void | cs_parall_allgather_r (int n_elts, int n_g_elts, cs_real_t array[], cs_real_t g_array[]) |
Build a global array from each local array in each domain. More... | |
void | cs_parall_max_loc_vals (int n, cs_real_t *max, cs_real_t max_loc_vals[]) |
Maximum value of a real and the value of related array on all default communicator processes. More... | |
void | cs_parall_min_loc_vals (int n, cs_real_t *min, cs_real_t min_loc_vals[]) |
Minimum value of a real and the value of related array on all default communicator processes. More... | |
void | cs_parall_min_id_rank_r (cs_lnum_t *elt_id, int *rank_id, cs_real_t dis2mn) |
Given an (id, rank, value) tuple, return the local id and rank corresponding to the global minimum value. More... | |
size_t | cs_parall_get_min_coll_buf_size (void) |
Return minimum recommended scatter or gather buffer size. More... | |
void | cs_parall_set_min_coll_buf_size (size_t buffer_size) |
Define minimum recommended scatter or gather buffer size. More... | |
Local arrays are appended in order of owning MPI rank. The size of each local array may be different.
Use of this function may be quite practical, but should be limited to user functions, as it may limit scalability (especially as regards memory usage).
[in] | n_elts | size of the local array |
[in] | n_g_elts | size of the global array |
[in] | array | local array (size: n_elts) |
[out] | g_array | global array (size: n_g_elts) |
size_t cs_parall_get_min_coll_buf_size | ( | void | ) |
This is used by some internal part to block or scatter/gather algorithms, so as to allow I/O buffer size tuning.
[in] | n | size of the related array |
[in,out] | max | local max in, global max out |
[in,out] | max_loc_vals | array values at location of local max in, and at location of global max out |
[in,out] | elt_id | element id for which the value is the smallest (local in, global out) |
[in,out] | rank_id | rank id for which the value is the smallest (local in, global out) |
[in] | val | associated local minimum value |
[in,out] | min | local min in, global min out |
[in,out] | min_loc_vals | array values at location of local min in, and at location of global min out |
void cs_parall_set_min_coll_buf_size | ( | size_t | buffer_size | ) |
[in] | buffer_size | minimum recommended part to block or gather buffer size (in bytes) |
