cs_rotation.h File Reference
+ Include dependency graph for cs_rotation.h:
Data Structures
struct  cs_rotation_t
 Subdomain rotation description. More...
void cs_rotation_define (double omega_x, double omega_y, double omega_z, double invariant_x, double invariant_y, double invariant_z)
 Define a global rotation. More...
void cs_rotation_matrix (double theta, const double axis[3], const double invariant_point[3], double matrix[3][4])
 Compute rotation matrix. More...
void cs_rotation_update_coords (cs_lnum_t n_coords, double t_rot, cs_real_3_t coords[])
 Update coordinates based on a global rotation and time. More...
void cs_rotation_cyl_v (const cs_rotation_t *r, const cs_real_t coords[3], const cs_real_t v[3], cs_real_t vc[3])
 Express a vector in the cyclindrical system associated to a rotation. More...
void cs_rotation_to_array (int r_num, cs_real_t fra[8])
 Copy rotation structure values to an array. More...
cs_rotation_tcs_glob_rotation
◆ cs_rotation_cyl_v()
void cs_rotation_cyl_v ( const cs_rotation_t r,
cs_real_t  vc[3]
[in]rpointer to rotation structure
[in]coordscartesian coordinates of the location point
[in]vvector components in cartesian coordinates system
[out]vcvector components in cylindrical coordinates system
◆ cs_rotation_define()
void cs_rotation_define ( double  omega_x,
double  omega_y,
double  omega_z,
double  invariant_x,
double  invariant_y,
double  invariant_z
The rotation vector's length determines the angular velocity (in rad/s).
[in]omega_xrotation vector x component
[in]omega_yrotation vector y component
[in]omega_zrotation vector z component
[in]invariant_xinvariant point x component
[in]invariant_yinvariant point y component
[in]invariant_zinvariant point z component
◆ cs_rotation_matrix()
void cs_rotation_matrix ( double  theta,
double  matrix[3][4]
[in]thetarotation angle, in radians
[in]axisrotation axis direction vector
[in]invariant_pointinvariant point coordinates
[out]matrixresulting rotation matrix
◆ cs_rotation_to_array()
void cs_rotation_to_array ( int  r_num,
cs_real_t  fra[8]
This may be useful to avoid requiring specific type mappings for MPI or other programming languages.
[in]r_numrotation number (1 to n numbering, 0 for none)
[in]fraflat rotation array: axis (0-2), invariant(3-5), omega (6), angle(7)
◆ cs_rotation_update_coords()
void cs_rotation_update_coords ( cs_lnum_t  n_coords,
double  t_rot,
[in]n_coordsnumber of coordinates
[in]t_rottime since rotation start
[in,out]coordscoordinates array
◆ cs_glob_rotation
cs_rotation_t* cs_glob_rotation
