
[in] | context | pointer to reference info and context (actual type: cs_sles_mumps_t *) |
- Returns
- pointer to newly created solver info object. (actual type: cs_sles_mumps_t *)
◆ cs_sles_mumps_create()
- Parameters
[in] | sym | type of matrix (unsymmetric, SPD, symmetric) |
[in] | verbosity | level of verbosity |
[in] | setup_hook | pointer to optional setup epilogue function |
[in,out] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
- Returns
- pointer to associated linear system object.
◆ cs_sles_mumps_define()
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_mumps_create.
Note that this function returns a pointer directly to the sparse direct solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
- Parameters
[in] | f_id | associated field id, or < 0 |
[in] | name | associated name if f_id < 0, or NULL |
- Returns
- pointer to newly created sparse direct solver info object.
◆ cs_sles_mumps_destroy()
void cs_sles_mumps_destroy |
void ** |
context | ) |
- Parameters
[in,out] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t **) |
◆ cs_sles_mumps_free()
void cs_sles_mumps_free |
void * |
context | ) |
- Parameters
[in,out] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *) |
◆ cs_sles_mumps_log()
void cs_sles_mumps_log |
const void * |
context, |
cs_log_t |
log_type |
- Parameters
[in] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *) |
[in] | log_type | log type |
◆ cs_sles_mumps_setup()
void cs_sles_mumps_setup |
void * |
context, |
const char * |
name, |
const cs_matrix_t * |
a, |
int |
verbosity |
- Parameters
[in] | name | pointer to system name |
[in] | a | associated matrix |
[in] | verbosity | associated verbosity |
◆ cs_sles_mumps_solve()
cs_sles_convergence_state_t cs_sles_mumps_solve |
void * |
context, |
const char * |
name, |
a, |
int |
verbosity, |
cs_halo_rotation_t |
rotation_mode, |
double |
precision, |
double |
r_norm, |
int * |
n_iter, |
double * |
residue, |
const cs_real_t * |
rhs, |
cs_real_t * |
vx, |
size_t |
aux_size, |
void * |
aux_vectors |
- Parameters
[in] | a | matrix |
[in] | rotation_mode | halo update option for rotational periodicity |
[in] | precision | solver precision |
[in] | r_norm | residue normalization |
[out] | n_iter | number of "equivalent" iterations |
[out] | residue | residue |
[in] | rhs | right hand side |
[in,out] | vx | system solution |
[in] | aux_size | number of elements in aux_vectors (in bytes) |
- Returns
- convergence state
◆ cs_user_sles_mumps_hook()
void cs_user_sles_mumps_hook |
void * |
context, |
DMUMPS_STRUC_C * |
mumps |
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that structure should not be temporary (i.e. local);
- Parameters
[in,out] | mumps | pointer to DMUMPS_STRUCT_C structure |
