| cs_mesh_cartesian_params_t * | cs_mesh_cartesian_get_params (void) |
| | Return pointer to cartesian mesh parameters structure. More...
| void | cs_mesh_cartesian_create (void) |
| | Create cartesian mesh structure. More...
| void | cs_mesh_cartesian_define_simple (int ncells[3], cs_real_t xyz[6]) |
| | Define a simple cartesian mesh with a constant step in all directions. More...
| void | cs_mesh_cartesian_define_dir_user (int idir, int ncells, cs_real_t vtx_coord[]) |
| | Define directions parameters based on a user input. More...
| void | cs_mesh_cartesian_define_from_csv (const char *csv_file_name) |
| | Define a simple cartesian mesh based on a CSV file. CSV file needs to contain : (1) First line which is empty or contains a header (2) Second line containing number of vertices per direction: format is 'nx;ny;nz' (3) Third line is empty or contains a header (4) Fourth line and onwards contains vertices coordinates for each direction. Format is "X1[i];X2[i];X3[i]" for index i. If current vertex index is beyond max value for a given direction, an empty value is expected. For example, if for index 'j' the first direction is empty, format is : ';X2[j];X3[j]'. More...
| void | cs_mesh_cartesian_define_dir_params (int idim, cs_mesh_cartesian_law_t law, int ncells, cs_real_t smin, cs_real_t smax, cs_real_t progression) |
| | Define parameters for a given direction. More...
| int | cs_mesh_cartesian_need_build (void) |
| | Indicate if a cartesian mesh is to be built. More...
| int | cs_mesh_cartesian_get_ncells (int idim) |
| | Get number of cells in a given direction. More...
| void | cs_mesh_cartesian_connectivity (cs_mesh_t *m, cs_mesh_builder_t *mb, long echo) |
| | Build unstructured connectivity needed for partitionning. More...
| void | cs_mesh_cartesian_params_destroy (void) |
| | Destroy cartesian mesh parameters. More...
◆ cs_mesh_cartesian_law_t
| Enumerator |
| CS_MESH_CARTESIAN_CONSTANT_LAW | |
| CS_MESH_CARTESIAN_GEOMETRIC_LAW | |
| CS_MESH_CARTESIAN_PARABOLIC_LAW | |
| CS_MESH_CARTESIAN_USER_LAW | |
| CS_MESH_CARTESIAN_N_LAW_TYPES | |
◆ cs_mesh_cartesian_connectivity()
- Parameters
◆ cs_mesh_cartesian_create()
| void cs_mesh_cartesian_create |
void |
◆ cs_mesh_cartesian_define_dir_params()
- Parameters
| [in] | idim | Geometrical direction: 0->X, 1->Y, 2->Z |
| [in] | law | 1D discretization law: constant, geometric or parabolic |
| [in] | ncells | Number of cells for this direction |
| [in] | smin | Min coordinate value for this direction |
| [in] | smax | Max coordinate value for this direction |
| [in] | progression | Progression value, only used for geometric or parabolic laws. |
◆ cs_mesh_cartesian_define_dir_user()
| void cs_mesh_cartesian_define_dir_user |
int |
idir, |
int |
ncells, |
cs_real_t |
vtx_coord[] |
- Parameters
| [in] | idir | Direction index. 0->X, 1->Y, 2->Z |
| [in] | ncells | Number of cells for the direction |
| [in] | vtx_coord | Array of size ncells+1 containing 1D coordinate values for vertices on the given direction |
◆ cs_mesh_cartesian_define_from_csv()
| void cs_mesh_cartesian_define_from_csv |
const char * |
csv_file_name | ) |
- Parameters
| [in] | csv_file_name | name of CSV file containing mesh information. |
◆ cs_mesh_cartesian_define_simple()
| void cs_mesh_cartesian_define_simple |
int |
ncells[3], |
cs_real_t |
xyz[6] |
- Parameters
| [in] | ncells | Array of size 3 containing number of cells in each direction |
| [in] | xyz | Array of size 6 containing min values, followed by max values for the three directions. |
◆ cs_mesh_cartesian_get_ncells()
| int cs_mesh_cartesian_get_ncells |
int |
idim | ) |
- Parameters
| [in] | idim | Index of direction: 0->X, 1->Y, 2->Z |
- Returns
- Number of cells in corresponding direction (int)
◆ cs_mesh_cartesian_get_params()
| cs_mesh_cartesian_params_t* cs_mesh_cartesian_get_params |
void |
- Returns
- pointer to cs_mesh_cartesian_params_t structure
◆ cs_mesh_cartesian_need_build()
| int cs_mesh_cartesian_need_build |
void |
- Returns
- 1 if mesh needs to be built, 0 otherwise
◆ cs_mesh_cartesian_params_destroy()
| void cs_mesh_cartesian_params_destroy |
void |
