void | cs_notebook_load_from_file (void) |
Initialize the notebook object (based on cs_tree_node_t) More... | |
int | cs_notebook_parameter_is_present (const char *name, int *editable) |
Check if a parameter value is present. More... | |
cs_real_t | cs_notebook_parameter_value_by_name (const char *name) |
Return a parameter value (real). More... | |
void | cs_notebook_parameter_set_value (const char *name, cs_real_t val) |
Set a parameter value (real) for an editable parameter. More... | |
int | cs_notebook_parameter_get_openturns_status (char *name) |
Indicate whether the parameter is used for a study with openturns. More... | |
const char * | cs_notebook_parameter_get_description (char *name) |
Returns the description of the parameter (GUI defined) More... | |
void | cs_notebook_destroy_all (void) |
Destroy the notebook structure. More... | |
void | cs_notebook_log (void) |
Output the notebook info to the setup log. More... | |
void | cs_notebook_uncertain_output (void) |
Writes uncertain values to output file. More... | |
void cs_notebook_destroy_all | ( | void | ) |
Destroys the structures related to the notebook
void cs_notebook_load_from_file | ( | void | ) |
The name used to identify the object is "cs_notebook".
void cs_notebook_log | ( | void | ) |
const char* cs_notebook_parameter_get_description | ( | char * | name | ) |
[in] | name | name of the parameter |
int cs_notebook_parameter_get_openturns_status | ( | char * | name | ) |
Returns an int flag to indicate whether this paramter is used for an OpenTurns study. -1 : The parameter is not used with OpenTurns 0 : The parameter is used as an input from OpenTurns 1 : The parameter is used as an output to OpenTurns
int cs_notebook_parameter_is_present | ( | const char * | name, |
int * | editable | ||
[out] | editable | 1 if the value is editable, 0 otherwise (optional) |
void cs_notebook_parameter_set_value | ( | const char * | name, |
cs_real_t | val | ||
The name used is the same as the one in the GUI
[in] | val | value of the parameter |
cs_real_t cs_notebook_parameter_value_by_name | ( | const char * | name | ) |
void cs_notebook_uncertain_output | ( | void | ) |
If input and output uncertain variables are provided, output values are written to an output file : cs_uncertain_output.dat Results are ordered in the definition order in the notebook.
